Old 06-22-2017, 06:26 PM   #226
whitels1
whitels1's Avatar
Re: 84 K10 Custom Deluxe 5.3 build
Originally Posted by MTCK View Post
That turned out great. Wheeling by this weekend???
Thanks! I wish, maybe next weekend. Still plenty to do!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
whitels1 is offline   Reply With Quote
Old 06-25-2017, 01:13 PM   #227
whitels1
whitels1's Avatar
Finally moving on to other things, cut another 8" off the rear and welded in the bumper. I'm in the process of installing the rear tail lights, and I think I found a good spot to mount the spare.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 07-05-2017, 05:03 PM   #228
whitels1
whitels1's Avatar
It's a bummer my pics don't work anymore, but I got video
Phase 1 completed and I'm happy to be taking a little break.
I got out for a shake down run on Monday, flexed it out and I'm using most of my rear 13" shock without bottoming out. The work was worth it, it wheeled a lot better, although bouncy in the rear without the bed on it! Here is a video of it in action.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 07-05-2017, 09:03 PM   #229
Greenlee
Greenlee's Avatar
Nice! That looks like a blast. Likes like you are crawling up obstacles easier that some of the Jeeps.
Greenlee is offline   Reply With Quote
Old 07-11-2017, 02:15 PM   #230
whitels1
whitels1's Avatar
Thanks Greenlee! It is fun, and I do better than some and not quite as good as others but she get's it done!
Here is a video of a run this weekend, with my 4x4 club.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 08-01-2017, 08:13 PM   #231
whitels1
whitels1's Avatar
A wheelin video from a few weekends ago.
Also I found a hauler for the K10 the build thread is here. http://67-72chevytrucks.com/vboard/s...d.php?t=743708
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 08-02-2017, 02:55 AM   #232
MTCK
MTCK's Avatar
Exciting! What's better than two builds? Three builds! What do you think the K10 weighs?
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 08-02-2017, 03:06 AM   #233
whitels1
whitels1's Avatar
I'm a stickler about GVW so both will get weighed. I'm hoping 4500, and then the Hauler under 7k, but something will probably have to go on a diet, including me!
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 08-08-2017, 10:57 PM   #234
whitels1
whitels1's Avatar
Me and the boys decided to run one of the toughest trails in the Vegas area, at night. It was an awesome time, I bent a tie rod being strapped backwards off a large boulder, we got it back in place and wrapped a soft shackle around it to get me off the trail, it worked good! The whole group made it out without any body damage, and all was going well until the last waterfall, when an LS swapped jeep on 41's decided to bump it and rip the truss off the top of his 14 bolt(More on that in the video). We started the trail at 7:15pm and I didn't get home until 6:00am. No wheeler left behind, we all pulled together and got it off the trail.
A nice evening for a trail ride!
A sketchy bypass, felt worse than it looked!
A spider that almost ate me...
A video
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 08-09-2017, 01:04 PM   #235
daddyjeep
daddyjeep's Avatar
Looks like a great run. How are you finding the truck to work with less weight in the back? I didn't see where you had any traction issues in the video.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939
87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html
04 1500 crew cab
http://67-72chevytrucks.com/vboard/s...d.php?t=786514
daddyjeep is offline   Reply With Quote
Old 08-09-2017, 02:57 PM   #236
whitels1
whitels1's Avatar
It was fun, I really like the trucks configuration, It is a bit light in the back so It will pull a wheel now and then but traction is not an issue if I'm locked. My main problem is the cam I have has no low end power, so that needs addressed, some gears and crossover steering. A trail like that would have been impossible with the bed and length so I'm moving in the right direction.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 11-26-2017, 04:20 PM   #237
whitels1
whitels1's Avatar
It's been a while but got out for some night wheelin last night, here is a video.
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 11-27-2017, 08:41 PM   #238
COS399
COS399's Avatar
Thanks for the video. I bought a 86 k20 with a 5.3 already installed a few months back. The guy left the TH400 and I was thinking that maybe if I found a 4L80E for the right price I might swap it out. It still has the 4.10 gears and could use an overdrive gear when I am running it down the interstate.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 11-29-2017, 03:15 AM   #239
whitels1
whitels1's Avatar
Thanks for watching! An 80 would be a good idea, how does the truck run?
GoldyLS1 K20 Build
My K10 Rock Crawler
-Dave
Old 11-29-2017, 07:37 PM   #240
COS399
COS399's Avatar
The truck runs awesome and the install was nice and clean. He had a couple of wiring gremlins but I corrected the problems and she is SWEET!! It will make my Jimmy conversion a lot easier now that I have something to reference off of.
