Old 03-07-2013, 10:04 PM   #226
sduckworth13
sduckworth13's Avatar
Re: Project 69SWB
That looks good, wonder if you could use some lab metal filler to seal it up real good and keep it from leaking?
Scott
sduckworth13 is offline   Reply With Quote
Old 03-07-2013, 10:31 PM   #227
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
As far a the weld seam it's solid. I'm going to go ahead and spray some epoxy on this area and then lay down some evercoat rage gold to smooth it up. Then when I get done with all the priming and whatnot I'm going to use a self leveling sealer on the drip rail. It should be waterproof at that point.
Jimmy
.69SWB Build.
~Whitey~ is offline   Reply With Quote
Old 03-07-2013, 10:39 PM   #228
sduckworth13
Re: Project 69SWB
Cool, I'll be watching and taking tips.
Scott
Old 03-08-2013, 12:46 AM   #229
Low Elco
Re: Project 69SWB
Came out great!
Low Elco is offline   Reply With Quote
Old 03-08-2013, 12:16 PM   #230
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Originally Posted by Low Elco View Post
Came out great!
thanks fellas.
Jimmy
.69SWB Build.
Old 03-08-2013, 08:06 PM   #231
gdavis
gdavis's Avatar
Re: Project 69SWB
Originally Posted by ~Whitey~ View Post
Can only upload 1 pic at a time from my phone.
Here's another.
You did a Fab job on the rof. Great work.
gdavis is offline   Reply With Quote
Old 03-13-2013, 11:26 AM   #232
RWB-713
RWB-713's Avatar
Re: Project 69SWB
Nice work! Roof Looks Great!
" I strive for a level of perfection that I do not possess the skillset to achieve. "
Ariel <> '67 C10 Shorty Stepside *** Build On Hold ***
First Ride <> '81 C10 Long Fleet *** Current Project ***
RWB-713 is offline   Reply With Quote
Old 03-13-2013, 01:00 PM   #233
XxCHEVYMANxX
XxCHEVYMANxX's Avatar
Re: Project 69SWB
Nice work Jimmy!
John
Mild Custom 68' Work Truck Build
Facebook LoL
1977 Trans Am (Project)
1965 Chevelle (Project)
XxCHEVYMANxX is offline   Reply With Quote
Old 03-13-2013, 01:23 PM   #234
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Originally Posted by XxCHEVYMANxX View Post
Nice work Jimmy!
Thank guys!
I laid down some epoxy on that part of the roof last night, then got up this morning before work and spread out some Evercoat Rage gold on the repair... going to sand that down when I get home from work this evening and see where I'm at with it.
Jimmy
.69SWB Build.
Old 03-13-2013, 01:51 PM   #235
mcbassin
Still Learning
mcbassin's Avatar
Re: Project 69SWB
Wow, Lot of good progress on your cab. You are knocking it out. It's pretty rewarding when it's all done and in primer.
mcbassin is offline   Reply With Quote
Old 03-13-2013, 01:55 PM   #236
ddubbs
ddubbs's Avatar
Re: Project 69SWB
Really liked what you started with. Progress is coming along great.
LIFTED OR LOW THE ONLY WAY TO GO!!!!
Check out my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=517346
Projects
56 Chevy pickup Porterbuilt FR/RR dropmembers
ddubbs is offline   Reply With Quote
Old 03-13-2013, 02:03 PM   #237
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I find myself ready to move onto something else and have thoughts of leaving this be for a while, but I'm hanging with it. This is how I felt about halfway through the frame and engine but stuck with it... then when I rolled it out, it was very rewarding and all worth while.
Thanks ddubbs! I was pretty fond of my truck before I tore it down, but it needed some work. Looked a lot better in the pics than it did in person. It was a 50ft truck as I called it. (looked great from 50 away) :-)
Jimmy
.69SWB Build.
Old 03-13-2013, 03:07 PM   #238
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Re: Project 69SWB
Subscribed! This is a fantastic build you have doing here. I sincerely appreciate the PM's and will be watching your progress.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 03-13-2013, 04:05 PM   #239
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
no problem Al! Hope to keep you entertained. :-)
Jimmy
.69SWB Build.
Old 03-15-2013, 11:32 PM   #240
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
Was able to get the roof in epoxy yesterday and start on finishing up the repair to the section I had cut out.
This was my first pass with the filler (evercoat rage gold), I sure like working with it. nice stuff. I did one other coat after this one and then top it off with a thin coat of and light sanding of evercoat polyflex glazing putty.
I had originally just laid the epoxy over the area I was working on, but after I got the repair done I went ahead and did the whole roof. Letting it dry tonight, then I have a couple tiny dings to fill in and will do one more coat of epoxy and then lay down the polyester primer... just on the roof only. Afterwards I'll move on to another area.
first pass of the filler
After the epoxy.. I've always had a problem with orange peel due to my compressor not having any guts... especially with the thicker primers. I've only painted 2 jeeps before and color sanded till I was ready to puke. That problem is going away. I figure out of all the money I am spending on the truck I can at the very least upgrade my compressor and do a much better paint job. So by-by 26 gal Craftsman and hello in a couple days 60 gal Ingersol Rand with almost triple the CFM. :-) will post of pic of that when it comes in.
Jimmy
.69SWB Build.
Old 03-16-2013, 07:22 AM   #241
CC69Rat
CC69Rat's Avatar
Re: Project 69SWB
Have you been using the 401 or 402 catalyst? (Assing DPLF)
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-16-2013, 11:47 AM   #242
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I'm using:
Epoxy: Black PPG Shop-Line JP377 with JH3770 hardner.
Poly: Gray PPG Shop-Line JP205 w/hardner
Filler: Evercoat Rage Gold
Glazing: Evercoat Poly-Flex
Paint: PPG Shop-Line JAU (Black)
Jimmy
.69SWB Build.
Old 03-16-2013, 12:02 PM   #243
Bennett68C10
Bennett68C10's Avatar
Re: Project 69SWB
Are you planning on going with a single stage or BC/CC. I'm trying to learn as much as I can cause i'll probably be painting my truck myself. Trying to figure out the pros/cons of the different options out there.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 03-16-2013, 12:26 PM   #244
sduckworth13
Re: Project 69SWB
Jimmy, the roof looks great.
Scott
Old 03-16-2013, 02:56 PM   #245
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
I'm doing a single stage black (5 coats), then a color sand and buff. I have a couple friends in the auto body and paint business who have recommended the products I'm using. I also have gotten many pointers and tips from them that have saved me a lot of headaches.
Thank you Scott. I'll be glad to get done with the cab. It's a huge peice of the puzzle.
Jimmy
.69SWB Build.
Old 03-16-2013, 06:35 PM   #246
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
ok the roof is done for now. I fixed a few dings and laid down another coat of epoxy, let it dry for about about 2 hours and then went over it went 2 coats of poly (1st coat light). Going to leave it alone for a couple days while I tinker with some smaller stuff then get it flipped by right side up and work on the back and corners.
Next time I paint I'll have my new air compressor, can't wait.
Jimmy
.69SWB Build.
Old 03-17-2013, 11:05 AM   #247
Bennett68C10
Re: Project 69SWB
Thanks for the info, the roof looks great. You are inspiring me to do my paint myself. If you have any tips or tricks please let me know.
Keith
66 Suburban
IG: bennett68c10
Old 03-17-2013, 09:07 PM   #248
CC69Rat
CC69Rat's Avatar
Re: Project 69SWB
Looks really good man. Shopline is great stuff. Thats what Im buying as I need more.
Keith, go for it man.
Chad
Old 03-18-2013, 08:09 AM   #249
Low Elco
Re: Project 69SWB
Roof looks great, keep it up!
Old 03-18-2013, 11:02 AM   #250
~Whitey~
~Whitey~'s Avatar
Re: Project 69SWB
thanks fellas.
Keith all I can tell you is what I've been told to do and what I've realized in the process of being told what to do. haha.
tips (not professional, but noteworthy!)
1. Make sure you clean the surface good. (I use PRE from Eastwood)
2. Light coat first, the medium coats after that
3. A good air compressor that puts out at least 11 cfm. 100% duty cycle is preferred. Otherwise plan on sanding a lot of orange peel out. With my craftsman 26 gal 4ish CFM I had to use a HVLP gun it wouldn't handle a regular paint gun... and 3/4 of the way through that roof top is was pretty much done... hence the orange peel. (not enough pressure to atomize the paint) I'm not saying you can't do it with a puny compressor, but it makes for more work.
4. Let it dry, don't rush it. Epoxy I'll let dry 24 hours before I do body work on top of it, poly I let dry overnight, and paint I won't touch it for at least 2 days after I spray it.
5. Let the sandpaper do the work, pressing harder to try to sand faster is only going to clog the paper and/or cause deep scratches.
6. PROTECT YOUR LUNGS. you only have one set... a good coat of primer or paint on your lungs will make breathing difficult for a long, long, time... unless it kills you, then you won't have to worry about it.
When it comes to the job I do it in this order.
Starting with clean bare metal... which I usually hit with Eastwood Fast Etch and then PRE
Epoxy first. I'm just spraying the areas that need body work, do the body work and sand smooth with 80grit and follow up with some 180, then I feather out the epoxy to the bare metal. This is because I don't have time to do it all within that window that you have to spray the poly without having to go back and scratch up the epoxy. I would hate to go over the entire cab, all the nooks and crannys to do that.
Poly second just on top of body work and then I'll feather that out almost to the edge of the epoxy with 220.
When all the body work is done I'll spray everything with epoxy, wait 3 or 4 hours then spray it all with poly. (2 different colors is helpful, so when sanding you know when to stop.. I use black epoxy and gray poly.
At this point all the body work for the most part is done. It's time for blocking (I use Dura-blocks) to level/smooth out the panels, if I have to put on any filler to level anywhere I'll spray those spots with poly, sand, and then cover everything with epoxy sealer and paint. I also do it all by hand, I don't have a DA... though I may get one now that I have a good compressor. Not sure.
That might be more info than you wanted, but that's how I've been told to do things and it's worked out so far. I'm sure there are other ways to go about it as I think paint/body work is a "To each their own" trade.
Sorry for the long post but hope that helps someone... that's it in a nutshell.
It's Monday, I'm sure I left something out.
Jimmy
.69SWB Build.
1969, black, custom 10, fleetside, shortbed
