1967 5x4.75 help
Hi Guys, Long time lurker 1st time poster.
Needing help converting my Dad's 67 to 5x4.75 disc. He has a set of wheels that he has his heart set on and I want to find a way to make it happen for him. From what I've read we can get a stock spindle bolt on kit, but it will increase the track width. I'm still not sure if it's 1.25 per side or over all. I don't believe we have the room for 1.25 per side. Other option is, we have a set of spindles and calipers that I believe to be 71-72 but I'm not sure how to confirm. I know they make a 6x5.5 to 5x4.75 conversion rotor for the 71+ but I'm unsure of what ball joints and tie rods/ adjuster sleeves to use. I'm thinking it would just be the conversion rotors, 71-72 ball joints and tie rods with the conversion adjuster sleeves if I can confirm that those are indeed 71-72 spindles Any advice y'all can give will be greatly appreciated. Dad's getting on up in his age and has already had a heart transplant, I want to do everything I can to get him in his 67 ASAP Thanks in advance for any help y'all can offer |
![]() ![]() ![]() Join Date: Jan 2018
Re: 1967 5x4.75 help
A recent thread on the subject: http://67-72chevytrucks.com/vboard/s...d.php?t=830560
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
#3 | |
Thank you for pointing me I'm the right direction? I think I can make that set up happen. |
Another thing you can do is use a wheel adapter as a guide, and drill the larger rotor to desired bolt pattern.
The 1 inch rotors are not the best if you work the truck or bomb curvy roads. They heat soak faster, and warp easier then the 1.25 rotors. Plus lack a good caliper upgrade like the Wilwood D52's. None of which matter if you cruise around. |
#5 | |
If desiring to go that route, search for a machine shop that can re-drill the 5x5 pattern to the car/5x4.75 pattern if you don't have the proper equipment to DIY.
At the body shop.
Redrill maybe a problem with the reinforcement lug
" That didnt make it any newer " " Dont antique the equipment " |
Ahh.... If that's how they're all made now, that would be a re-drill issue. When I did a pair it was w/some genuine GM rotors back around 1988. Not a problem w/them back then.
![]() Join Date: Nov 2001
There is another option...
71-72 Chevrolet 1/2ton Van Factory Spindle - Then use all 71-72 Truck ball joints and steering linkage. OR 73-74 Chevrolet 1/2ton Van Factory Spindle - Then use all 73-79 Truck ball joints and steering linkage. Both these options use 5 x 4-3/4" bolt pattern. They are a smaller diameter rotor, but they are the same rotor, caliper & pads as found on the 70-78 Camaros. Draw backs are: You do NOT have an option of running a lowered spindle... AND you have to go find a used/salvage yard 71/72 or 73/74 Chevy Van. Keep in mind... In 1975 they went to 5 on 5 bolt pattern. I still have a set up of each; one 71/72 and one 73/74 Spindle Assy. No, I am not interested in selling. This option keeps it simple and easy to order parts from the parts store. Because you order the Suspension pieces (Ball Joints, Tie Rods, etc..) for the correct year Pickup Truck (71/72 or 73/79), then you order the Brake pieces (rotors, calipers, pads, wheel bearings, etc..) for the Correct Year Van Spindle (71/72 or 73/74) used, which is the same as 70-78 Camaro. Funny part is telling the parts counter person you have an old van, then the look on their face when they typically have everything on the self. PM me if you have more questions... I spent 30+ years working in Auto Parts stores.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White 2002 Chevrolet 1500HD 4x4 Crew Cab 6.0L 4L80E Red Last edited by 67 cst swb; 02-07-2022 at 04:13 PM. |
At the body shop.
Can't say all.
We where going to do the 4.75 pattern til that showed itself. The hub we modified this weekend
#10 | |
For those seeking something heavier duty, re-drilling once worked. I have (had?) a set of GM 1/2 12" x 1.25" thick rotors on my 67/68 that were re-drilled to car pattern. I'd have to pull one off to verify if it still has them now since it's been raided for parts as the years went by.
I know the S10 & g-body guys routinely cut old rotors up to use as hubs. I didn't care for that as I read of @ least a couple of instances where the hub eventually cracked/failed. That's why I opted for the aftermarket billet hubs on my more recent projects slated for larger brakes.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-07-2022 at 07:35 PM. |
Just as a reference in case somebody wants the info at a later date. You can get one of these to drill the rotor assuming it is possible. They work great on the rear axles.
https://www.hellsgatehotrods.com/pro.../drill-guides/ |
#13 | |
I have done it before, but I had access to a lathe to thin the face some to get some hubcentric action going. I had access to proper disks from a known manufacturer so I didn't feel I had a cheap metal problem coming. Remember if you do that. They have proper arc welding rods to weld to cast iron |
#14 | ||
#15 |
Awesome stuff Guys!
Thank you all for the info. This truck is just going to be a peppy little patina cruiser for the ole man to do burn outs and putt around the country in. So, the CPP bolt on kit does indeed add 2.5" to the total front track width? Machining parts is not a problem as long as it's time/money efficient. My Dad and I are both machinist and we have a pretty nice little manual machine shop set up. Had originally thought about getting 71+ rotors and turning them down and re-drilling the pattern, but was worried about, casting issues and material thickness between the hub ID and OD after it was turned for the smaller center bore. Would like to use the factory or the possible 71+ spindles that we have. Will just bite the bullet and buy some spindles and go with the method in the thread listed above if machining or the CPP bolt on isnt feasible. Is there any way to confirm that what spindles we actually have? I know they were used on a 67-72 from what we were told, but I don't know with what set-up. We also have calipers with hoses with the casting number 5474176 if anyone knows what they are. I can't find many definitive answers from the number alone. Back story: My dad has owned the 67 for years but was never able to restore it due to health and family issues. Due to it needing rockers and corners we decided to find him a nice roller we could throw his built 355 in for a quick project to get him cruising. Afterwards I'd buy the 67. Ended up buying a pretty nice 70 roller with a ton of new and slightly used aftermarket parts. A set of 18/20 wheels (in 5x4.75 of course SMH, lol), SPP lower tubular control arms RHE trailing arms, bolt on rear disc kit in 5x4.75, CPP sway bars etc.... After getting the 70 back to the shop the ole man decided that he just couldn't part ways with his beloved small window. So now we're going to put all the parts on the 67 and I'm going to build the 70 for myself after Dad is cruising. Going to be a fun adventure y'all probably be seeing a lot of me, LOL Thanks again for all of the info |
#16 | |||
Going to disc from drum brakes adds to the track width. Drop spindles (which are only available for disc set-ups) can add a little more depending on the manufacturer. It depends on how you look @ your tape measure but it's typically 3/8" per side. CPP makes a 'Modular' drop spindle. It maintains the drum brake set-ups track width. Not familiar w/these abreviations: Quote:
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-07-2022 at 11:15 PM. |
#17 |
I'm aware that it adds to the track width. That is my concern. Per the CPP website specs P/N 6370WBK-5 adds 1.25". doesn't state over all or per side. I'm not concerned with drop spindles unless the factory spindle bolt on kit won't work
I've also read that the typical drop spindle disc conversion adds a minimal amount of width increase. 1/2"-3/4" per side I can live with, an additional 1.25 per side will probably make the tire sit outside the fender. EDIT: Widening the track isnt an issue as long as the wheels we have will fit without sticking out, or looking weird with a wide front and narrow rear. Sorry if I'm being confusing it's been a long day Last edited by chipmaker 1985; 02-07-2022 at 11:40 PM. |
#18 | |
#19 |
It's not an aftermarket spindle it's a bolt on bracket that adapts the stock drum rotor to accept a disc caliper.
That adds 1.25" not sure per side or overall. From what I've gathered the aftermarket spindle, Camaro rotor swap adds less than an inch per side. Would like to just use the bolt on stock spindle kit for simplicity. Going down to the shop today to try to mock up the wheels and see exactly how much room we have to work with. |
#20 | |
Again, going from drum to disc brakes increases the track width .375 - .500". Drop spindles can add more to this number but would still come in under the 1.25" per side mark. I googled that exact p/n off CPP's site. I don't see anywhere in the descript about 1.25" added to the track width:
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 02-08-2022 at 01:31 PM. |
#21 |
Talked with Austin at CJ pony parts today. He confirmed that this kit does indeed add 1.25" per side. There is a special note at the bottom of the listing stating this
Luckily the wheels he has will actually work out better with the additional width! |
#22 |
Not seeing anything ? Is there supposed to be a link?
Did you inquire how exactly the track width grows 1.25" vs drum brakes? No way I'd do a kit that spaced things out 1.25" (2.5" total) when other options are out there but that's personal preference.
#23 |
Nope didn't ask how. Would assume it has to do with the lug surface position in relation to the position of the bearing seats. The kit doesn't reuse the original bearing hubs so that's where I think the difference is.
Agreed this isn't the method I'd choose, hell I'd never convert a full size Chevy to 5x4.75 anyways. But it isn't my truck and that's the way the ole man wanted to do it. The kit arrived a couple days ago, hope to be installing it in the next few weeks. I'll take measurements before and after to see how much difference and what causes it. |
