Old 12-13-2021, 10:51 AM   #26
youngrodder
youngrodder's Avatar
Re: 1957 Chevy farm truck from Australia
This looks AWESOME...Love the look, laid out flat with those 22's.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 12-23-2021, 10:57 AM   #27
my56chevytruck
my56chevytruck's Avatar
Originally Posted by Vomit View Post
Thank you for the kind words gents.
I have been working on the truck as much as I can.
Jumping into the front suspension.
I took it all apart. wire wheeled and did a half-arse job sand blasting the upper and lower arms before painting them satin black. Installed new upper and lower ball joints. Some 7" slam bags and 3" drop spindles.
I somehow ended up with 2 left sided upper bag plates so had to cut, re bend and weld them up before installing.
I managed to break my vice trying to use it as a press too. OOOPS!
I put the old hubs and wheels on as I was really keen to see how low it would be.
Unfortunately not low enough.
So now im thinking of my next moves.im 130mm off the deck and I know the wheel/tyre combo i plan on running will get me 40mm lower. Ive now just seen guys have reversed the cups and set them down into the LCA to drop the bag mount alil more, might get me another 50mm?
I wanted to avoid doing a Z notch.
truck looks great and what a nice shop you've got. That's a lot of cast to break, wow!
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
Old 12-28-2021, 08:22 AM   #28
Vomit
Vomit's Avatar
Slow progress but i did manage to remove the inner guards from the front clip(rusty bolts in hard to reach areas suck) so i could double check wheel position in fender.
Im happy with that.
Currently doing some measuring and drawing for a rear notch.
Vomit is offline   Reply With Quote
Old 12-28-2021, 09:14 AM   #29
youngrodder
That looks really cool.
Marc
Old 12-28-2021, 10:49 AM   #30
Rickysnickers
Looks nice. I resized your photo.
Old 03-03-2022, 02:07 AM   #31
Vomit
Vomit's Avatar
Posting a small update as reading back through what ive done so far keeps me motivated to push on.
I drew up C notch sections on CAD and had them laser cut.
Lock in gussets with holes for cross members.
Lots of welding to do, should keep me busy.
Old 03-10-2023, 05:28 PM   #32
daveshilling
daveshilling's Avatar
Any updates on this truck??
daveshilling is offline   Reply With Quote
Old 03-10-2023, 09:09 PM   #33
lv2tri2
Looking forward to your build.
lv2tri2 is offline   Reply With Quote
Old 03-10-2023, 10:01 PM   #34
dsraven
that looks like a reaaaaaaally long truck. plans?
Old 03-10-2023, 10:02 PM   #35
dsraven
I love how clean your shop is. I can imagine your build is just as clean. keep posting, we love to see forward progress.
