Old 03-17-2022, 05:47 PM   #476
Jiggers72-GMC
Jiggers72-GMC's Avatar
Re: '72 Cheyenne K10
Very nice, I got this one off Amazon, no cutting wires,
Tow Ready 118311 T-Connector
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 03-17-2022, 05:50 PM   #477
Jiggers72-GMC
I need exhaust, what system do you have there ??
Old 03-17-2022, 06:21 PM   #478
jimbosprint
jimbosprint's Avatar
The exhaust was built by Freese's Exhaust Shop here in Chico. The pipe is 2.25" and the mufflers are 18" Magnaflows.
jimbosprint is offline   Reply With Quote
Old 03-18-2022, 06:03 AM   #479
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Looks good, try not to use the rear recovery point though...
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 03-18-2022, 08:06 AM   #480
Jiggers72-GMC
Thanks for the exhaust info Jim, I'll probably take mine to a local shop up here that does great work.
Old 03-20-2022, 10:58 PM   #481
memo43
memo43's Avatar
Awesome build, really enjoyed it.
Especially the attention to detail that you provided.
I drive an 85 k20 and my 18 year old son drives an 86 k20, both daily drivers (even with todays gas prices, we tell everyone that our truck payment is our gas payment).
Keep up the good work, love seeing these ol trucks on the road.
Memo S.
Retired US Marine
Family Man
memo43 is offline   Reply With Quote
Old 03-23-2022, 03:35 PM   #482
jimbosprint
Today I spliced in a 4-wire trailer plug. I used correctly labeled/colored wires that I saved after installing the American Autowire kit.
I also replaced the speedometer cable and removed the speedometer gearbox. The gearbox leaked really bad, and the dash showed double the actual speed. I need to take it for a test drive and see how accurate the speedometer reads now.
Old 03-24-2022, 08:55 AM   #483
Ol Blue K20
Nice, the harness looks clean. I believe you can get new gear boxes in different ratios if need be..
Dale
Old 03-24-2022, 11:07 AM   #484
jimbosprint
So the speedometer doesn't move at all now. I must have missed something.
Old 03-24-2022, 01:13 PM   #485
Jiggers72-GMC
Silly question Jim, is the new cable hooked up to the speedo at the dash??
Old 03-24-2022, 01:18 PM   #486
jimbosprint
It was hooked up on my drive to get dinner, but I disconnected it on the drive home to see if it was spinning at the dash end. It was not.
Old 03-24-2022, 01:25 PM   #487
Ol Blue K20
I hope it's a easy fix!
Dale
Old 03-27-2022, 06:17 PM   #488
jimbosprint
The speedometer cable was just not lined up at the transfer case end - easy fix. It functions, but the accuracy is still off. At 30mph the dash reads 35mph. I'll take the improvement.
I rotated the tires today. Put the spare in so it can get some miles.
Old 03-28-2022, 09:45 AM   #489
SRU1436
I got the trailer hitch installed today. I used c-clamps to hold it up while I drilled the holes in the frame, which worked well. It's important to have a rear recovery point attached to the frame in case I get stuck off road. Now I just need to add a trailer wiring harness.
Attachment 2177779
Attachment 2177780
Attachment 2177781
Attachment 2177782
Looks great, where did you get the trailer hitch from? I want to add one to my 72.
SRU1436 is offline   Reply With Quote
Old 03-28-2022, 09:52 AM   #490
SRU1436
I read through the thread more and found the model, guess I should’ve read more.
http://67-72chevytrucks.com/vboard/i...s/handface.gif
Old 04-15-2022, 06:48 PM   #491
jimbosprint
Backordered saddle door panels showed up today. I also have a Precision window channel kit and new window regulators. Time to rebuild my doors.
Old 04-15-2022, 10:38 PM   #492
Ol Blue K20
Attachment 2186087
Where did you find the nice door panels? Waiting anxiously to see how they fit!
Dale
Old 04-16-2022, 11:28 AM   #493
jimbosprint
I bought them from Classic Industries back in January, but they were out of stock. Driver side armrest is still backordered.
Old 04-16-2022, 02:48 PM   #494
jimbosprint
My driver door has new window seals and a new door panel. Precision weatherstrip is quite a bit nicer than the LMC ones I have used in the past. If I were restoring the truck, I would not be that happy with these OER brand door panels. For this truck they are just fine though.
I'll do the passenger side tomorrow probably. I look forward to how much quieter the cab will be with door panels. And I will not miss the windows banging around in the track.
Old 04-17-2022, 10:21 AM   #495
Ol Blue K20
They look pretty good.
Dale
Old 04-17-2022, 10:24 AM   #496
Jiggers72-GMC
What he said ^^^^^^ the color goes well on your truck.
Old 04-17-2022, 07:26 PM   #497
jimbosprint
I worked on the passenger door today. The handle was missing the button which didn't really matter to me, but I had the new part and so I had to fix it. One of the captured nuts for the armrest was missing. I found it in the bottom of the door and I was able to get it put back. The window regulator needed to be replaced too, so I did that.
Old 04-17-2022, 07:35 PM   #498
jimbosprint
The window roller channel was super gummed up so I cleaned that out. A sharp corner of the window was catching on the new vent window channel so I filed it down for smoother operation. I would like to finish putting the door panel on this side but no parts stores are open on Easter, so I can't get more of the nylon door panel fasteners that I need.
Old 04-18-2022, 02:17 PM   #499
jimbosprint
The passenger door is all back together. Just waiting on an armrest for the driver side.
Old 04-19-2022, 06:34 AM   #500
Ol Blue K20
Nice! Looks real good.
Dale
ochre
