Old 08-31-2021, 04:55 PM   #1
enonz65c30
preferred brand of intank fuel pump 88 TBI 454
I need to order two new fuel pumps and sending units for my project truck(1988 gmc r3500 454 wTBI). What is everyone's preferred brand? I have twin tanks as well. Thank you in advance for any help on this.
enonz65c30 is offline   Reply With Quote
Old 08-31-2021, 07:53 PM   #2
52napco
Re: preferred brand of intank fuel pump 88 TBI 454
Walbro is good or maybe Edelbrock has a made in USA pump..
52napco is offline   Reply With Quote
Old 09-01-2021, 05:29 AM   #3
FBD guy
I’ve always ordered GM or DELPHI from rockauto.
Old 09-01-2021, 01:38 PM   #4
THI
Junior Member
THI's Avatar
I also will only use AC Delco or Delphi - I have replaced too many Carter pumps and I only like to do that job once!
THI is offline   Reply With Quote
Old 09-01-2021, 04:40 PM   #5
44th Miss Inf
I always use the ep381 pump (96-up vortec) on my tbi trucks, have been since they came out, and have never had an issue. Some recommend the ep377 (94-95 454 tbi) but I would NOT use an ep386, which is what came in the truck. They barely supply enough fuel for a 350, much less a 454.
44th Miss Inf is offline   Reply With Quote
Old 09-01-2021, 05:31 PM   #6
FBD guy
Ive read that before, maybe from you
Old 09-06-2021, 11:17 AM   #7
enonz65c30
Thank you for the info, i have a delphi on the way for the driver side and passenger side(whole hanger unit pump and sender) the passenger side sending unit is the worst of the two. ground wire is held on by vice grips
Old 09-06-2021, 01:57 PM   #8
SCOTI
SCOTI's Avatar
Delphi. Avoid GM pumps. Anything new is made in Mexico w/these. I installed both L/R new units on my dually (circa 2015) & both failed within months (<6). Swapped to Delphi's & no issues.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Copyright ©2000 - 2021, vBulletin Solutions Inc.
Copyright 1997-2020 67-72chevytrucks.com
