Old 02-15-2010, 02:03 PM   #226
protrash64
Resistance is Futile
protrash64's Avatar
Re: 1964 Suburban Pics
Here's where it sits now........
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-15-2010, 02:23 PM   #227
MacAttack
283 Drama Queen
MacAttack's Avatar
Digg'en the support strap across the tranny face, Jeff!
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 02-15-2010, 06:03 PM   #228
protrash64
protrash64's Avatar
...... yeah, just a piece of angle iron that I didnt have to cut. 1 less thing to do helps; I've opened up enough projects already.
Old 02-18-2010, 12:46 AM   #229
protrash64
protrash64's Avatar
Opened up a real can of worms and pulled out all the crap in the way and and I'm cleaning up and painting everything. I figured I mite as well as you dont get the chance very often......so this is where I am. Looks like the truck was gold originally.
Any body else find zinc-chromate under their paint?? I didnt know they used that stuff
Old 02-20-2010, 10:56 PM   #230
bird7263
Urban Chop Shop
bird7263's Avatar
Jeff, been a while since I poked in.. Lookin good bro!!!
2003 Chevy Trailblazer LTZ, 2.5" Susp Lift, Tinted, HID's/LED interior/ Lot of upgrades and little mods
1965 Chevy 1/2T Longbox, soon to be a slammed shop truck
Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=591266
Semper Fi Marines
bird7263 is offline   Reply With Quote
Old 02-25-2010, 01:34 AM   #231
protrash64
protrash64's Avatar
Everything cleaned up nicely. Rattled on some black and swung in the engine. I had to pull it back out as my mounts were 1/4'' too close together. No big deal, but it had to be done. Your mount holes should be 17'' apart. I was a little tite and just couldn't get it to drop in place. The second shot was a beauty and it dropped right in and had to do the usual screwing around to get the bolts thru the mounts....nothing major for only being told this should work and never having seen it done. My trans pulled forward about 1.25'' and the holes lined up perfectly in the frame.
Anyway, here are the pics..........
Old 02-25-2010, 01:35 AM   #232
protrash64
protrash64's Avatar
One more with some of the serp set-up going on.
Old 02-25-2010, 01:55 AM   #233
89muscletruck
89muscletruck's Avatar
Rock on!
Big blocks rule!
89muscletruck is offline   Reply With Quote
Old 02-25-2010, 01:58 AM   #234
Captainfab
60-66 Nut
Glad to see you have that 454 sitting in there. Everything looks real nice all painted.
Old 02-25-2010, 03:09 AM   #235
Joemomma1
Joemomma1's Avatar
Originally Posted by protrash64 View Post
Blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah blah.
Thats what I see, pics are numero uno.
Joemomma1 is offline   Reply With Quote
Old 02-25-2010, 08:57 AM   #236
jason65
Registerd User
jason65's Avatar
Looking good Jeff. I like it.
jason65 is offline   Reply With Quote
Old 02-25-2010, 11:10 AM   #237
Dinos63
chevy only
Dinos63's Avatar
Nice work kat!!! Very clean
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 02-25-2010, 11:22 AM   #238
protrash64
protrash64's Avatar
.....I'm adding the info 'cuz I see and read so much hearsay and 1/2 finished stuff that its hard to get good info on some projects. When I finish this it will have all the info about one method of swapping a BBC into one of these frames.
Old 02-27-2010, 01:50 AM   #239
protrash64
protrash64's Avatar
Have the serpentine set-up complete. A complete maze of metric and SAE bolts. Mocked up the engine just to see if everything was going to fit....like someone could actually run out of space under one of these hoods. The a/c compressor is just a heavy pulley right now; eventually it will get tossed.
Old 02-27-2010, 09:26 AM   #240
jason65
Registerd User
jason65's Avatar
Very nice. That thing should be running soon.
Old 03-06-2010, 09:14 PM   #241
protrash64
protrash64's Avatar
Few small updates....I've been bogged down in a bunch of small things to work out. Transferred my TV bracket to the quadrajet by measuring an Edelbrock and drilling the linkage. Made a throttle shaft and also had to use a 1'' spacer due to the low riser stock intake. I have only 3.75'' to the radiator so I went with electric fans. My intake had to be drilled and tapped for 3/8's NPT for a fan controller. The Sanderson cast exhaust headers have excellent clearance but cover the pipe plugs in the heads. Also had to go with a mini-starter.
...also my version of a spring stretcher as I've seen a few people put on here before. More soon as I believe I have everything covered now.
Old 03-11-2010, 01:33 AM   #242
protrash64
protrash64's Avatar
Made more progress. The thing is wired and the fuel is hooked up. Starter on and heater assembly went back in. I'm going to put everything in loom after I start it and I know its working correctly. Carb is ready and I'm working on the fans. Need to get hoses and put in my Milodon trans and oil dipsticks.
Old 03-11-2010, 10:06 AM   #243
daverod
SSN 706
daverod's Avatar
That thing will be running in no time.
daverod is offline   Reply With Quote
Old 03-11-2010, 06:10 PM   #244
protrash64
protrash64's Avatar
I certainly hope so!!! Wanna drive some before it gets too hot.
Old 03-12-2010, 01:03 AM   #245
protrash64
protrash64's Avatar
Fans are mounted and radiator is trial fitted.......need to get a couple things and it will be finished.
Old 03-12-2010, 01:10 AM   #246
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Saaaweet Progress.
Alan's Classic is offline   Reply With Quote
Old 03-12-2010, 02:51 AM   #247
Captainfab
60-66 Nut
Looking good Jeff....won't be long now.
Is that a battery disconnect next to the heater? Is it operable from inside?
Old 03-12-2010, 11:01 AM   #248
protrash64
protrash64's Avatar
Originally Posted by Alan's Classic View Post
Saaaweet Progress.
Thanks Alan; it's making me look forward to sanding on the p/u again.
Yes sir. It's up high behind the glove box. I also have a kill switch on the solenoid wire, just in case.
I wanted to take this to Goodguys but it's not happening. I could have thrown this thing in here and gotten it going but I decided I wanted to do things neatly so I didnt have anything to fix or work on later.
The hydroboost is going to be put off for awhile as I picked up a new-old 60's steering column that will be replacing the hacked up column in the truck. It needs bearings and a turn signal switch. It also came with the bracket to mount under the dash which will replace the Frankenstein creation under there now. Being that all of this stuff is together under the dash I thought those two projects would go well together allowing me access to the brake mechanism while the column is out.
Old 03-12-2010, 11:14 AM   #249
DPowers
DPowers's Avatar
looking great
DPowers is offline   Reply With Quote
Old 03-14-2010, 02:42 AM   #250
Joemomma1
Joemomma1's Avatar
Care to elaborate on the tv bracket on the quadrajet? I didnt think it would be easy, you make it look like its just a matter of drilling holes. That can save me the money I was gonna spend on a new carb.
