Old 04-15-2022, 05:34 PM   #76
dsraven
Re: subframe question
Sorry, thought you said 81 up.
Old 04-15-2022, 06:03 PM   #77
jmlloar
jmlloar's Avatar
I did. 73 to 80 and or 81 to 91. basically the same.
square body.
jmlloar is offline   Reply With Quote
Old 04-15-2022, 11:03 PM   #78
TonyMann
I have a 57 one ton and I installed 73 3/4 ton frame on my truck and it could'nt have worked out better, I cut a c shape right behind where shocks were mounted. I then removed the rotors and calipers, installed 1988 one ton rotors, put the calipers back on and a proportioning valve and a dual chamber m cylinder in the stock location with a booster and it rides, handles, steers, and stops like a 73 to 85 square body. make sure to right down any V I N or serial number you come across, most frames are numbered on the front. and make sure (most important) that you keep the wheel base the same.
TonyMann is offline   Reply With Quote
Old 04-15-2022, 11:06 PM   #79
TonyMann
Included some pics if it helps. TonyMann.
Old 04-21-2022, 11:10 PM   #80
jmlloar
jmlloar's Avatar
can get a 91 1 ton dually frame but not sure on making it work.
also can get a mid 90's 3500 hd.
it has 19.5 wheels and 454ci with 4l80e
Those years have a lot more curves in the frame.
Old 05-12-2022, 12:15 AM   #81
jmlloar
jmlloar's Avatar
Got my hands on a perfect 1980 long bed 3/4 ton frame. Looks like I will do the complete swap instead of the graft after all.
Old 05-12-2022, 08:23 AM   #82
dsraven
Nice. Post up so.e pics when you get rolling in it.
Old 06-14-2022, 06:51 PM   #83
jmlloar
jmlloar's Avatar
8 inches removed from wheelbase
Old 06-14-2022, 07:06 PM   #84
dsraven
Nice fitment. Should weld up nice.
Old 06-19-2022, 04:12 PM   #85
jmlloar
jmlloar's Avatar
plates bolted into place and ready to weld.
I know the plates are overkill but I like to over engineer everything.
Old 06-19-2022, 04:19 PM   #86
jmlloar
jmlloar's Avatar
frame is nice and straight
Old 06-24-2022, 02:47 PM   #87
jmlloar
jmlloar's Avatar
cab mounts installed
Old 04-07-2023, 07:58 PM   #88
jmlloar
jmlloar's Avatar
engine and tranny is in
Old 04-07-2023, 08:00 PM   #89
jmlloar
jmlloar's Avatar
1st suburban tank bracket installed
Old 04-07-2023, 08:05 PM   #90
dsraven
good forward progress. keep plugging away and soon it will be together.
