Old 03-24-2016, 11:56 PM   #226
XwalkerX
Re: LS factory cruise control hook up
yes it drops to 0v when pedal is pressed
and if i unplug the connector from the cruise module that faint hint of brake light disappears
XwalkerX is offline   Reply With Quote
Old 03-25-2016, 12:12 AM   #227
ls1nova71
ls1nova71's Avatar
I have to leave for work now, but will check in the morning to see if mine glow any at all, but don't think they do. I'm leaning towards something being messed up in the module since the wiring seems to be correct and unplugging it makes it go away. I'll let you know what I find in the morning.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-25-2016, 12:14 AM   #228
XwalkerX
thanks man!
Old 03-25-2016, 03:11 PM   #229
XwalkerX
so a friend of mine gave me the idea of running a diode off the g wire to the junction at the brake light wire.
http://frys.com/product/1799257?site...H:MAIN_RSLT_PG
this would essentially make that 9/10v stay only on the G wire and not impact the brake light wire. this way the faint brake light illumination would stop but when I press the brake pedal and it sends 12v to the brake lights it would also send 12v to the G wire back to the cruise module.
so that I think would solve the brake light issue but still doesn't help figure out why the cruise control wont work
Old 03-25-2016, 09:05 PM   #230
ls1nova71
ls1nova71's Avatar
I checked my cars today and the brake lights do not glow at all, but yet I still get that 9v on that wire. Its really strange. After all the tests you have done and seeing that it appears to be wired right, I think I wuld try another module. If you dont have a junk yard near you I can probably find one but not sure what it would cost to ship it.
Old 03-26-2016, 02:08 AM   #231
XwalkerX
ill try and source out another module this weekend/next week and in the meantime ill have to draw an electrical diagram of how i have everything currently hooked up just to be 100% positive its correct
Old 03-26-2016, 08:50 AM   #232
solidaxel
solidaxel's Avatar
Did you tell us your tail lights were LED ?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-26-2016, 11:30 AM   #233
ls1nova71
ls1nova71's Avatar
Yeah, post up a diagram of the wiring so we can make sure it's absolutely right, and if it is I would try another module. If you can't find one just let me know and I know I can get one. I could also slap it on my truck and test it just to be sure.
He said no LEDs.
Old 03-27-2016, 02:35 PM   #234
Andy4639
Old member
Andy4639's Avatar
Question Re: LS factory cruise control hook up
I have 2 questions on this.
1. I have all LED's but with the relay mod it should be fine correct?
I also have the grounded flashers in place will this possibly make it work?
2. I don't have speedometer cable, mine is a GPS speedometer. Their is no cable attached to the trans at all. Will I need the cable to be hooked up?
I want and try to have cruise for the 2016 HRPT since I didn't have it for the 2014 run.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-27-2016, 06:43 PM   #235
Andy4639
Old member
Andy4639's Avatar
Wink Re: LS factory cruise control hook up
Found a 4 wire replacement handle.
$44.99. I think a junkyard will be a lot cheaper!
http://www.classicindustries.com/pro.../dd100102.html
Old 03-27-2016, 10:03 PM   #236
doublebeetx
ls1nova71, will the stalk listed by Andy work for my dbw cruise ? Thanks !
doublebeetx is offline   Reply With Quote
Old 03-28-2016, 12:49 AM   #237
ls1nova71
ls1nova71's Avatar
1 I'm not familiar with the relay mod? How is it wired?
2 You won't need a speedo cable, just a VSS wire coming out of the PCM.
3 That switch will work, but it will require several relays to reverse the switches inside of it.
Old 03-28-2016, 12:50 AM   #238
ls1nova71
ls1nova71's Avatar
It will, but there are several relays required to change the normally closed switches inside of it to normally open like a GM switch.
Old 03-28-2016, 07:14 AM   #239
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: LS factory cruise control hook up
I was talking about the relay posted earlier in this thread. On the ground wire.
Old 03-28-2016, 11:01 AM   #240
XwalkerX
So here is my crude wiring diagram
Hopefully we can figure this out. It would make my weekly 250 mile round trip drive a lot nicer.
Old 03-28-2016, 11:17 AM   #241
XwalkerX
with the key on and taking readings at the module with the connector plugged into it im getting these readings
a- 0v (toggle switch is in the off position)
b- 0v
c- 0v
d- 12v
e- 0v
f- 12v
g- 10v
h- n/a
j- 0v
k- 9v
also I forgot to include that I have an inline fuse wired in to the power wire right before the bottom split on my diagram
I also picked up a 12v zenner diode this weekend that I have yet to wire into the G wire to get rid of that voltage going to the brake lights until the pedal is pressed.
Old 03-28-2016, 08:59 PM   #242
XwalkerX
so just wired in the zener diode to the G wire so my brake lights are not affected by the 10v being sent from the cruise unit.
just re-tested to confirm everything is in complete working order
key on, engine running, connector unplugged to test leads:
A- off position - 0v
A- on position - 12v
B- (with A still "on") 0v resting; 12v momentary toggle down pressed
C- (with A still "on") 0v resting; 12v momentary toggle up pressed
D- 12v resting; 0v brake pedal pressed
E- 0v (ground)
F- 12v regardless of toggle A position
G- 12v brake pedal pressed
H- n/a
J- n/a
K- 11.6v
Old 03-29-2016, 12:02 AM   #243
ls1nova71
ls1nova71's Avatar
Everything on your diagram looks to be right. Have you tested it with the diode installed? The only thing that looks odd on your diagram, and I don't think it would affect anything, is your brake lights appear to be wired on a key on hot wire rather than a constant hot. I assume you are using an aftermarket harness and wired it this way?
Old 03-29-2016, 12:07 AM   #244
ls1nova71
ls1nova71's Avatar
If you are talking about the relay diagram in post #7, then it should work, although I have never personally tried it.
Old 03-29-2016, 12:11 AM   #245
XwalkerX
thats actually just me trying to simplify the schematic.
they are in fact wired to the proper fused brake light position and i get brake lights with key off too.
sorry about the confusion.
so if everything is wired correctly then i can only assume its the box itself?
i call the local LKQ and they didnt have any 99-02 silverados available so ill keep calling around tomorrow.
does the yard local to you have one readily available?
Old 03-29-2016, 12:17 AM   #246
ls1nova71
ls1nova71's Avatar
There are 6 pick a part type yards with in a half hour of me, and they almost always have some 99-02 trucks in them and the cruise modules are almost never taken off, so I'm pretty confident I could find one.
Old 03-29-2016, 05:53 AM   #247
Andy4639
Old member
Andy4639's Avatar
Yes that's the post.
Old 03-31-2016, 04:53 PM   #248
XwalkerX
I NOW HAVE WORKING CRUISE CONTROL IN MY 44 YEAR OLD TRUCK!
thank you for all the help along the way LS1NOVA!!!!!!
Old 03-31-2016, 04:57 PM   #249
izzy_Britton
izzy_Britton's Avatar
I can barely read that! Can you make it bigger please ? Haha
I am glad you figured out out because I will be doing similar in a couple weeks and now I have an awesome example to work from if i have any odd issues.
-IZZY
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too
Cream Puff - LS'd Square - Slow going on the back burner
Tripple Threat - 3 Wrecks for the price of one build thread
Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered.
izzy_Britton is offline   Reply With Quote
Old 03-31-2016, 11:49 PM   #250
ls1nova71
ls1nova71's Avatar
Cool, glad you got it going! (I had to mod your original quote so it wouldn't scream at everybody again.... )
