![]() Join Date: Jun 2007
Intake manifold Brake booster plug
I will be installing a hydratech hydroboost brake set up in my Blazer. Because of this I need to plug the hole where the brake booster got its vacuum. Trucks with factory hydroboost have the plug in that location. I do not want to put a bolt in a hose!
Does anyone have the GM part number for that plug? It will look like this but it is solid instead of hollow. ![]()
Click on my Not really a build thread, yet NOT SO RUST FREE RUST FREE BLAZER LS ENGINE SWAP INFORMATION THREAD BOLT RESTORATIONS 4l60 to an NP205 |
Re: Intake manifold Brake booster plug
Years ago I tried to find the part number for that plug and never did find one for it. The part its self doesn't have a number cast into it either. But if you send me your address I'll send you this one.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
Information sent. Thank you so much!
Can’t you find and use a vacuum cap on the original fitting?
You could but why when they make the correct part?
AC Delco #12559760. This is the part number for the nipple.
Edit: I see that you are looking for the part number for the plug. Looks like ICT billet make a billet plug that you could use. I have a couple around somewhere, but I cleaned and not I can't find anything lol |
![]() Join Date: Mar 2000
I have a bag full of those plugs.
Saskatoon, Saskatchewan Canada |
Do you have a part number ?
I have been looking as well I can find lots of vacuum booster nipples no vacuum plug numbers |
You wouldn't happen to have a part number for that bag full of them?
Did you not get the one I sent you?
No sir. But the part number may help others?
I sent it out Monday morning. I'll have to find the receipt from the PO to see what happened to it.
The luck I am having finding this plug is not working!
I had a vacuum cap on that port but the engine hiccupped and it took a long time to find the problem......... it blew the cap off, so I need a bag of the RIGHT plugs as I have 3 engines not using this port Thanks
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll ZZ4 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red 327 340hp 4spd 3:36 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wifes cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
