04-15-2014, 12:07 AM | #226 |
Re: Need advice: LS ENGINE SWAP
Im tired this took about 4 hours I didnt get out there til about noon but tomorrow is another day...Im a little concerned about all my other wiring I decided to go all new not just the engine harness but for the headlights, gauges, and all that stuff...any Ideas where to get ?
Trying to get thru my LS swap |
04-15-2014, 12:16 AM | #227 | |
Sgt Dennis Heineman USMC Aviation Ordnance I.Y.A.O.Y.A.S 2001-Present 84 K10 2000 trans am ws6 2011 nissan altima 2009 Troy Built with a 42 Inch Deck My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371 |
04-15-2014, 12:28 AM | #228 |
yeah mine were pretty beat up... I figured got this far and dont need a fire down the road.
04-15-2014, 12:30 AM | #229 |
True, it's easy stuff while your in there
04-16-2014, 10:26 AM | #230 |
Got the firewall done, lots of sanding and cleaning, going back today to get the front frame cleaned up lots and lots of grease on there
04-16-2014, 10:51 AM | #231 |
Looking good man
04-16-2014, 02:10 PM | #232 |
Gmcpauls sells direct replacment harness.
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
04-16-2014, 10:24 PM | #233 |
Thanks man !!!
Thanks Truckdude ! but I already sent my harness out for conversion
04-16-2014, 10:40 PM | #234 |
Well spent most of the day scraping, spraying degreaser, wiping and spraying and even used a pressure washer that made available to me while I was there, but Im still not done need to go back tomorrow and do some sanding and more cleaning and more painting but here is what it looks like now...its getting there slowly but surely
I got a chance to open up one of the valve covers just to see what it looks like and this is what I found...looks as clean as that last engine but ! this time the year is a little different...falls inline with the 07 silverado
04-16-2014, 10:56 PM | #235 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
04-16-2014, 11:32 PM | #236 |
Oh !!! haha Im totally out of it, I ended up going with speedway motors they had a 20 circuit harness that looks like it will work...thanks for pointing that out and again thank you truckdude I apreciate you trying to answer that for me.
05-09-2014, 10:33 AM | #237 |
Okay I need to update this thread and post where I left off. Engine and tranny is in along with my suspension 3.5/5.5 I rebuilt my front end all new tie rods idler arm and bushings, got gas line from existing tank going but have to make a slight modification, installing my harness tonight and rewiring the whole truck this weekend...I had to step away for awhile as things got overwhelming lol it got to the point where I was dreaming about this truck, so had to just step back and rest my mind for awhile...I have to get my tranny cooler lines figured out since I got a new tranny cooler and got a different power steering cooler that other one that came with it was too awkward and would have been a pain to bolt up so I got something a bit nicer looking...so Im back on the drawing board and trying to get this thing done...here is a pic of it after the suspension I will most more stuff later
05-09-2014, 11:33 AM | #238 | |
05-09-2014, 11:43 AM | #239 |
Yep, lol... Dman caught a mistake on my fuel rail... I got the wrong fitting on so I will be changing that out tonight... Thanks Dennis!
05-09-2014, 01:36 PM | #240 |
meowMEOWmeowMEOW
Desert Dog
DessertDog
05-09-2014, 03:45 PM | #241 | |
05-14-2014, 01:47 AM | #242 |
I wanted to update this thread and let everyone know the progress, this past weekend I got started on my wiring, I called "Tidwell Installations" here in San Diego to do my chassis wiring harness because I wanted it done right and this guy is top notch. I also got my engine wiring harness back from being redone. As some of you know I had a hard time trying to find all the right connectors and take it from me if you ever have your wiring harness sent out, make sure you label every connector, it will make life so much easier ! anyways had a hard time with the harness and some of the connectors wouldnt reach the correct destinations, no big deal had to move some wires around and got them on. Trace Tidwell that was wiring the rest of the truck jumped right in and started getting some wires moved, one thing lead to another and next thing you know he is rerouting the entire harness so it looks much better in the engine compartment I was amazed at this guys work. Below are some pics of what he started and should be finished next weekend all the electrical will be done on this truck by then
I was amazed at how clean it looks { still need to change that fuel rail connection } this is where he left off should be done next weekend I will post more pics when all electrical is finished.
05-19-2014, 12:16 AM | #243 |
Trace got alot more work done on my harness starting to look alot better now
more extra wire not needed to make it fit neater should be finished this next comming week then got a bunch of little things to finish and hopefully be starting her up soon after.
05-19-2014, 12:21 AM | #244 | |
05-19-2014, 12:31 AM | #245 |
Yah no kidding what am I thinking ? I should know better by now lol !
05-19-2014, 09:21 AM | #246 |
Ya true, I just say soon haha
05-26-2014, 01:32 PM | #247 | |
The swap is looking good. Spending my Memorial Day on the porch swing reading LS swaps.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
05-26-2014, 11:08 PM | #248 |
Yep Im praying that it will start on D-Day but we'll take it as it comes, Memorial day weekend was somewhat productive got my fuel connections all correct, finished my switch panel, got my power steering cooler all installed and done, with oil filled. Took a good look at my transmission cooler lines and pretty sure I got that figured out but dont think the cooler I got will work, so need to get a different one I think, unless I can figure out where I can get the proper hose connections. My wiring guy Trace should have all my wiring done this comming week. Then have to figure out my drive shaft and send it off to be redone.
05-27-2014, 12:12 AM | #249 | |
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
06-09-2014, 12:32 AM | #250 |
Need to update this build thread. Power steering cooler done, transmission cooler done, switch panel done push button start and alot of the wireing done, actually got to hear it turn over witch was nice, interior lighting and wipers working harnes about 90% there...need to post some pics soon its going real slow but progress is being made Im not saying anything for sure but hoping this thing will be done in the next few weeks....
