Old 05-04-2012, 10:24 AM   #226
67cheby
67cheby
67cheby's Avatar
Re: Project: Turbo 250
hey a guy on facebook was talking to me yesterday about some performance parts he has for an inline six, send me your email and i will forward his emails to you
67cheby is offline   Reply With Quote
Old 05-07-2012, 12:50 AM   #227
slick copper
slick copper's Avatar
Hey man. Hadn't been on in a while. Hate to see that about your bed. Yeah my truck came from TX and had some dents and scuffs on it. How the heck does that stuff happen? Some careless dumba$$ that don't give a crap 'cause it isn't their stuff.
What about those pulleys though? They fit? I want some dressup for my engine too, what pulleys would I need with 2 belts, no AC?
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 05-07-2012, 07:36 AM   #228
longbed67
longbed67's Avatar
This is where the kicker comes in... I have measured and have only got to play with it a little but lining up the water pump, power steering, and alternator dont seem to be an issue... but getting the dang crank pulley lined up seems to be the issue.... with you having the stock damper shouldnt be an isssue... When I get done with final exams this week, I will have time to play with all of it more, ultimately I am at war in my mind over whether to keep the SBC SFI spec 18.1 harmonic balancer and build new brackets or to ditch it turn down my rpm to max out at 5900 and put a stock one on from dorman and call it a day.
Adam
My 1967 C10 - Turbo 250 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=485843
(608) 214-8706
longbed67 is offline   Reply With Quote
Old 05-07-2012, 07:10 PM   #229
longbed67
longbed67's Avatar
Well got my new P-trim .68 tangential turbine housing in yesterday afternoon and well guess what it doesnt clear the motor mount/frame rail and so now I have to figure out whether to try and scour the nation to find a .69 a/r on center housing and then shell the cash out for it, or try and fabricate a mount to clear the frame and maybe have oil draining issues.... with the drain line at a 40* angle.... HP never comes easy or cheap grrrr.....
Adam
(608) 214-8706
Old 05-16-2012, 08:38 PM   #230
longbed67
longbed67's Avatar
Alright long time no update... but look what came in the mail today still waiting for my porterbuilt package to come!
Adam
(608) 214-8706
Old 05-16-2012, 08:39 PM   #231
longbed67
longbed67's Avatar
Ended up buying the MSD HEI from him with the external coil so that it is easier with my a/c setup and the billet side covers.
Adam
(608) 214-8706
Old 05-16-2012, 10:39 PM   #232
67cheby
67cheby
67cheby's Avatar
Sweet !
Old 05-17-2012, 12:28 AM   #233
Captainfab
60-66 Nut
Any update on your new bed the shipping company smashed up?
A couple weeks ago, one of my customers had a shipment damaged by a shipping company. The receivers of the shipment were refusing to pay my customer until the damage was repaired. That is a payment of over $100,000 that is being held up because of idiots that work for that shipping company. And consequently I can not get paid yet either
Old 05-17-2012, 06:34 AM   #234
longbed67
longbed67's Avatar
Paperwork has been filed... haven't heard anything yet! I will be making some phone calls here today yet. I really need to start getting some of the body work done on it and use it to line up my fuel cell and the hitch's so I can get it back together sooner than later.
Adam
(608) 214-8706
Old 05-18-2012, 01:10 AM   #235
Captainfab
60-66 Nut
Good luck with your claim, hopefully they make it right.
Old 05-18-2012, 01:44 AM   #236
DA INFERNO
DA INFERNO's Avatar
Very Nice!
1964 CHEVY LB, 20" WHEELS, BAGGED
DA INFERNO is offline   Reply With Quote
Old 05-18-2012, 08:52 PM   #237
longbed67
longbed67's Avatar
Thanks Inferno!
Adam
(608) 214-8706
Old 05-19-2012, 10:54 PM   #238
longbed67
longbed67's Avatar
Well got a little work done today... I volunteered to build sail boats for the National Mississippi River Museum for the kids coming up in a few weeks and got 100 of them built... then got my motorcycle fender all stripped down to metal and got it primed as you can see in the second pic. and finally got a little work done on the truck.
Got the power steering mocked and the A/C mocked. Turns out i will have to cut the bracket on the power steering and weld in a chunk to fit around the manifold. And the billet pulley I chucked up in the lathe and cut off the back pulley as it was for a SBC and the front pulley is the exact same dimension as the L6 power steering pulley.
Mocked up A/C bracket turns out it wont work with either HEI distributor that I have... So i am going to find out if Malloy's Electronic Pickup ignition for the Points distributer will work with a digital 6 plus MSD box. If it does looks like I will be going that route. If not I will be mocking modifying the bracket to raise it ~2.5" to clear my MSD HEI distributor.
Adam
(608) 214-8706
Old 05-19-2012, 10:55 PM   #239
longbed67
longbed67's Avatar
heres the pics
Adam
(608) 214-8706
Old 05-19-2012, 10:59 PM   #240
67cheby
67cheby
67cheby's Avatar
Wow, looking great !
Old 05-20-2012, 08:11 AM   #241
kyull67
kyull67's Avatar
Looks great! I'm at about the same point as you in my build. Stuck on fuel pump though. Just read you are doing a stock '84 fuel pump, just boost reference the bottom from after the intercooler?
kyull67 is offline   Reply With Quote
Old 05-20-2012, 10:02 AM   #242
longbed67
longbed67's Avatar
You will want to run the boost reference from the carb hat... this way it is most closely representative of the pressure that the fuel bowls are seeing that way with the 1:1 ratio your base pressure remains 6-8psi (on the 1984 stock pump or 4-6psi with all other years) plus the boost pressure. If you plan on running a 4bbl carb you need the '84 pump as base operating pressure with those carbs is 6psi. I am not sure how much boost you plan on running but this setup is only good for about 10lbs which is a 1.68 multiplier times your base n/a hp to get your calculated hp under this load if its not enough you will need to get an electric setup like a aeromotive boost referenced ($$$$$$) as most standard electric pumps will burn up being used as boost referenced pumps.
Adam
(608) 214-8706
Old 05-20-2012, 03:10 PM   #243
kyle87
got any close picturesd of the power steering brackets? i switch for an intagrated head to non and trying to figure out what i need. thanks
kyle87 is offline   Reply With Quote
Old 05-21-2012, 09:47 AM   #244
kyull67
kyull67's Avatar
thanks!
Old 05-21-2012, 10:04 AM   #245
kyull67
kyull67's Avatar
Do you know the part number for the clifford manifold to holley 4bl carb adapter?
Old 05-21-2012, 06:41 PM   #246
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
I love the build. Too bad about the bed, at least you aren't at the point where that's all you're waiting on for it to be "finished". I hope everything works out.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
Old 05-21-2012, 07:40 PM   #247
longbed67
longbed67's Avatar
Actually I am at the point where I need it so I can get finished! I need it to be able to line everything up for my gooseneck hitch and fuel tank! And the stickler is I cant even put it on to take measurements because its still bolted to the crate and if they need to inspect it, it has to be on the original crate.
Adam
(608) 214-8706
Old 05-21-2012, 07:50 PM   #248
longbed67
longbed67's Avatar
Heres the link to it!
http://www.cliffordperformance.net/M...Category_Code=
Adam
(608) 214-8706
Old 05-21-2012, 07:56 PM   #249
longbed67
longbed67's Avatar
Here ya go! This pump is for a 1968 Camaro inline 250. I like it better because the resivor is integrated. The brackets came off of a 1976 nova.
Adam
(608) 214-8706
Old 05-21-2012, 08:58 PM   #250
stealthy '69
'69 Chevy SWB
Well then that REALLY sucks. I hope it all gets fixed up soon. I can't wait to see it finished and running.
Matt
