09-26-2015, 10:28 PM | #226 |
Carpe manana
Re: Blazer SPID thread?
LOL! That one gets my vole for the oddest one yet - thanks for posting Brad.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
09-27-2015, 12:04 AM | #227 |
I'm trying....
It's neat not only for the unlabeled codes or the random codes, but also for the BX2 and the A50 which I think should technically be covered by the Z84.
Edit---also by the book, I think all CSTs should have come with a spare tire cover. Double edit--another one I missed...how about the CB8 and Z58
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076 1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352 1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290 1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555 "Sometimes I wonder if zander208 was even real..." |
09-27-2015, 01:01 AM | #228 |
Man that truck had everything. Except had z84 package and ordered black vinyl seats. Should be highlander with that. Some of the blanks I'm wondering about though.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks. |
09-27-2015, 01:53 AM | #229 | |
Nothing sinister or really unusual actually. Go back to posts 219-222 for a similar St. Louis example. Its really just a case of too much information common during SPID format changes. Being the 563rd truck off of the 72 Flint line I am surprised its even that good. There were a lot of issues getting the correct RPO suffix codes during the change over from letters to numbers for the 72 MY. It was what it codes. K5 Hugger Orange with Black CST trim and a White top. BTW Those RM1 codes with the blank descriptions are H78-15/B On-Off Road Bias Belted tires. CSTs ordered with a hard top included a spare tire cover. So most but not all CSTs had tire covers as shipped.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 09-27-2015 at 02:20 PM. |
10-26-2015, 03:10 PM | #230 | |
"New Removable Top Assembly (RPO CC3) 1972 Blazer A new (simplified construction) top is being offered to supplement the currently available (RPO CB8) top for Blazer models. The new top (RPO CC3) is a single skin design with three exposed interior roof rib reinforcements running from side to side, whereas the RPO CB8 top is a double skin design with inner roof panel lines running front to rear. Part numbers for the two tops are as follows: RPO---Part No.--Color CB8--6262051---Black -------6262052--White CC3--6271845---Black -------6271846--White Mounting of the new top differs from the earlier style in that attachment to the box is accomplished through floating anchors contained in the box sides (Fig.1). The top is then bolted from above making trim panel removal unnecessary. New parts contained in the RPO CC3 top are: * Side door glass weatherstrip and retainer (providing an adjustable weatherstrip feature). * Thinner (1/8 inch) side glass and weatherstrip. * Top to box weatherstrip. * Seal and metal retainer around lift gate hinges. * Top to box side molding and chrome plated hold-down bolts. The lift gate and attaching parts, header weatherstrio, and header attachments are common to both tops." Unfortunately unless you have a build (broadcast) sheet or one of the atypical SPID as mention in earlier posting you will not see the CB8 OR CC3 codes. Generally they are found only on the build (broadcast) sheet. There they indicate the conversion of the vehicle to a removable hard top. Where the generally seen SPID codes Z58 (White) and Z59 (Black) really only indicate the color and confirm a factory hardtop installation.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban Last edited by SS Tim; 10-26-2015 at 06:06 PM. Reason: ref :csn v44 01/72 #1 pg2 |
10-26-2015, 04:35 PM | #231 |
I'm trying....
Wow Tim...fantastic info as always. Thanks for being the guru.
10-28-2015, 05:22 PM | #232 |
Ok, here the SPID from my Blazer. Quick question, what is the H78-15-B ON-OFF ROA?
..................... ____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1970 C20 -_--_--_- ______ _--_--_- /___|__\____ -_--_-_ |_(0)|__|_(0)] 1972 K5 |
10-28-2015, 05:25 PM | #233 |
I'm trying....
Tires.
10-28-2015, 05:30 PM | #234 |
Bias ply tires that is
10-28-2015, 05:36 PM | #235 |
well now I feel stupid
10-28-2015, 07:29 PM | #236 |
Five bias belted tubeless blackwall tires with an on-off road tread.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
12-06-2015, 09:21 PM | #237 |
I just bought a 71 blazer glove box door and driver door here is its spid
01-08-2016, 02:58 PM | #238 |
A member's 70 4X2 Gold on Gold 6cyl 3OTT.
http://67-72chevytrucks.com/vboard/s...4&postcount=87
01-16-2016, 12:06 PM | #239 |
Here's mine 1970 2WD Jimmy.
02-02-2016, 11:09 PM | #240 |
Carpe manana
uno mas...red w black interior
02-03-2016, 06:26 PM | #241 |
[QUOTE=SS Tim;7354312]To clear things up this is from GM dated January, 1972
"New Removable Top Assembly (RPO CC3) 1972 Blazer A new (simplified construction) top is being offered to supplement the currently available (RPO CB8) top for Blazer models. The new top (RPO CC3) is a single skin design with three exposed interior roof rib reinforcements running from side to side, whereas the RPO CB8 top is a double skin design with inner roof panel lines running front to rear. Part numbers for the two tops are as follows: Tim - thanks for sharing this info. I had a guy from a local repair boat shop come by the house to take a look at my top. In the photos below I drew black annotation marks to call out, or confirm if these are the roof rib reinforcements running side to side? We were discussing these and neither of us could determine if this was factory or if this was a repair that happened at some point in time. Thanks! Mike This is the driver front side. They have the same matching lines on the other side as well. Passenger backside
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612 Build version 2.0: 72 K5 6.0 LQ9, 4L80e, NP205 http://67-72chevytrucks.com/vboard/s...d.php?t=793192 ____________________________________________ 1972 CST K5 Blazer Dark Olive |
02-03-2016, 08:08 PM | #242 |
Pretty sure the roof ribs are up Top and not on the sides. It gives the top the strength it needs to support its own weight and not sag.
03-13-2016, 06:52 PM | #243 |
Here's a spid on a glove box door from a blazer that got parted years ago
1970 CST 4x4 collecting nos parts for this project 1972 cutlass owned since 1984 1972 cutlass conv 1970 Cutlass conv 1981 chevy shortbox 1986 grand national 2004 2500HD Crew Cab 66,000 miles |
03-13-2016, 08:05 PM | #244 |
I'm trying....
That's about as loaded a 70 as I've seen. Wish it still existed.
03-13-2016, 08:15 PM | #245 |
Unusual options. AUX battery, camper mirrors.
03-13-2016, 08:17 PM | #246 |
Another CST
03-13-2016, 08:33 PM | #247 |
Does any one have the option two ton colors for the seats.
1972 GMC Jimmy 1/2 4X4 4wheel camper 1970 GMC Jimmy 1/2 4X4 350 1969 Chevy Blazer 1/2 4X4 307 1967 chevy LWB 3/4 396 |
03-13-2016, 11:44 PM | #248 |
Those trucks were loaded about s much as can be possible. My dads jimmy had the camper mirrors stock I believe as well. Wish it would have lasted long enough to be my first truck. Mom wrecked it one winter and sold the jimmy as a parts truck. I was a sad little boy to se it go. That's why I bought my blazer. Wanted those memories back.
03-14-2016, 12:23 AM | #249 |
Heres my 71 CST
Posted via Mobile Device |
03-14-2016, 01:10 PM | #250 |
Carpe manana
Nice - thanks for posting these. Gary by two tone do you mean Highlander plaid? Can't recall seeing another OEM style seat set up close to two tone for utility or sport buckets.
