Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > Heavy Haulers
Old 10-31-2021, 01:50 PM   #1
dill68
grill guard
anyone familiar with this grill[ATTACH]Name:  IMG_20211027_164851451_HDR.jpg
Size:  82.4 KB[/ATTACH] gaurd?
dill68 is offline   Reply With Quote
Old 09-19-2022, 04:42 PM   #2
Campbel45
Re: grill gaurd
No, but I want one! I've seen a few here and there
Campbel45 is offline   Reply With Quote
Old 09-20-2022, 08:05 AM   #3
Re: grill gaurd
It looks like a Luverne grille guard. They supplied GM with those through the Silver Book
Old 09-20-2022, 05:17 PM   #4
CarolinaHD
Moderator
CarolinaHD's Avatar
Re: grill gaurd
Glad you made this thread, I just saw one at auction a few weeks ago. Real clean
Alex
1967 C50 292ci Lumber truck
1967 C50 292ci Dump truck
1967 C60 366ci Fire truck
CarolinaHD is offline   Reply With Quote
Old 05-17-2024, 12:50 AM   #5
G-749
Junior Member
Re: grill gaurd
Thanks to all that replied. Interesting pics , I can't get the picture posting thing to work.
The guard on mine is different from the guards that are on the pics of the 2 trucks. So , 3 different trucks w guards , 3 different guards , none of them are exactly the same , the difference between them is th spacing between the vertical and horizontal slats that are welded in. I have a GMC master parts book and it only lists 5 different bumpers and only 1 set of hooks. I know I have aChevy C 50 , and the hooks have a part # 3895437 on them and they to tall . Does anyone have access to a Chevy truck model C 40 -C 60 master parts book. Would like to know if there are different hook part #s , so that I could look for correct part #s for my truck. Special k, could you look in that book that you have and see if that would have any information about this ? Again , Thanks to all who replied and sent pictures
Will continue to look for a set of hooks to fit my truck.
Good luck on your projects
G-749 is offline   Reply With Quote
Old 05-17-2024, 02:23 PM   #6
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: grill gaurd
The correct number is 3895347 group 7.068, and it shows 1967-72 40-60 series except tilt cabs
Later the number changed to 668590 and 2037943 and was used through 1988 on school bus chassis.
Here is a 2037943 hook:
1970 K/5 Blazer CST 4WD, Bronze, 93k ACT. miles, 350, 4 speed, positraction, 16.5" x 8.25" wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration in progress...
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 41k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 60k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 05-17-2024, 08:07 PM   #7
G-749
Junior Member
Re: grill gaurd
Thanks so much for the updated part.#s on the towhooks
In the GMC truck master parts book 4500 6500 series , that I have it gives 2 different parts #s for them, 3776012 , rh front ,.3776011 lh front . This info is in section
11.0660. Same section also lists gussets , spacers , and washers.
Will continue to look for set of hooks using the new information about tow hooks for my
truck . Thanks to all who replied ,hope that all of this information will help others.
Good luck to all on your projects!!!
Old 05-18-2024, 06:48 PM   #8
G-749
Junior Member
Re: grill gaurd
71 C 50 grill guard
Old 05-18-2024, 06:56 PM   #9
G-749
Junior Member
Re: grill gaurd
1st.picture attempt
Old 05-18-2024, 09:38 PM   #10
CarolinaHD
Moderator
CarolinaHD's Avatar
Re: grill gaurd
Flipped
Alex
Old 05-21-2024, 12:36 PM   #11
1970cstblazer
Exclamation Re: grill gaurd
The 3776011/3776012 numbers are for '61-'66 40-60 series except tilt.
Old 05-24-2024, 01:02 AM   #12
G-749
Junior Member
Re: grill guard
Thanks for clarifying my post,any thing that helps to try n have parts and what year trucks
that match is a good thing for those wanting to know . Now for the good news , new Northetn brand C 50 replacement radiator is in the truck
Will connect 4 hoses fill with water and crank her up. If it passes the new water pump /new radiator, new thermostat ,fan belt, plugs, wires, torqued every bolt I saw underhood ,we'll you get the picture,big day , driving on Memorial Day weekend.Woo Hoo I am stoked
Soon as I get the new rim$ n.tire$ , will post pics. Thanks to all who replied and for fixing my bad spelling and picture posting . Wish all a safe n happy Memorial Day weekend.
Good luck on all your projects!!!
