Closed Thread
Old 11-14-2011, 05:23 PM   #226
FFredo
Re: What Did You Do With Your Truck Today ?
Good to meet you too Bshort. Hope the rain didn't ruin your San Diego trip too much.
FFredo is offline
Old 11-15-2011, 07:17 PM   #227
handyhands
OK hear my pictures.It took us two hours to load it on the trailer, but only thirty minutes to unload.Name:  100_2325.jpg
handyhands is offline
Old 11-15-2011, 07:18 PM   #228
BShort
Nope, we brought umbrellas. Spent a couple hours in Seaport Village then headed home.
BShort is offline
Old 11-15-2011, 09:05 PM   #229
mknittle
mknittle's Avatar
Originally Posted by Daze57 View Post
police here hate blue dots !
they dont mess with the old cars much here. the local PD has a 1950 some ford police car that shows up now and then at cruze nite
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline
Old 11-15-2011, 11:56 PM   #230
AD51
AD51's Avatar
Thumbs up Re: What Did You Do With Your Truck Today ?
I checked to see if my two front cab mounts were level...
AD51 is offline
Old 11-16-2011, 03:47 AM   #231
Daze57
Daze57's Avatar
i wish the police force here would use older cars or trucks - maybe we would have a chance _lol
Daze57 is offline
Old 11-16-2011, 03:48 AM   #232
Daze57
Daze57's Avatar
AD 51
nice lookin weld work on subframe
Daze57 is offline
Old 11-17-2011, 01:18 AM   #233
55metalmonkey
just fit my bumper after days and days of massaging it to fit properly, passesnger side was hit fairly hard at some point and poorly fixed with Bondo and shimmed with washers. had to heat, beat, and use a 25 ton press to get it even close to straight. I still have to de chrome the 2 upper replacement bumperettes but getting close to finishing the rough metalwork on the body. I just have the hood and the 2 inner fenders to do then I get to move onto the finishing touches on the engine and start roughing out the interior.
55metalmonkey is offline
Old 11-17-2011, 01:23 PM   #234
Daze57
Daze57's Avatar
that front end looks very cool - nice work on gettin' it straightin; out
Daze57 is offline
Old 11-17-2011, 01:45 PM   #235
55metalmonkey
thanks, Took a while but it`s much better than how the last guy fixed it...1inch thick coat of bondo.
Old 11-17-2011, 01:47 PM   #236
Daze57
Daze57's Avatar
have you had any hood fitting issues?
Daze57 is offline
Old 11-17-2011, 02:05 PM   #237
55metalmonkey
no... not yet anyway.
the front end sheetmetal is just hanging loosely by a few bolts. I did have the gaps a little too tight in some spots so I have to shim a bit for spaceing since it only has a thin coat of primer vs a few coats of paint, I figued it out that the overall final paint thickness for all the surfaces combined (side to side) will affect the gaps by close to 3/16" overall so I'm trying to compensate for that a bit. the truck is going to be 90% disassembled when it goes for paint so I didn't want to do any final fitting until then. I do have to pull the hood still to fix 2 rust spots and trim the inner edge by the rad for a bit of extra clearance.
Old 11-17-2011, 02:07 PM   #238
Daze57
Daze57's Avatar
still ......... looks good !
Daze57 is offline
Old 11-17-2011, 03:30 PM   #239
Purec4
Purec4's Avatar
Finished up the new floor and kickpanels, got them covered with bedliner and undercoating. Also fiberglassed in some minor rust in the floor pan under the seat and door wells. read to clean up the dash and paint. Next is the doors! .... Killing time waiting on a buyer...
We lust for what we want, weep for what we need...
Purec4 is offline
Old 11-17-2011, 07:29 PM   #240
mknittle
mknittle's Avatar
I worked on my rear suspension crossmember and cut out and tacked the brackets for the lower control arms. I have to do a mock up on the frame then break down the brackets so I can bend the top to match the curve in the frame.
Mark
My GMC build.
mknittle is offline
Old 11-17-2011, 11:18 PM   #241
AD51
AD51's Avatar
Daze 57
Thanks, I have an 02 Ext cab frame, cut out 5" and put it back together and plated the outside just to make myself feel better.
AD51 is offline
Old 11-18-2011, 01:04 AM   #242
55metalmonkey
Old 11-18-2011, 06:44 PM   #243
1959 Apache 3600
1959 Apache 3600's Avatar
Today I got the bench seat out of the cab and took off the passenger door. I know it's not anything major, but baby steps is about the best I can do with the limited time I have to play...
1959 Apache 3600 is offline
Old 11-18-2011, 07:24 PM   #244
Rude Dude
Rude Dude's Avatar
Painted valve covers and air cleaner see my build.
Rude Dude is offline
Old 11-18-2011, 08:02 PM   #245
Atommik
Atommik's Avatar
Well, this week started on the right door rust and dent repairs. Soaked bottom of door over the weekend in phosphoric acid...worked pretty good. revealed more rust than I thought ( I should know there's always more than you think). Made a patch for the inner and started on the outer patch ( Half done).
Atommik is offline
Old 11-18-2011, 08:06 PM   #246
Atommik
Atommik's Avatar
A couple of rust repair pics.
Atommik is offline
Old 11-18-2011, 08:09 PM   #247
Atommik
Atommik's Avatar
Inner patched, and outer half done.
Atommik is offline
Old 11-18-2011, 08:10 PM   #248
Rude Dude
Rude Dude's Avatar
Nice work !
Old 11-18-2011, 08:15 PM   #249
Atommik
Atommik's Avatar
Thanks, I really enjoy the metal fabrication...more than pounding out dents and doing the straightening!!
Atommik is offline
Old 11-18-2011, 08:32 PM   #250
OrrieG
OrrieG's Avatar
Painted small bits. This is all I could find to paint so I must be getting close??
OrrieG is offline
Closed Thread
