Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 11-12-2014, 07:38 PM   #226
72K5CSTDarkOlive
72K5CSTDarkOlive's Avatar
Re: Attempting my first build 72 K5
Originally Posted by notsolo View Post
The Tub is like a floppy noodle, the reinforcement bar holds the door opening strait as possible while repairs are done. Any welding that is needed will not interfere with the door closing correctly. Usually the bar is set when the top is on to insure correct alignment...... I think the pieces from LMC are rubber..I am about to glue the rubber door pieces to my hard top, same as the ones #15 in LMC cat- , I can get you a photo of them tomorrow.
Yes, that would be great.. Sounds like I need to get these reinforcement bars installed quickly. The shop is going to use the dash repair panel from brotherstrucks so I can put the original AM radio back in.
Thanks!
My Build Thread 72 K5 http://67-72chevytrucks.com/vboard/s...d.php?t=628612
Build version 2.0: 72 K5
6.0 LQ9, 4L80e, NP205
http://67-72chevytrucks.com/vboard/s...d.php?t=793192
1972 CST K5 Blazer Dark Olive
72K5CSTDarkOlive is offline   Reply With Quote
Old 11-12-2014, 08:47 PM   #227
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Originally Posted by 72K5CSTDarkOlive View Post
....so I can put the original AM radio back in.
If you need a replacement in-dash speaker these 4x10 Delco special rectangles work well and are USA made: http://www.turnswitch.com/speakers.htm
I've installed two of these now in different trucks. The sound quality is much better than the NOS speaker I used for my K20.
Old 11-13-2014, 03:52 PM   #228
72K5CSTDarkOlive
This would look great and bring out the originality, but I don't have the original OEM brackets.. I search the net for some. If you know anyone who has them, let me know.
Old 11-13-2014, 06:35 PM   #229
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Not too hard to scare up. I'd try a WTB post on the pickup parts board when you're ready. I may have a spare speaker bracket. Not sure if radio brackets are on the spare AM radios I have.
Old 11-13-2014, 06:56 PM   #230
notsolo
notsolo's Avatar
Double wall tops had clips thru the weather strip to hold them here is a link to single wall with metal channel. 67-72chevytrucks.com/vboard/showthread.php?t=425729 ...a couple photo's of OEM Harrison Radiator.
notsolo is offline   Reply With Quote
Old 11-13-2014, 10:07 PM   #231
72K5CSTDarkOlive
Thanks for sharing. I believe I do have the original radiator. I'm going to have it refurbished. I have a shot one block from where I live that can do it.
Old 11-13-2014, 10:12 PM   #232
72K5CSTDarkOlive
Replacing the woodgrain. I want to use the same original trim, but want to find a good quality replacement for the woodgrain. I know LMC has it, but heard that it's not even close to what it looks like originally.
Anybody know where I could find just the woodgrain to replace the tailgate band?
Old 11-14-2014, 12:05 AM   #233
Splash4195
WOW good build!
Splash4195 is offline   Reply With Quote
Old 11-14-2014, 12:23 AM   #234
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I installed a repro wood band on the tailgate of a K10 I had while in NM - the decal didn't last a year outside in the NM sun. As a consequence, I've hoarded a couple of nice OEM bands. You can get the wood grain tape from LMC IIRC but I haven't seen it and can't remark on quality. Could get some and try it out.
Old 11-14-2014, 11:25 AM   #235
elcoy
Wow great build! Very impressed. I will be starting the same process soon on my yellow bomber. I see you went with 2.5" lift springs. I am trying to decide what size tires and lift to put on mine. Are those 31" tires? What did it start out as in your first photos?
elcoy is offline   Reply With Quote
Old 11-14-2014, 02:51 PM   #236
72K5CSTDarkOlive
Thanks, Elcoy! Good luck with your build. This forum board has lots of resources and lot's of guys offering insights and help.
As far as the leaf springs, I sure hope those are not 2.5" in lift springs. I'm going for a stock look. I did order new leaf springs from General Spring KC, but I'm pretty sure they are factory replacement, except they are not tapered like the originals.
yes, those are 31's.
http://www.generalspringkc.com/product_p/22-384.htm
Old 11-15-2014, 03:48 PM   #237
mx289
mx289's Avatar
Truck is looking great.
As said before,your attention to detail is spot on.
I have been looking for woodgrain tape for a tailgate band and for lower side trim and I might try a very thin 3m wood veneer tape.
It is a little pricey.
Give it a look.
Tom
71 K2500
71 K5 Jimmy
mx289 is offline   Reply With Quote
Old 11-16-2014, 05:47 AM   #238
72K5CSTDarkOlive
Looks solid! Don't let the neighborhood assoc give you grief
As for the door strikers, were these bolted into threads/nutserts that are somehow affixed to the pillar? On pickups there is a backing plate which will drop into the cab when the striker bolts are removed but not sure if K5's are the same. I have a fresh set of parkerized strikers I want to swap in but am afraid to drop the backing attachment (whatever it is) if loose then have to remove the rear panels etc. to retrieve them.
Yes they are. They move side to side and up and down, but they didn't fall down to the bottom. Here is a few pics
Old 11-16-2014, 06:00 AM   #239
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Perfect - thanks!
Old 11-17-2014, 08:27 PM   #240
72K5CSTDarkOlive
Give it a look.
Thanks MX289
I tired to looking for the wood veneer tape on 3M's site, but their search bar sucks. Could you send me a link?
Old 11-17-2014, 08:31 PM   #241
72K5CSTDarkOlive
Quick update.. This weekend I transported the K5 to my place inside the garage so I can finish the tear down. The AC, electrical wires and heater is all I have about left before it's ready to removed from the frame and taken down to the body shop.
Any tips on removing the windshield?
Name:  blazer tranport.jpg
Name:  blazer front garage.jpg
Name:  blazer back garage.jpg
Check out this cool Clifford Alarm system that I certainly won't be using lol. It has more wires than the whole truck does.
Old 11-17-2014, 11:13 PM   #242
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Cut the gasket with a utility knife and save the OEM trim. Don't wast any $$ on repro windshield trim. Get a Precision brand gasket and polish up the OEM trim for re-use.
Old 11-18-2014, 07:26 AM   #243
notsolo
notsolo's Avatar
Mine was still in good shape no cracks or splits, carefully worked it out with regular and plastic putty knives. cleaned it up and reused it. Same with the hard top window glass. Heard too many stories about ill fitting weatherstrip on glass. Either way.. Good luck.
Old 11-18-2014, 10:45 AM   #244
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
^^^^^ This
Tom Vogel is offline   Reply With Quote
Old 11-20-2014, 08:45 PM   #245
72K5CSTDarkOlive
Don't make the same mistake I did.. The Wilwood D52 Caliper kits will not fit our K5's with 15x8 rally wheels.
I didn't find this out until last weekend when I mounted the tire and was about to push the truck onto the trailer... The front wheels wouldn't budge. It turned the wheels where getting stuck on the caliper.
Old 11-20-2014, 08:51 PM   #246
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Bummer! Would a wheel spacer help at all?
Old 11-20-2014, 08:55 PM   #247
72K5CSTDarkOlive
Thanks, that was my initial thought. I'm trying to save all my trim as best I can and just clean and polish with a dremel.
Do you cut it from the inside or outside or both?
Old 11-20-2014, 09:12 PM   #248
IronCanine
I'm trying....
IronCanine's Avatar
I was disappointed to here this Mike. I ordered a set of black ones that got here yesterday just because I saw yours on your build thread. I can't imagine there's any more space behind a 15x6 steelie. Guess it's back to a stock single piston.
1970 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=645076
1969 K10 SWB CST http://67-72chevytrucks.com/vboard/s...52#post8520352
1971 K20 Z84 https://67-72chevytrucks.com/vboard/...90#post9047290
1946 B.F. Avery Model A Tractor http://67-72chevytrucks.com/vboard/s...55#post8292555
"Sometimes I wonder if zander208 was even real..."
IronCanine is offline   Reply With Quote
Old 11-20-2014, 09:56 PM   #249
DeadheadNM
Carpe manana
DeadheadNM's Avatar
I cut the inside lip then gently push the windshield up and out. You wont need to make a circumferential cut before it comes loose. Key for re-install is the OEM trim. Avoid my mistakes with repro trim as detailed here: http://67-72chevytrucks.com/vboard/s...d.php?t=484773
Old 11-20-2014, 10:30 PM   #250
72K5CSTDarkOlive
Only way to find out is to try. I'll let you know what I come up with
