04-18-2024, 01:08 AM | #1 |
275/60/15 at all 4 corners: lowering experts, please come in
Hi guys,
My ‘69 c10 is getting 275/60/15 at all 4 corners on 15x8 4.0” BS truck rallys. I’m debating whether to do a 2/4 or a 3/5 drop. Will either of these drops present any problems for me with the wheel combination above? Thanks Luke
1969 C10 Shortbed Wanted (pm me): - Pair of 275/60/15 tires |
04-18-2024, 08:45 AM | #2 |
Re: 275/60/15 at all 4 corners: lowering experts, please come in
following....
Current stable: 1970 K5 Blazer 4x4 1972 K5 Blazer 4x4 SOLD: 1971 GMC Sierra Grande 2500 2wd 1972 Chevrolet K5 Blazer 1966 Chevrolet C20 1972 Chevy Suburban 4x4 1500 1956 Chevy 150 2 door post 1956 Chevy 2 door post bel air 1968 Chevrolet C20 1958 Ford Thunderbird 1968 4x4 Suburban 1/2 ton |
04-18-2024, 09:11 AM | #3 |
OK, not a lowering expert, but I have a similar setup to what you are describing. My truck is a 2.5/4 static drop with 8" rally wheels. I went with 255/70-15 at the time to better fill up the fender wells.
I could easily add another 20mm of tread width and drop the front or rear another inch without any issues.
1967 C10 1980 Jeep CJ5 2020 Toyota 4Runner 2024 Toyota Tundra |
04-18-2024, 11:44 AM | #4 |
I am not an expert but here is my story.
1967 with 2.5 spindle drop 4" rear. 235/75/15. When I go over a big dip at speed the front tire will contact the inner fender. My tires are smaller than 67C10step yet I have a problem and he doesn't. All that to say, I bet your plan will work. I just recommend that while you have the springs out, check the clearance with the truck on the bump stops. Then adjust things to make it work. |
04-18-2024, 12:01 PM | #5 | |
04-18-2024, 01:09 PM | #6 |
BlahBlahBlah
Here is a thread for 15 inch wheels only. I believe there are a lot of trucks in here that have the combo you are asking about.
https://67-72chevytrucks.com/vboard/...t=15+inch+only
04-18-2024, 08:37 PM | #7 | |
The thing that bothers me is regardless of what spring, if it ever hits hard enough to reach the bump stop it is going the interfere. |
04-18-2024, 08:55 PM | #8 |
Dang man! You need to slow down! Just kidding. I’ve driven mine over 3000 miles since doing the suspension and getting it on the road and I’ve never even felt like I was close to hitting the bump stops up front.
04-18-2024, 09:41 PM | #9 | |
Active Member
Posted via Mobile Device |
04-18-2024, 10:25 PM | #10 |
Very nice! What drop kit is that?
04-19-2024, 12:14 PM | #11 |
FWIW, 255-70x15 tires on 8" rally wheels from a square body truck barely rubbed the bolts holding my inner fenders to the outers. It only happened on bumpy roads while turning. I fixed it by replacing the hex head bolts with button head bolts. My truck has somewhere around a 2" drop at the front.
However, 275-60x15 tires are shorter than mine, so you may not have a problem, depending on how low you go.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
04-19-2024, 12:57 PM | #12 |
Active Member
04-19-2024, 06:41 PM | #13 |
With a 2inch spring drop, can you align to spec ?
04-20-2024, 05:06 PM | #14 |
That's a real beauty with a very nice stance.
04-20-2024, 09:29 PM | #15 |
275/60/15 on 15 x8 all 4 corners 2.5" front 4 " rear static drop no issues on rubbing . Rear tires wear out twice as fast as fronts
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 Last edited by kaycee; 04-20-2024 at 09:31 PM. Reason: brain tumor |
04-20-2024, 10:26 PM | #16 |
Never had an issue with mine not really sure on the drop on it though..
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
04-21-2024, 01:02 AM | #17 |
I ran 275/60's for many years with a 2.5" spindle + 1" drop spring in the front. The rear was a 4" drop spring. This pic is that same drop with slightly smaller overall diameter 255/50-17's.
04-21-2024, 10:50 AM | #18 |
Earlier I wrote: "255-70x15 tires on 8" rally wheels from a square body truck barely rubbed the bolts holding my inner fenders to the outers."
My truck does have 85 spindles. I wonder if they position the wheel outboard just a little further? It's not much, because button head bolts fixed the problem! Tires are Cooper Cobras, which may be a shade wider or taller than BFG Radial T/As.
04-22-2024, 12:18 AM | #19 | |
