Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 02-01-2014, 01:06 AM   #226
Captainfab
60-66 Nut
Re: Power Brake Booster Adapter Bracket
What booster and master depends on what braking system you have. Is it drum/drum or disc/drum or disc/disc? There is a short list of compatable boosters in post#1 and a more complete list in post #183 on page 8.
I'll send you a PM with purchase details.
Originally Posted by BSB1965 View Post
Hi, I'm a new member to the forum. I have a 1965 chevy truck that is mostly stock but I would like to make some upgrades. I have seen your Power Brake Booster Adapter Bracket and would be interested in purchasing one. How would I go about buying one and what booster master cylinder combination would you recommend? Thanks!
Old 02-18-2014, 12:01 AM   #227
ogsRULE
ogsRULE's Avatar
Hey,
I just put up a post on a problem I am having mounting my booster to the firewall. Looks like this will solve that pronto. Please take a look and let me know if it is the fix.
http://67-72chevytrucks.com/vboard/s...d.php?t=617091
Thanks,
Scottie
ogsRULE is offline   Reply With Quote
Old 02-18-2014, 12:25 AM   #228
Captainfab
60-66 Nut
I posted a reply in your thread.
Old 03-09-2014, 01:07 PM   #229
nhr3
nhr3's Avatar
i am working on my 65 C10 and having difficulty with CPP Brake Booster install. I think your bracket will help. I sent you a PM detailing the issue and posted pictures on my build page
http://www.67-72chevytrucks.com/vboa...70#post6565870
Sure hope you can help. NHR3
nhr3 is offline   Reply With Quote
Old 03-09-2014, 02:07 PM   #230
Captainfab
60-66 Nut
PM's replied to......
Old 03-13-2014, 03:22 PM   #231
TypeSL2
Originally Posted by Captainfab View Post
Here is a fellow member's ingenious way to connect a new brake booster to your brake pedal.
http://www.67-72chevytrucks.com/vboa...&postcount=324
This link is awesome!! I am definitely going to be going this route once I get my bracket and disc swap parts all collected. I hate having to lift my leg up off of the seat to push the brake pedal. PM sent on the bracket for use with an NV3500.
James
TypeSL2 is offline   Reply With Quote
Old 03-13-2014, 11:32 PM   #232
Captainfab
60-66 Nut
PM replied to
James
Old 03-14-2014, 11:16 PM   #233
BSB1965
I finally have my power brakes installed. I went with the power brake booster from a 90 Astro Van P/N 54-71220 and the Master Cylinder from a 70 Buick Estate Wagon P/N 13-1063. Captainfab bracket was great (just as advertised)! I've attached a picture for reference. I do have a question though. My brake pedal doesn't seem to engage until it's near the floor, is this normal? I would have expected it to engage sooner.
BSB1965 is offline   Reply With Quote
Old 03-15-2014, 12:26 AM   #234
Captainfab
60-66 Nut
Thanks for posting a pic of your installation.....looks good.
As for your low pedal, there are a couple things to try. One is to adjust your pedal to booster pushrod a little longer. Another is to verify that the master cylinder you got does actually have the shallow bore in the back of the piston.
Old 03-26-2014, 09:08 AM   #235
64LBSS
Mock up pics of the booster bracket, booster, and master cylinder in the dropbox link below. I will be pulling everything back apart for paint and will get some more finish pics then. This is a GREAT piece that is a perfect fit for the truck.
Small install hint, sometimes, the pedal assembly is torqued up and the holes do not properly align with the firewall holes. Loosen the pedal assembly from the column mount under the dash and it will allow you to move those into the correct position for the 4 bolts to line up.
https://www.dropbox.com/sh/dy8a02owqa3eman/FsTHFDycSK
64LBSS is offline   Reply With Quote
Old 03-26-2014, 11:18 PM   #236
Captainfab
60-66 Nut
Thanks for the link to the pics and the compliment
What booster and master are you using?
Old 03-27-2014, 06:46 AM   #237
64LBSS
That's an OEM 71 booster and master cylinder from Oreilly
Old 04-06-2014, 12:14 AM   #238
Captainfab
60-66 Nut
I have 2 of these '63-'66 booster brackets that I had zinc plated. The price is the same as the powder coated version which is $61.50 plus $11.65 for shipping.
Old 04-30-2014, 10:28 PM   #239
MudBug
MudBug's Avatar
Do you still have the zinc coated brackets? If not do you still have any brackets for 63-66.
MudBug is offline   Reply With Quote
Old 04-30-2014, 11:39 PM   #240
Captainfab
60-66 Nut
Yes I do have one zinc plated booster bracket left.
The parts that I make are not a limited run of parts, they are always available. I make them on a one going basis. Although the zinc plated booster brackets don't seem to be a big seller, so I may not have any more done.
Old 05-01-2014, 08:22 AM   #241
MudBug
MudBug's Avatar
I'll take it. How and how much for it.
Old 05-01-2014, 11:15 PM   #242
Captainfab
60-66 Nut
I'll send you a PM with payment details.
Old 05-07-2014, 11:21 PM   #243
Captainfab
60-66 Nut
The zinc plated booster brackets are both sold.
Old 05-18-2014, 12:56 PM   #244
grs
Originally Posted by Caudillo64 View Post
I just insalled mine easy bolt up no problems also looks good. Thanks.
Where did you buy the booster, master, and proportion valve?
grs is offline   Reply With Quote
Old 05-19-2014, 12:11 AM   #245
Captainfab
60-66 Nut
You might try sending him a PM, but to me it looks like one of the typical aftermarket booster master and prop. valve combo's available from ECE, POL, CPP, etc.
Old 06-05-2014, 07:03 PM   #246
USMilitary
Need a bracket from ya. PM sent.
USMilitary is offline   Reply With Quote
Old 06-05-2014, 11:13 PM   #247
Captainfab
60-66 Nut
PM replied to
Old 07-06-2014, 03:21 PM   #248
my5chev
Hey Capt, I'm needing a booster bracket for a 65 lwb fleet.
my5chev is offline   Reply With Quote
Old 07-07-2014, 12:43 AM   #249
Captainfab
60-66 Nut
I replied to your PM
Old 07-07-2014, 07:43 PM   #250
my5chev
Payment sent...
