Old 01-23-2024, 01:49 PM   #1
not2oldchevy
Master cylinder
Best master cylinder for 1953 3100 corvette front disc ford 8.8 rear disc w power brakes
not2oldchevy is offline   Reply With Quote
Old 01-23-2024, 02:28 PM   #2
geezer#99
geezer#99's Avatar
Re: Master cylinder
Instead of relying on someone’s suggestion you should do some calculations.
https://www.speedwaymotors.com/the-t...e-system/30895
Old 01-26-2024, 03:40 PM   #3
e015475
e015475's Avatar
Re: Master cylinder
I'd start with the master that matches your Corvette front brakes year since that's where 70%+ of your braking is going to come from
Since you are mixing and matching brake systems, I'd put an adjustable proportioning valve on the rear brakes and play with it until the rears lock up just before the fronts
https://www.jegs.com/i/JEGS/555/6302...6bju2d9wVCqhvc
e015475 is offline   Reply With Quote
Old 01-27-2024, 10:52 AM   #4
Rickysnickers
Re: Master cylinder
Since this is more of a general question, it's being moved to the suspension area.
