04-24-2024, 06:52 PM | #4776 |
Re: What did you do to your truck today.The 3rd chapter
Well, today was working on getting the engine ready for paint, (clean, detail, debug ect.) and work on installing the new suspension parts.
Kelly 1967 El Camino COPO 427 4-speed 1968 C10 Panel 6.0 LS 1968 GMC 1500 Custom (454 in progress) 1969 C10 CST 6.0 LS 1969 Nova |
04-26-2024, 10:14 AM | #4777 |
Brought my old driveshaft in for new u-joints because of a vibration I was having, shop checked it and it turned out to be bent and the previous owner had welded it together poorly and the welds were cracking.
Had the shop build me a new overnight with a little thicker diameter, heading out to install it now.
1972 C10 Step Side short bed |
04-26-2024, 10:24 AM | #4778 |
Removed engine for a re-seal and repaint, gonna get installed back with th350.
All the suspension dismantled for powder and complete rebuild with caster mod disc conversion and drop spindles |
04-26-2024, 04:05 PM | #4779 | |
Cost me $450 but it was worth it. Mine got a deep dent when I got T-Boned on the way to the union picnic two years ago. I had a core differential rebuilt, and replaced the trailing arms, but missed the ding in the shaft. The truck would vibrate excessively above 60 MPH. Now it runs smooth. Still have to see if the frame needs straightening, or its only out of alignment. Overnight? My guy took about 4 weeks. But he's a one man band, and said his alignment computer burned its chip.
04-28-2024, 08:04 AM | #4780 | |
4 weeks is a bit of a wait, I see some of the online builders will get one out in a few days after you send your measurements. I figured a week for mine, had to have him repeat it when he said I could have it in the morning.
04-28-2024, 02:28 PM | #4781 |
You like your manifold rare or well done
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
04-28-2024, 05:10 PM | #4782 |
Well done.
When my Mom ordered a new range, I interceded before the appliance store boys could cart off the old Hotpoint. I set it up in the backyard. I had to tie in a 220 line and outlet so I could power it. I baked a new set of Hedman headers after airbrushing on some black ceramic coat from Eastwood. Two hours at 500*. Came out pretty good. Then I mummy-wrapped the headers with 2'' fiberglass wrap. I had shot the stuff inside as well as out, so I thought it would hold up. Unfortunately, the wrap retained moisture, so one of the downtubes on the drivers side rusted out after only 7 years. [In Arizona.] Then I found out the hard way, Hedmans are lifetime guaranteed, but not if you use mummy wrap.
04-28-2024, 06:36 PM | #4783 | |
04-29-2024, 08:08 PM | #4784 | |
It looked cool. Underhood temperatures kept down. Exhaust tones were almost like a Cadillac's. And no one told me it caused corrosion. At least I thought I'd get a bye from the arid climate of Southern Arizona. [I have a set of Clifford headers on my 292 L6 that I have been running since 1978.] Also I thought shooting the insides would make it more corrosion proof. We live and learn...
04-30-2024, 08:46 AM | #4785 |
These came this morning . The free Summit shipping is great here most times if I order early the parts come the next day . Decided I didn’t like the original manifolds on the new engine .
05-01-2024, 11:32 AM | #4786 |
At the body shop.
Had some re pop M/T center cap stickers made up.
" That didnt make it any newer " " Dont antique the equipment " |
05-01-2024, 12:35 PM | #4787 |
Easiest header install I’ve ever done . One glitch the rear bolt on number 2 exhaust wouldn’t make the angle to go in . I heated the header and put a tiny dimple and it went right in . Headman offered to replace them under warranty but it was so minor I didn’t go that route . The headers fit perfectly .
05-01-2024, 03:58 PM | #4788 |
After my Hedman headers rusted out, I was careful to order the same part number for the replacement. However ''Progress'' had marched on -- and the Collector/Exhaust junctions were now a new Ball style. Not the 3 bolt sets that press a flat gasket. So I had to sawzall-off the ends and run 7 miles to Midas to get Ball ends welded on my exhaust pipes.
Then I found out a year later my local Hot Rod Shop could have gotten me the old school Hedmans if I bought them there. But I thought I was saving a buck at Jegs. Anyway, for the old school Collector/Exhaust gaskets, I found the thicker Copper ones were the best. Never burned out.
05-01-2024, 05:17 PM | #4789 | |
Who Changed This?
05-01-2024, 07:50 PM | #4790 | |
I was very impressed with the flange thickness and overall thickness of the headers . Took a bit of force to dimple the one tube even heated . Now I need to get some pipes for the exhaust
05-01-2024, 10:26 PM | #4791 | |
Who Changed This?
05-02-2024, 12:57 AM | #4792 | |
I expected more mojo out of Ceramic coating. Now that the '71 Jimmy's not my DD, I can run it on the siding and R+R the headers. Gonna paint them White with the cheapest Ace Hardware stove paint I could find, and reinstall them with fresh gaskets and re-attach the Dipstick tube to the side of the Block. I still have my Mom's old Hotpoint. Hoping the resident packrats have left some internal insulation... Bake Two hours at 500*.
05-02-2024, 01:28 AM | #4793 | |
At the body shop.
That hasn't been my experience. Tri Y on a 454 haven't touched them since 2017 when I bought the truck. And 4 -1 on a sbc been together since 2016 zero maintenance nor leaks. Dougs tags on both sets.
05-02-2024, 10:17 PM | #4794 | |
I also cut the metal bars between the ports because I read that would help to prevent any metal warpage from unsealing the ports. Must have done something right because I installed the headers around 1999 and they've sealed perfectly ever since. |
05-02-2024, 10:33 PM | #4795 |
Oh yea, it has kind of warmed up around here today so I waxed the truck.
Stuff still hasn't dried as of this writing. Thought I'd give the ladder a try to wax the roof and clean the windshield for some reason. That worked out OK. |
05-03-2024, 07:01 PM | #4796 | |
At the body shop.
I don't know..
05-03-2024, 08:41 PM | #4797 |
Removed the old exhaust setting it aside for the 68 that I’m putting the old motor in
05-03-2024, 11:42 PM | #4798 |
God I hope not, now that I've posted they'll probably start leaking. ...I got some spares standing by. Drove my '69 Nova from Mississippi to Washington one time and the engine started knocking! Every steep hill I climbed the knock got louder and I just knew a rod was coming out the side of the block at any moment! Made it home and discovered that some stupid header bolts had come loose. ETA: As a side note I've never had to re-tighten these header bolts, as a matter of fact, I never even checked them so the bolts are probably rusted in the heads by now...great. Heck I always thought they needed to be tightened again from time to time. Last edited by BRL; 05-04-2024 at 01:17 AM. |
05-04-2024, 05:37 PM | #4799 |
good day today went to a local show with this one and.....took best truck and then my friend Pat pictured helped me get this one out of my storage unit and back in my garage to see if I can finish by next May
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
05-05-2024, 09:56 AM | #4800 | |
The pulls they performed showed no measurable difference in performance. |
