06-20-2022, 12:25 PM | #1 |
Did the 1/2 ton short beds come with a two piece driveshaft?
I am just wondering if the 1/2 ton C10s with short beds ever came with two piece driveshafts, or will I be looking for a Unicorn?
06-20-2022, 12:32 PM | #2 |
Re: Did the 1/2 ton short beds come with a two piece driveshaft?
Yes. I had a 67 step side that had one and my 70 that I have now. So not quite a unicorn.
06-20-2022, 01:43 PM | #3 |
My 67 short bed is a two piece as well. My 70 model years ago was a one piece. If I ever swap to an automatic transmission I may go back with a one piece.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
06-20-2022, 04:24 PM | #4 |
Its a Truck Thing......
My 71 had a 2 piece. Original 250 6cyl with 3 OTT.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
06-20-2022, 07:03 PM | #5 |
My '71 short Fleet side with the 307 and 3ott had a 2 piece. But when I went 350 with the 700 I went to the one piece.
Smitty '71 Short Fleetside Spring Valley, Ca. |
06-21-2022, 01:45 AM | #6 |
thank you all so much for your feedback I picked up a long bed two piece driveshaft today after learning that they all are the same length from the center bearing support to the rear axle, that will work for me as I am mating it with a Lexus GS450h transmission so I will need to have the front cut and a three bolt flange welded on anyway
got this from a super nice guy named Chris is Westley California for $150 (ish) bucks, the price went down the more things I put in my little to buy pile, ha ha Last edited by Gregski; 06-21-2022 at 01:51 AM. |
06-21-2022, 01:47 AM | #7 |
I also learned how there are two types of drive shafts a skinny one (the size of your wrist) with a flimsly center support bracket and a heftier one with a stronger middle bracket like this one (I got this off of a 3/4 ton long bed) also from Chris in Westley California for $80 (ish) bucks (price adjusted the more suffs I bought) Chris is a great guy
06-21-2022, 01:50 AM | #8 |
I don't mean to brag but I am a bit of a third degree rust belt Ninja with the wire wheel
06-21-2022, 01:52 AM | #9 |
and 17 minutes later...
06-21-2022, 01:55 AM | #10 |
let's not forget the doo dad, bird poop and all
06-21-2022, 01:56 AM | #11 |
now it's ready for the media blasting cabinet and later DIY powder coating
06-21-2022, 02:05 AM | #12 |
My 70 SHORT Box had a 2 piece. Original 250 6cyl with 3 on the tree.
06-21-2022, 09:07 AM | #13 |
Wore those bristles down a bit, did ya? Looks great.
I'd like to ask anyone giving 2pc SWB driveshaft info to include the engine and transmission the truck came with. I'm unclear on the rhyme and reason for 1pc vs 2pc driveshafts. It looks like 6cyl/3spd SWBs came with 2pc
06-21-2022, 09:19 AM | #14 | |
hope this helps, |
06-21-2022, 09:35 AM | #15 | ||
My response: Quote:
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
06-21-2022, 09:41 AM | #16 | |
K
06-21-2022, 09:42 AM | #17 | |
We could make beautiful music together. K
06-21-2022, 09:44 AM | #18 | |
06-21-2022, 09:45 AM | #19 |
Folks, Mr. Keith Seymore is a treasure trove of valuable information, he has helped me many a times with my '74 squarebody build, we must cherish him at all costs (and perhaps clone him) thank you sir!
06-21-2022, 11:18 AM | #20 |
I owned a 67 shortbed that came from the factory with a one-piece driveshaft. It had a 250 engine, a 3OTT transmission and an overdrive unit. It also had 4.10 gears. The gears and overdrive were listed on the SPID. There was no center support bracket on the crossmember.
06-21-2022, 11:48 AM | #21 |
My '71 K10 had a one piece even with a 4" lift and 33" tires, 3.73 gears and Limited Slip. I only replaced the U-joints once in 226,000 hard miles.
'71 C/20 350/T350. |
06-21-2022, 01:09 PM | #22 | |
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90. |
06-21-2022, 07:13 PM | #23 |
'67 Chevy C-10; 283/PG/12-bolt Rear: 2 pc w/ small carrier bearing.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
06-21-2022, 07:19 PM | #24 |
My 67 SWB 327 with a three speed 2 piece originally..
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
06-21-2022, 11:10 PM | #25 |
I had a 72 SB GMC Sierra Grande with a 350/350 drivetrain. It had a two piece. The carrier bearing mount broke and I had it welded….. twice. After it broke the third time I replaced it with a single driveshaft out of a early 70’s chevelle, if I recall correctly. It was a exact fit. Never had another issue with it.
