Old 04-05-2013, 10:41 PM   #226
~Whitey~
~Whitey~'s Avatar
Re: 1968 Chevrolet SWB Stepside Restomod
You just might be needing those.
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 04-07-2013, 02:19 AM   #227
Xeen
Xeen's Avatar
Vic and I have been planning something very special for the interior of the truck.
I will give you all a little hint, it has something to do with the climate control area of the dash, as for the reveal it will be a few weeks so you will have to wait and see.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 04-07-2013, 09:53 AM   #228
Low Elco
Very nice!
Low Elco is offline   Reply With Quote
Old 04-07-2013, 09:12 PM   #229
gdavis
gdavis's Avatar
Hey, Soon I will be needing some kind of seam sealer. I need to seal the cab roof to the sides. What do I need to get and where is it avabily at? You know by telling us your climate control project is like temping a child with candy. But just like children we will have to wait and see.
gdavis is offline   Reply With Quote
Old 04-07-2013, 11:33 PM   #230
Hardesty454
Hardesty454's Avatar
Truck l
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 04-07-2013, 11:33 PM   #231
Hardesty454
**looks good!
Rob
Old 04-08-2013, 05:56 AM   #232
Xeen
Xeen's Avatar
Originally Posted by Hardesty454 View Post
Truck looks good!
Thanks I appreciate it, I've got a ways to go yet but it's getting there.
Old 04-08-2013, 07:24 PM   #233
502ms
502ms's Avatar
Great speaking with you today. Hope your build is nice and sweet.
Best Regards,
Leon M.
502ms is offline   Reply With Quote
Old 04-09-2013, 06:03 PM   #234
Xeen
Xeen's Avatar
Hey all;
I ordered a NOS GM Ignition Bezel and service tool today.
Old 04-10-2013, 06:25 PM   #235
Xeen
Xeen's Avatar
Hey all;
I went to the salvage yard and got the gas pedal and TAC wiring I needed today, new that stuff would have costed me nearly $200 and I picked it up for $43 I thought that was a pretty good deal.
Old 04-11-2013, 01:53 PM   #236
Xeen
Xeen's Avatar
Hey all;
The Dakota Digital Climate Control and Cruise Control was delivered today.
Also the BMW USB power adapter was delivered.
Flip out handle for easy removal.
Old 04-11-2013, 02:43 PM   #237
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Will the USB power adapter fit in the existing cigarette lighter hole? Or does it plug into it?
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 04-11-2013, 04:17 PM   #238
Xeen
Xeen's Avatar
The BMW USB Power adapter will plug into any standard 12v receptacle.
Old 04-13-2013, 04:28 PM   #239
Xeen
Xeen's Avatar
Hey all;
I installed my Boyd Welding EFI Gas Tank today.
I still need to run my fuel lines.
Old 04-15-2013, 02:20 AM   #240
Xeen
Xeen's Avatar
Hey all;
I ordered O2 Sensors and stainless steel weld in O2 sensor bungs today.
Rockauto.com has killer prices on O2 sensors.
Old 04-15-2013, 09:37 AM   #241
67cheby
67cheby
67cheby's Avatar
nice parts, dig that tank !
67cheby is offline   Reply With Quote
Old 04-15-2013, 12:52 PM   #242
Xeen
Xeen's Avatar
Thanks, I have tried to order quality parts.
Old 04-15-2013, 01:59 PM   #243
67cheby
67cheby
67cheby's Avatar
get good stuff the first time saves you from going back and redoing it !
Old 04-16-2013, 01:52 AM   #244
Xeen
Xeen's Avatar
Hey all;
I am buying a stock GM Radiator and electric fan out of a 2006 silverado 5.3L for my truck today.
I am also buying a MAF sensor and LH battery tray.
Old 04-16-2013, 02:07 AM   #245
Xeen
Xeen's Avatar
Hey all;
I would like to send out a special thanks to ls1nova71 for explaining the fuel system for the 2003 vortec swap for me, a million thanks you rock man!
Old 04-16-2013, 11:44 AM   #246
Xeen
Xeen's Avatar
hey all;
I got lucky and the entire sub harness was still there for the fan setup, so I dont have to buy any electrical stuff.
I forgot to get the battery tray though, oops.
The radiator is alot wider than I imagined it would be, mounting it will be fun considering it isn't as tall either, so the stock radiator mounting bracket kit I bought awhile back isn't going to work, yay...
Old 04-16-2013, 11:51 AM   #247
Bomp
Bomp's Avatar
Sweet tank.
Looks like your getting all the necessary parts to build one Killer Truck!
Bomp is offline   Reply With Quote
Old 04-17-2013, 03:46 PM   #248
Xeen
Xeen's Avatar
Hey all;
I ordered my fuel line fittings and clips today.
I decided to use 3/8" to -6 AN Tube Nuts and run 3/8" steel lines for both my supply and return lines.
This will allow me to use a simple 37 degree flare on a steel line, and save a ton of money over a braded hose setup with the added bonus that it will be more robust over time.
It took me quite a bit of research and time to figure this out and hopefully this will save someone some time in the future.
Here are the fittings I used with links.
GM 3/8" female spring lock to male -6 AN. http://www.summitracing.com/parts/rus-640850
GM 5/16 female spring lock to male -6 AN. http://www.summitracing.com/parts/rus-640860
Tube Nut 3/8" to female -6 AN. http://www.summitracing.com/parts/sum-220633-2
Tube Sleeve 3/8" to -6 AN. http://www.summitracing.com/parts/sum-220634-2
Old 04-18-2013, 01:31 PM   #249
Xeen
Xeen's Avatar
Hey all;
Thanks to the talents of Victor and the small contribution of my imagination here is the Climate Control Bezel.
The Bezel has yet to be polished but I couldn't wait to show it to you guys so after it's polished I will install it into the dash and take another picture.
Old 04-18-2013, 02:53 PM   #250
~Whitey~
~Whitey~'s Avatar
That looks good! I'm jealous over the gas tank... On my list just haven't got there yet. How did it fit? Any problems?
Jimmy
.69SWB Build.
1968, chevrolet, restomod, stepside, swb
