10-21-2022, 05:14 PM | #226 |
Re: My 55 Chevy 4X4
Put the exhaust together. Going with flowmaster delta 40s. Wanted to stainless steel but my TIG skills are not there yet.
55 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=602942 38 ford http://67-72chevytrucks.com/vboard/s...d.php?t=704338 |
10-24-2022, 04:12 PM | #227 |
Re: My 55 Chevy 4X4
for anybody lurking, you can also weld stainless with an arc welder. I just did a repair on the wifes audi exhaust with my old arc welder. the exhaust pipes are from 2001. it turned out great. clean the metal well first, don't use a regular steel wire brush to do that.
11-24-2022, 12:55 PM | #228 |
Re: My 55 Chevy 4X4
Have the gas tank ready to install and working on the radiator hoses.
55 4x4 http://67-72chevytrucks.com/vboard/s...d.php?t=602942 38 ford http://67-72chevytrucks.com/vboard/s...d.php?t=704338 Last edited by Rickysnickers; 11-25-2022 at 10:56 AM. |
11-25-2022, 11:22 PM | #229 |
Re: My 55 Chevy 4X4
Great project .
Congratulations on your marriage, I was married on Halloween also . I’ve got a genuine factory installed NAPCO ‘57 GMC that’s been finished for decades . Soon it will go under the wrench and become a two wheel drive air ride 5.3 automatic Currie 9” . It also will have power windows ,Altman latches a/c etc. The new chassis was done in 2010 then other projects took over the shop . Did you use Bear Claw or Altman door latches ? Looking forward to your solution to getting Electric into the doors, I’m thinking contacts also .
Glen & Jane's Rides ‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008 7 other cars & trucks , 5 trailers '56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020 ’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020 My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275 |
11-27-2022, 02:35 PM | #230 |
Re: My 55 Chevy 4X4
The kit was an Altman kit. I need to do more adjustment on the doors. right now they latch but after I get the door gaps where I want them I might not have the adjustment I need for the striker. The power windows are Nu-relic and they went in nice. Just a little trimming on an inner brace for motor clearance. I rather just use contactors instead of the sliding loom style for door power but I have some folding steps I want to install and not sure what they need to switch them to work.
03-04-2023, 01:13 PM | #231 |
Re: My 55 Chevy 4X4
Got a BP automotive harness and started wiring the engine bay.
03-04-2023, 01:19 PM | #232 |
Re: My 55 Chevy 4X4
The engine started up just fine and I let is run for about 30 seconds. The next day I had a small leak from the top of the gas tank. I was never happy with the mounting bracket I made for the tank. Verry hard to remove the tank. So I decided to redo the bracket so it can be removed easier. I am also going to add hard lines to extend past the top of the tank so I can disconnect the flex lines without having to lower the tank.
04-09-2023, 11:34 AM | #233 |
Re: My 55 Chevy 4X4
I fixed the gas leak issue. Got my air intake routed and plumbed the power steering.
04-09-2023, 11:45 AM | #234 |
Re: My 55 Chevy 4X4
Added all the fluids and ran the engine up to temp. No leaks and the fan turned on at 190 degrees. So now I can start the wiring. Doing the ignition first. Everything but the starter is going through a 200 amp megafuse. Then I am using a button that controls a 200 amp relay that send power to an engine bay and dashboard power distribution block. The dash power is also protected by a 150 amp breaker. I figure the relay is a convenient way to disconnect the battery and prevent a draw when sitting.
11-22-2023, 06:14 PM | #235 |
Re: My 55 Chevy 4X4
Getting closer. Front end is on. Lights are done. Shocks installed. The rear was a little squatted so I removed the 2" lift blocks and installed a 4" shackle reverse kit. I also found some bucket seat that work better than the bench seat I had and I bough a dakoda digital dash.
11-23-2023, 08:28 AM | #236 |
Re: My 55 Chevy 4X4
Truck is looking really good... and pretty much done! What is left to do?
Rick 78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel 71 GMC C25 350/TH400 - Project Angie 59 Chevy SWB Stepside (next in line? Not sure now ) 2001 GMC Sierra K2500 |
11-23-2023, 04:16 PM | #237 |
Re: My 55 Chevy 4X4
I am registered and will start doing some shake down runs in March when the weather gets better. I am working on the interior. Going to put the sound deadener in, picking carpet colors, and designing a center console, adding 3 point seat belts, and a heater. Looking to do a tannish Carmel with black. Down the road I will have the seats reupholstered to match. It feels good to be done. I have 2 more projects on deck. a 38 ford rat rod that I started when the truck was in paint jail and a 68 Firebird I bought over 30 years ago with my lawn mower money when I was 15. I want the 38 moving at the end of summer and the 68 on the road in 3 years.
