Old 05-22-2016, 10:39 PM   #226
TBONE1964
Cluster King
TBONE1964's Avatar
Re: Reconditioned gauge Clusters F/S
Originally Posted by jsprengeler View Post
Tom,
What would it cost just to have the chrome part refinished on my green gauge cluster? Thanks! John
Hi John,
I honestly would not have any idea on re chroming your bezel. It is probably pretty pricey and you will still have to have the green resprayed. You may want to find a local chrome shop that works with plastic and see if they could give you a quote.
Another option if you are OK with it is aftermarket bezel which comes chrome with black and have the black painted green. This is not as easy as it sounds. The tape work has to be perfect the first time or throw it out and start over. The last time I did this it was $200.00 with time and materials.
If you want me to get those estimates for you, I can, just let me know.
That is a nice looking cluster as is.
Hope this helps,
Tom
TBONE1964 is offline   Reply With Quote
Old 05-23-2016, 10:18 AM   #227
jsprengeler
jsprengeler's Avatar
Thanks for your quick response, Tom. I'll certainly look into your suggestion. John
Incapable of not thinking about my truck at least every other minute
jsprengeler is offline   Reply With Quote
Old 05-23-2016, 10:27 AM   #228
TBONE1964
Cluster King
TBONE1964's Avatar
Originally Posted by brutus72 View Post
I am open to aftermarket, if you think they are good quality reproductions. Could you send a pic?
Here are some photos of the new aftermarket tach I use. They are not a 100% exact to OE reproduction but they are close and look nice in the cluster. I have done a lot of clusters with these tachs with no issues. This tach would cost about $100.00 to replace if it ever did go bad.
Let me know what you think.
Take care,
Tom
Old 06-27-2016, 05:39 PM   #229
brutus72
Take care,
Tom
Tom,
I have a couple of clusters that are pretty rough, would like to get a complete rebuilt cluster back using the best of what I have, likely will need new bezel, would like to add 5k or 8k Tach, vacuum gauge if you have one. I am good with aftermarket. Will send PM
brutus72 is offline   Reply With Quote
Old 06-27-2016, 06:06 PM   #230
Grumpy old man
Grumpy old man's Avatar
Looking for a 6 cylinder tach , any available ?
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 06-27-2016, 07:49 PM   #231
TBONE1964
Cluster King
TBONE1964's Avatar
Sorry, fresh out. I just found one for a customer and it was NOS for a 6 cyl and he paid around $275.00 for it. They are getting real hard to get now.
Take care,
Tom
Old 06-27-2016, 07:50 PM   #232
1968k20
1968k20's Avatar
Still looking for a vacuum gauge. Do you have one yet?
1977 Chevrolet K10 SWB Project 350/4spd/np205
1977 Chevrolet K20 LWB 350/350/203
1991 4Runner 22RE 5 SPD
Yanmar Tractor 3 Cyl Diesel
1968k20 is offline   Reply With Quote
Old 06-27-2016, 07:53 PM   #233
TBONE1964
Cluster King
TBONE1964's Avatar
Tom,
PM received. I will get with you soon.
Thank you,
Tom
Old 06-27-2016, 07:55 PM   #234
TBONE1964
Cluster King
TBONE1964's Avatar
Nothing OE. If one comes up, I will let you know. OE vac gauges are getting hard to find in good working condition and almost always need a restoration on the face which can be done.
Let me know if you find one that needs face restoration and I can get that done. Otherwise, there is the aftermarket ones.
Thank you,
Tom
Old 06-27-2016, 08:25 PM   #235
1968k20
1968k20's Avatar
Thank you,
Tom
Thank you!
Old 07-12-2016, 12:51 AM   #236
robs71k5
K5drive
robs71k5's Avatar
Have a problem with my speedometer . I replaced the cable when it broke and replaced it with a new one but then the speedo started making noise and the speedo was jumping so I purchased another new cable and installed, the noise has been reduced but it hasn't gone away so now I'm thinking it might be the speedo itself . I had the speedo set to zero when My truck was completed . It now has 9000 miles on it . The miles are still adding up but the noise is driving me crazy. What would happen if I gave it a shot of WD. Or another solution might feel to purchase anothe speedometer if you can match the miles . Suggestions thanks Rob
robs71k5 is offline   Reply With Quote
Old 07-12-2016, 02:03 AM   #237
TBONE1964
Cluster King
TBONE1964's Avatar
Hi Rob,
I prefer dry or wet graphite on the speedometer cable and on the back of the speedo where the cable hooks up. It will stay in place much better than WD. WD will/should provide a temporary fix for the noise but graphite is much better as a lubricant.
If you wanted to send me your speedometer, I could hook it up to my calibration machine and check it out. Most likely the frame bushings are wore. This will cause noise as well as needle bounce.
If you want a replacement speedometer, I can put a nice one together for you. I can set mileage to whatever you like. It will be calibrated, quite and no needle bounce.
You can send me a PM if preferred to discuss details.
Thank you,
Tom
Old 07-20-2016, 05:54 PM   #238
joeminnesota
joeminnesota's Avatar
I just received the Instrument Cluster TBONE1964 reconditioned for me! All i have to say is WOW WOW WOW! it looks fantastic! I cannot wait to install it!
Thanks so much!
69 C10 250 6 Cyl 4 Speed Long bed Fleetside
joeminnesota is offline   Reply With Quote
Old 07-20-2016, 08:37 PM   #239
TBONE1964
Cluster King
TBONE1964's Avatar
Thanks so much!
Hi Joe,
I really appreciate the complement. Please post a photo up when you can with the cluster installed. I would love to see the truck it is going into.
Thank you again for the business and your patients. It was my pleasure to build you a nice cluster.
Take care,
Tom
Old 07-20-2016, 09:43 PM   #240
Elliot949
Elliot949's Avatar
Hey Tom... Here it is ... It finally made it to the truck... I decided not to use my original 67 Restored Bezel but went with the Chrome Aftermarket Bezel... we are getting closer to getting it all hooked up...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 07-20-2016, 09:56 PM   #241
TBONE1964
Cluster King
TBONE1964's Avatar
Very nice Dan. I really love that steering wheel
Take care and thank you for posting up the photo. Looks real nice.
Tom
Old 09-22-2016, 09:35 AM   #242
c104life
Hey Mr. Tom if you don't mind, what do you use or how do you clean the circuit board ?
c104life is offline   Reply With Quote
Old 09-22-2016, 10:27 AM   #243
TBONE1964
Cluster King
TBONE1964's Avatar
Brasso and a microfiber towel. be careful not to lift the brass tabs where the light sockets are.
Good luck,
Tom
Old 02-25-2017, 10:31 PM   #244
TBONE1964
Cluster King
TBONE1964's Avatar
Hello all,
Just wanted to make an announcement that I will begin doing cluster restorations again.
A few things have changed though. I do not stock too much inventory now because of space limitations. I will be limiting the amount of work I do at one time.
If you are interested in having work done, let me know and I can give you specific details on work and pricing.
Thank you to all that are interested in having cluster work done or have had work done in the past.
Take care,
Tom
Old 02-25-2017, 10:41 PM   #245
Black71Shorty
Black71Shorty's Avatar
Tom, it's great to hear you will be doing this again! You do very nice work!
Coby
Black71Shorty is offline   Reply With Quote
Old 02-25-2017, 10:42 PM   #246
CheyenneSuper72
Hey Tom, could you pm me a price for a replacement tach, lense, and circuit board? Thank you.
CheyenneSuper72 is offline   Reply With Quote
Old 02-25-2017, 10:43 PM   #247
TBONE1964
Cluster King
TBONE1964's Avatar
Coby
Thank you sir
Old 02-25-2017, 10:46 PM   #248
TBONE1964
Cluster King
TBONE1964's Avatar
PM on the way
Old 02-25-2017, 11:28 PM   #249
Jcfcamaro
Jcfcamaro's Avatar
I'm interested in having mine restored. 72 dash with vacuum and tach.
Jcfcamaro is offline   Reply With Quote
Old 02-26-2017, 01:15 AM   #250
TBONE1964
Cluster King
TBONE1964's Avatar
You can send me a PM. let me know if the gauges and tach as well as the speedometer work or if you do not know what condition the gauges are in.
I appreciate the interest and look forward to doing a restoration for you.
Take care,
Tom
