03-29-2024, 11:39 AM | #1301 |
Re: SkinnyG's '61 Apache
So much yes.....
03-29-2024, 02:27 PM | #1302 |
Beautiful.
The weather is also good.
------------------------------------------- Greetings Harald My 62 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=829782 |
03-31-2024, 11:36 AM | #1303 |
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
03-31-2024, 11:59 AM | #1304 |
There is room for a lot of stuff, the trailer is quite large.
03-31-2024, 09:53 PM | #1305 |
Something went "BANG."
04-01-2024, 12:21 AM | #1306 |
Some poop came out.
Turns out the engine sucked apart the Edelbrock air filter, the metal cap inside went into the turbo, and I'm hoping didn't do too much damage.... Off to LordCo tomorrow to see if I can get a K&N that DOES NOT have a suckoffable cap inside.
04-01-2024, 06:34 AM | #1307 |
Wow that could have been bad. I think you got lucky by the looks of it but I would probably still take compressor apart and clean it out and either sand the impeller or replace so no loose bits come off. I always worried about those suckoffable caps since they look to just be glued in but since thats how all the pleats are held in with the metal base air filters I try to grab the ones that are all molded silicone\rubber style material.
04-06-2024, 10:32 AM | #1308 |
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate Last edited by SkinnyG; 04-08-2024 at 01:08 AM. |
04-06-2024, 10:36 AM | #1309 |
Odd. My videos are not embedding...
04-06-2024, 11:19 AM | #1310 |
You've been very lucky with that.
04-14-2024, 10:03 PM | #1311 |
Chasing an increasingly noisy Hydroboost pump.
I've bled it every which way under the sun, but cannot get it to stay quiet for more than 40 minutes of driving. I ordered a new pump. RockAuto wholesaler closeout, got the pump for $58CDN (about $40US). Two days of anger management issues and profanity, and it's in and bled, and appears to be working great. At one point I had to turn the "Blues" off on the stereo, as the songs were just too dang "happy." Black Sabbath to the rescue. And had a visit from a friend today:
04-17-2024, 09:45 AM | #1312 |
I seem to be losing spark, more and more - especially worse the hotter it gets / the more I drive. Definitely missfire.
I've checked plugs. I've changed wires. I'm thinking coils.
04-18-2024, 07:21 AM | #1313 |
I'm curious, what spark plugs, wires and coils are you running?
04-18-2024, 09:33 AM | #1314 |
Maybe it’s a cam or crank position sensor?
04-18-2024, 10:39 AM | #1315 |
Stock 585 coils (round with heat sink), used Delco wires, after running new "Fast" brand wires. NGK TR6 plugs.
A cam or crank sensor should have a code, and will _not_ produce a STFT +15% on bank 2 only (lean misfire).
04-28-2024, 10:57 PM | #1316 |
Found two COOKED plug wires on the passenger side. I definitely need to source some LONG wires to route them around the flipped exhaust manifold rather than under them.
I went back to the "Fast" wires I had made (they were longer on the passenger side, but I pulled them thinking they were causing an issue - I'm not sure they were....). Runs MUCH better now. We'll see how long they last.
