Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 03-04-2012, 11:56 AM   #226
mcbassin
Still Learning
mcbassin's Avatar
Re: Crash's 72 K10
Nice work as always! You're on the home stretch now
mcbassin is offline   Reply With Quote
Old 03-04-2012, 10:23 PM   #227
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Originally Posted by mjensen View Post
You're work is looking very good! Much better than mine
Thanks mjensen.. not sure how good it looks.. I am happy with it… I am sure yours will be fine as well..Good luck with your build.
Originally Posted by 67c10rustbuket View Post
Excellent progress man!
Thanks 67c10rustbucket, still lots of work to do…
Thanks Mike.. still a long way from being on the home stretch… but better today than yesterday.
Mark
Crash's 69 4x4 SWB
Crash's Roof over Lake Home
Crash's 1988 Land Cruiser Build
Crash_OK is offline   Reply With Quote
Old 03-04-2012, 10:24 PM   #228
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Didn’t do a whole lot today.. cleaned up the shop and started fitting the rocker and cab corner.
Next week I hope to start cutting out the rust above the windshield.
Still need to cut out and install the high hump.
Removed the u-joints and indexed the drive shafts.
Still lots of work to do on the rust… Lots of grinding and sanding still to be done.
Mark
Crash's 69 4x4 SWB
Old 03-05-2012, 11:55 AM   #229
Bus flyer
Re: Crash's 72 K10
wow its looking great
Bus flyer is offline   Reply With Quote
Old 03-07-2012, 07:20 PM   #230
BeefyJoeDirt
BeefyJoeDirt's Avatar
Re: Crash's 72 K10
The bolts that hold the high hump in, how are they mounted? do they have a nut or are they just screws that stick through to the under side? Sorry I have no 4x4 to reference for my build. Started with a 2wd and got a 4x4 long bed frame cut down to a short frame, so I am kinda building blind!
BeefyJoeDirt is offline   Reply With Quote
Old 03-07-2012, 10:00 PM   #231
tsnow678
Re: Crash's 72 K10
It looks as if he plug welded it in.
Link to my 69 Camaro 6.0/T56 swap:
http://ls1tech.com/forums/conversion...69-camaro.html
tsnow678 is offline   Reply With Quote
Old 03-07-2012, 11:27 PM   #232
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
I have not mounted it yet, but on the old cab it was mounted with bolts from the top and nuts on the bottom. The nuts on the bottom where all connected together with a thin metal strip and then the strip was spot welded to the bottom of the cab. I am n not sure how I will mount it to the new cab. I was thinking of welding the nuts to the cab.
Mark
Crash's 69 4x4 SWB
Old 03-07-2012, 11:35 PM   #233
Lower
Lower's Avatar
Re: Crash's 72 K10
Rivot nuts work well for things like that
~Jon
Ol Green 1970 K10ish LWB,454/400/205, been in family since new.
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=516056
Lower is offline   Reply With Quote
Old 03-07-2012, 11:36 PM   #234
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks... I will look into them...
Mark
Crash's 69 4x4 SWB
Old 03-08-2012, 12:43 PM   #235
BeefyJoeDirt
Re: Crash's 72 K10
Mark,
Where did you get the fuel hose that connects to your filter/regulator? A part number would be great if its not to much trouble...
Old 03-08-2012, 01:10 PM   #236
Bus flyer
Re: Crash's 72 K10
Lower thats a great! Idea we use them all the time in aviation and really will give it a cleaner look.
Old 03-08-2012, 04:54 PM   #237
BeefyJoeDirt
Re: Crash's 72 K10
Mark,
Sorry for the dumb question...after closer inspection of your awsome pictures I relized you used a quick adapter and hose clamped the fuel line to them. I know it was months ago but still....GREAT JOB!! It looks so clean and wicked
Jason
Old 03-08-2012, 11:49 PM   #238
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Mark,
I got it at o'reillys. I don't have a part number.. I asked for high pressure fuel injection fuel hose. I used regular fuel hose on the suction side of the pump.
Hope this helps.
Mark
Crash's 69 4x4 SWB
Old 03-08-2012, 11:51 PM   #239
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks.. I got those pieces at o'reillys as well.
Mark
Crash's 69 4x4 SWB
Old 03-09-2012, 12:05 AM   #240
pcorriveau951
pcorriveau951's Avatar
Re: Crash's 72 K10
what size tire do u currently have on your truck?
pcorriveau951 is offline   Reply With Quote
Old 03-09-2012, 06:17 AM   #241
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
35x12.50x15.. I would like to go to a larger rim, and a little smaller tire.. so these will soon be for sale..
Mark
Crash's 69 4x4 SWB
Old 03-09-2012, 10:47 PM   #242
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
I had a few hours to work on the cab today. Started off by drilling and bolting the front pillar to the cab support.
Then I trimmed and welded the cab corner. Still need to clean up the welds..
Moved from there to a another rust spot.. I cut out a patch from the other cab. I still have some grinding and sanding to do.. but it is close. The metal is not blackened… it is just a weird reflection from the flash.
As far as I know the only rust left is shown below.. None of it looks easy to do..
Tomorrow I may work on the u-joints, or continue on the rust..
Mark
Crash's 69 4x4 SWB
Old 03-11-2012, 09:14 AM   #243
RCbowtie69
RCbowtie69's Avatar
Re: Crash's 72 K10
I'll say that's some nice repair work on your cab,your progress on the rust repair is moving right along.Keep the pictures coming & keep on trucking.
My Truck: 2.5 drop front, 4 & 5/8 in rear, 350cubic in. been bored .60 over, 700r4 (soon), 3 speed (on tree for now).rims & tires size,15x8 ralleys 5 on 5,P275/60R15.
Members I have met: Pickupman, 1972 Super Cheyenne, Stepside,Chis Mc Bride. tsnow67,joel.e,
RCbowtie69 is offline   Reply With Quote
Old 03-11-2012, 10:50 AM   #244
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks RCbowtie... It seems like it is taking forever... But I will get it done someday if I stay at it..
Mark
Crash's 69 4x4 SWB
Old 03-11-2012, 10:51 AM   #245
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Work a little on the cab yesterday. Started by working on the rust above the windshield. Tilted the cab forward so that I would not have to work above my head
I did not take a picture, but I painted everything I could reach with por15 before I welded the patch in. I cut the patch from the old cab.
Then I moved to the rust on the outside above the windshield. It turned out really nice.
It was an awesome day.. I should have went fishing..
Then I stared on the rust under the dash of the cab.. I will finish it next weekend..
Hopefully next week I can start on filling in the holes in the firewall.
It does look at lot better than it did before I started.. but there is still a lot of work to do..
I need to figure out how to fix this? I think I can cut out a patch from the old cab and fit it. We will see.
I still need to patch the high hump and get it mounted.
I need to sell or haul the old bumpers to the off. The front bumper is heavy, it would make a great bumper for a offroad truck.. the rear bumper is nice I think it fits a 73 and up chevy.
I need to get the rear parking brake cables from somewhere. Does anyone have any ideas on a place to get some?
Mark
Crash's 69 4x4 SWB
Old 03-11-2012, 11:20 AM   #246
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: Crash's 72 K10
I got my e-brake cables from rockauto.com.
Been reading theis build overthe past few days and just got caught up. Well done. You made the LS swap look easy. One mistake I made when I did my door bottoms was that I did not measure top to bottom first and I ended up having them tight for clearance to to bottom in the cab opening. The rocker postion should be checked for up and down position compared to the door also. I'm just getting started with the rockers on my Jimmy.
hgs_notes is offline   Reply With Quote
Old 03-11-2012, 11:22 AM   #247
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks, I will try rockauto.. Yes I measured the opening before I removed the old rockers, and I will install the doors before I weld the rockers in. Thanks for the tips.. good luck with your build...
Mark
Crash's 69 4x4 SWB
Old 03-11-2012, 05:36 PM   #248
mcbassin
Still Learning
mcbassin's Avatar
Re: Crash's 72 K10
Very nice work on the cab Mark! you have sure came a long ways in a short period of time. I like the repair around the windshield, inside and out. Keep pounding, you're just about there.
Old 03-11-2012, 05:42 PM   #249
Crash_OK
Crash_OK's Avatar
Re: Crash's 72 K10
Thanks Mike.. I still have a lot to do to the cab. I am thinking about doing the firewall like you did. I know it will take me a lot longer to do it then it did you, but I love the way yours looks.. Hopefully I can take some time off during spring break and get some of it done. Hope you got a lot done on yours today..
Mark
Crash's 69 4x4 SWB
Old 03-12-2012, 01:30 PM   #250
BeefyJoeDirt
Re: Crash's 72 K10
I am having a pain fitting my cab corners. They dont line up well and the curve of the corner is to large. I have been trying to flex it and work it into the right shape but with no luck. I am beyond frusterated. It seems most of the panels that I have got from lmc truck are not fitting very well. The innner rockers and front pillar needed quite a bit of influence with body tools to make them fit. Where did you get your cab corners from?
Jason
