03-07-2022, 02:20 AM | #1 |
1972 k30
Ok time has come to document this build and progress on the 1972 k30 build. In the works is
Power train -Stroked BBC (1969 427 2 bolt car) -4l80e (2003 gmc) -Twin stick NP205 (1991 1 ton) -Holley sniper (will also control the trans) -HD 4x4 engine crossmember built by CFM industries (We used my chassis for the proto type for a product that was desperately needed in the market) Chassis -1971 Chevy K20 -52" Alcan 4" lift springs -Diy4x4 B52's up front and their shackle flip in the rear (should be around a 8 inch lift) -1.5 dom Crossover steering and tie rod with barnes 4x4 weld in inserts Diffs -14 bolt w/ 4:56 & Grizzly locker built by Great Lake Offroad with their disc brake kit and hd cover. (I need to run the numbers on this because it is a direct bolt in for our trucks) -Dana 60 w/ a spartan locker, yukon 4:56's, hd lock outs, 35 spline stub shafts and GLO hd cover. I acquired the chassis from a local pick and pull (Feb 19')but didn't decide to build the truck until my dad and I made a 3 hour trip out to plains to buy a cab off a Facebook post (May 20') Well enough off blah blah here are some pics from the adventures of my old man and I playing with trucks
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com Last edited by Curtb1971; 03-12-2022 at 02:12 AM. |
03-07-2022, 02:27 AM | #2 |
Re: 1972 k30
Worn out, greasy, rusty, dirty parts
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com |
03-07-2022, 02:33 AM | #3 |
Re: 1972 k30
Diffs
03-07-2022, 02:49 AM | #4 |
Re: 1972 k30
Fighting king pins.... After stripping the 7/8 hex, then running out of gas with the torch and uga dug power on the breaker bar I used a you tube method of welding a piece of steel to the king pin. It didn't say no when I hit it with the 10lbs sledge (my purse) Had to borrow a friend's BA torque wrench to get the new king pins to 600 ft lbs!!! To say the least I was a little intimateded but it went smooth with the 5ft handle.
03-07-2022, 03:00 AM | #5 |
Re: 1972 k30
Did a road trip with my dad to Alcan Springs in Grand Junction to grab some buddies and my springs. They gave us the nickel tour of their spring making process and wow these guys are a top notch small biz. B52 52 inch spring conversion and shackle flip and dropping the frame off to get blasted.
03-07-2022, 03:11 AM | #6 |
Re: 1972 k30
NP205 came put of a 1991 1 ton but I didn't get the golden adaptor. Cool thing is that it has the gm vss in the output for the 4L80e. Was a pretty simple rebuild for playing with my first one. Had to get new shift forks and shift collars because they had some hefty wear. A friend of mine milled down the shift rail detents for the twin sticks.
03-07-2022, 03:28 AM | #7 |
Re: 1972 k30
NP205 twin stick shift rail with detents milled out next to a buggered up stock rail. 4L80E was built by TnT automotive and random pic of the chassis
03-07-2022, 03:34 AM | #8 |
Re: 1972 k30
Pics
03-07-2022, 03:45 AM | #9 |
Re: 1972 k30
The cab was built summer of 2020 and I did most of the work with supervision because my dad had his shoulder replaced that April. He showed me more tips and tricks that i can add to the hat. Panel bond for the win on the rockers
03-07-2022, 03:54 AM | #10 |
Re: 1972 k30
I gotz the bluessss
03-07-2022, 04:04 AM | #11 |
Re: 1972 k30
Glass, door and Q-pads
03-07-2022, 04:11 AM | #12 |
Re: 1972 k30
Bed
03-07-2022, 04:17 AM | #13 |
Re: 1972 k30
More bed pics
03-07-2022, 04:27 AM | #14 |
Re: 1972 k30
Bed is on the frame and looking goofy with them little tires. Had some 72 steel DG4 mirrors chrome plated thanks to a good friend and some other parts zinc plated at Denver Metal Finishing.
03-07-2022, 04:50 AM | #15 |
Re: 1972 k30
CFM Industries 4x4 engine crossmember.
In the begining i was going to put an LS 6.0 in the truck and after searching I wasnt impressed with the products avaible in the market. I then contacted CFM about if they made a crossmember for 67-72s because they had a LS one for square body's. They said they didn't but would like to scan a chassis with their 3D scanner and asked if I could bring it there. Turns out they are only a couple miles from my shop and ended up coming over with their super high tech 3D scanner to scan the frame. After me changing to a BBC a few renderings Darren engineered this one and wow.... No drilling, no modifications to the brake lines, 0-2.5" forward adjustment from stock, removable cross section for oil pan access and here is the kicker small block, BBC or LS adaptable with clearance to keep the AC compressor in the factory location. Pretty cool to be part of this product because it was a void needed for us 67-72 guys
03-08-2022, 06:56 PM | #16 |
Carpe manana
Re: 1972 k30
Looks like excellent work Curt. Following.
03-11-2022, 12:32 AM | #17 |
Re: 1972 k30
Right on Pete, it been a fun project for my old man and I
Just got the big blocks back from the machine shop. The 427 and a 402 for a later project. Just ordered the parts for the 402 today and started looking at heads and the stroker kit for the 4x4. Figured I'll practice on the 402 for now. More fun coming up soon.
03-11-2022, 01:28 AM | #18 |
All about them K’s
Re: 1972 k30
Nice work Curt, that’s gonna be a really special truck when you are done. I still have the one me and my old man built way back when I was in high school. Can’t wait to see it continue to come together. That crossover setup on the 60 looks good. If I ever decide to take mine that high I’m going to do something similar with my 60. I keep swearing that 4” is all I need but I do like them up in the air. That crossmember looks awesome, I’ll keep it in mind when I get to my 6.0 swap.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
03-11-2022, 07:52 AM | #19 |
6>8 Plugless........
Re: 1972 k30
Very nice work on this K30! Everything looks beautiful. I really like that engine cross member. There definitely weren't many options for these trucks. Finding original ones that are nice is tough and I hate those stupid flat mounts mainly because they suck to put the bolts in.
What did you use to paint your frame and suspension? Your trans and tcase looks very nice as well. I've got a 72 K20 Cheyenne Super I'm working on now and I almost went with that blue and white but I might paint it back to it's original colors. I'm not sure. I've always liked that blue and white but never had one.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
03-11-2022, 02:12 PM | #20 |
Re: 1972 k30
Awesome so far. How are you putting the 205 on the 80e?
Also i see your paypal in your sig. Does that mean you want donations?
1970 k20 6.0l/nv4500/np205/14bff in progress build linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=677014 |
03-12-2022, 02:04 AM | #21 | ||
Re: 1972 k30
That's an interesting question because I'm stuck between machining a spacer or whacking down the output shaft on the trans. I intended to run the stock 4L80e adaptor with a little machining for the shift rails because the T case bolt pattern is the same for the 205. Was going to run a advanced adaptor spacer with a clocking ring but I think that's just too much going on there. Probaly going to just mill a 1/2 longer spacer and if the T case needs clocked I'll drill new mount holes in the case. I'll see if I can find a pic of the stock adaptor whacked out for the shift rail. Used to sell a few parts on the board so hence to paypal sig but donations are always welcome, I'm sure I'd find a way to waste them on old truck parts
1971 LSX "Bonnie" build thread http://67-72chevytrucks.com/vboard/s....php?p=8026381 paypal is curtbarton1971@yahoo.com Last edited by Curtb1971; 03-12-2022 at 02:24 AM. |
03-12-2022, 08:37 AM | #22 |
Re: 1972 k30
LMAO at the donations. Maybe you're on to something?
04-28-2022, 12:58 AM | #23 |
Re: 1972 k30
Cool to see this one finally got a build thread going. I'm going to have to reach out to CFM on that cross member an 8.1 that I've got laying around just might fit in that.
'71 K1500 Short-Wide '86 K30 C&C '89 Iroc-Z |
04-28-2022, 11:37 PM | #24 | |
Re: 1972 k30
Haven't worked on the truck much because work has been eating up the fun time but did get to tinker with some interior stuff last Saturday and hang out with my ol man. Installed some black carpet material in place of the jute pad on the firewall, radio and heater boxes. Mocked in the modified under dash harness that hopefully is set up good for the Holley sniper that ships June 30 The 402 for another truck is finished and now time have to shift gears and get going on the big block for this truck.
04-29-2022, 01:28 AM | #25 |
Re: 1972 k30
I’m really digging this build thread.
