02-05-2024, 10:51 AM | #26 |
Re: 1958 Pontiac Wagon Build
Thanks Guys, and no, just me puttering away at it when I can (weekends and some evenings)
I brought the car home in late October, took the driveline out and started the metalwork in November. So 3 months to do the inner and outer rockers and 1/2 the floor. Is that fast? It's dirty work, but so far I have been enjoying the challenge. Lots more metalwork to go, but's that why I purchased the car, I wanted a project. Stay tuned for the Driver's side (it's in worse shape)
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 |
02-05-2024, 10:40 PM | #27 |
That is fast, especially when you are making your own panels, but don't tell yourself that and keep knocking it out and hopefully drive it in the summer or later this year. Lol.
02-06-2024, 11:20 AM | #28 |
I appreciate the encouragement, but this will not be driving this year. Also, when I put deadlines on myself, it no longer becomes enjoyable.
I was poking around last night with it and this side will need some more work, as the main support is rotted out, next to a body mount, (see pic) but here are some 'Before' pics. After looking at them again this morning, I must be crazy.
02-06-2024, 11:23 AM | #29 | |
Model, settings, wire, etc. Thanks, K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
02-06-2024, 11:23 AM | #30 |
and a few more
02-06-2024, 11:33 AM | #31 |
Sometime I vary the set up depending what and where I am welding, but I am using a 120V Lincoln (20 years old?) with gas, typically on B with the 19 gauge steel( A B C D ) at a wire speed set between 4 and 5. I think the gas pressure is 20? (not sure as I haven't changed it for years) also, I use 023 wire
When I welded in the seat plate (secure rear seat bolts) I upped it to C level heat, as the plate is 16 gauge. I am NOT a good welder, so please do not take my settings as correct. What I have found with sheet metal is that I do not run a bead. I just use a series of tacks to create a weld that looks like a bead. Hope this helps
https://67-72chevytrucks.com/vboard/...=797726&page=3http://https://67-72chevytrucks.com/...=797726&page=3 51 Chev 5 window on S10 with SBC 1958 Pontiac Wagon build https://67-72chevytrucks.com/vboard/...d.php?t=849781 Last edited by Tempest67; 02-06-2024 at 11:49 AM. |
02-06-2024, 11:57 AM | #32 |
Thank you -
K
02-12-2024, 03:16 PM | #33 |
been working on the outer rocker to get it ready for install.
needed to add piece to front of rocker, and add some patches to B and C pillars
02-12-2024, 07:21 PM | #34 |
It's looking good, nice metal work and approach as always.
Those doors appear to be in very good shape and also lined up and evenly gapped for a 50s car. Btw, it never crazy to save a long roof classic with the correct number of doors, it great to see them getting so much attention and love these days. |
02-13-2024, 10:19 AM | #35 |
Thanks 3drburb,
Just trying to focus on the task at hand, and not look at the entire project. Hopefully the next update will show the outer rockers will be in. ........and yes, it is good to see the wagons getting some love.
02-13-2024, 10:32 AM | #36 | |
Oh and once again great job! Your work is inspiring. Just diving in and getting it done.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
02-13-2024, 12:56 PM | #37 |
I still own a 65 Olds F85 4 dr wagon. Drove it for many years and just tucked it away as it was a little tight inside leg room with the kids and me being on the taller side, had it long before the Burb.
02-13-2024, 02:02 PM | #38 | |
3drburb - F85 wagon very cool and thanks for the encouragement
02-25-2024, 08:41 PM | #39 |
Hey Guys, time for an update.
the inner and outer rockers are now in on the drivers side
02-25-2024, 08:46 PM | #40 |
then onto the floor braces.
I went to the 58 Chev floor that I had and cut off what I needed, and welded a bracket inside the brace to weld to the piece still on the car. Also, welded a small patch in the lower corner of the toe board. Next is to install the brace, and then onto the floor. You can see the floor I made just lying there, lots of trimming still to do, but not until AFTER the brace is welded in. (next post)
02-25-2024, 08:48 PM | #41 |
here is the floor piece just sitting in place
02-27-2024, 11:35 PM | #42 |
Very impressive work. Thanks again for showing us along the way.
02-29-2024, 03:22 PM | #43 |
Thanks 3drburb,
Next to do is get this brace in position to weld.
03-01-2024, 10:51 AM | #44 |
put it in position, and welded it in
03-04-2024, 09:27 AM | #45 |
I installed the front driver side floor pan on the weekend.
1st pic hole in floor 2nd pic home made floor pan 3rd pic installed (ran out of welding gas on little piece under seat) 4th pic from below still some trimming/grinding to do, but overall I am pleased with the fit. Next to do is the rear floor pan, and wheel well.
03-04-2024, 02:27 PM | #46 | |
In my world 3 doors are the correct number of doors. 3drburb like this one? Was the Vista Cruser an option then? Okay I should stop high jacking there peoples threads. https://youtu.be/VU5CYt1D-SE?si=AYYCkwzEeigiS0o3 I love the all the posts and appreciate the time it takes to document it.
03-04-2024, 08:55 PM | #47 | |
Very nice Ad, first time seeing it, thanks, also love seeing the kid playing around the cargo area, that Ad will be great nowadays. LOL! Apologies for the hijack. |
03-04-2024, 09:07 PM | #48 | |
The work and those homemade floor pans are looking pretty darn nice. |
03-04-2024, 09:46 PM | #49 |
Some really nice repair work..!!
03-12-2024, 09:56 AM | #50 |
Hi Guys,
I made a patch for the rear wheel well (1st pic), then removed and replaced 1/2 the rear crossmember. Luckily, I had a good crossmember that I could cut and weld in.(from a 58 Chev) I carefully removed the old floor and bent it back, and was able to reattach it to the new brace. Now that I have a good solid brace, I can continue with the floor
