Closed Thread
Old 02-03-2015, 12:52 AM   #226
yossarian19
Re: What did you do with your truck today, take 2
Stared at pieces of the wiring harness, declined to solder. Hours later, on my way into the house, I removed the oil filler cap pedestal from the valve cover and screwed the filler cap directly into the valve cover. Looks much cleaner that way.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline
Old 02-03-2015, 01:23 AM   #227
68shortwide
68shortwide's Avatar
Stared at pictures and decided to try and save an ol truck.
Jack
Personal Fleet: Family Fleet:
1955.5 Panel 1959 Apache
1968 ShortWide
1969 ShortStep
68shortwide is offline
Old 02-04-2015, 07:30 PM   #228
57chevyman
57chevyman's Avatar
Got my new front bed panel today
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline
Old 02-04-2015, 07:32 PM   #229
57chevyman
57chevyman's Avatar
New disc brakes
Frank
1957 Chevy 3100
Old 02-04-2015, 08:32 PM   #230
bowt1ed
Nice looking zinc coated rotor there Frank. Who'd you get it from? Jim
bowt1ed is offline
Old 02-04-2015, 08:49 PM   #231
57chevyman
57chevyman's Avatar
I got it from an eBay seller named tomsclassics . The kit came with 2" mcgaughys drop spindles. The whole kit was around $550 delivered to my door
Frank
1957 Chevy 3100
Old 02-05-2015, 10:44 PM   #232
dinosaurdoctor
dinosaurdoctor's Avatar
Sounds like my 48. The more I do the more I see to do.
dinosaurdoctor is offline
Old 02-06-2015, 01:09 PM   #233
DaveCt
DaveCt's Avatar
Knocked the snow of of the '49s temp. garage. Come on spring time!
DaveCt is offline
Old 02-06-2015, 02:04 PM   #234
57chevyman
57chevyman's Avatar
got my fenders and bedsides ready to paint
Frank
1957 Chevy 3100
Old 02-06-2015, 02:38 PM   #235
yossarian19
Last night, trimmed some fat off the coil brackets so I would show a little more of the valve cover. Could relocate but the fenders are crowded enough - maybe later?
"Over my head"
Old 02-07-2015, 09:07 PM   #236
FamilyBowTie
Started the tear down
49 5 window on s10
http://67-72chevytrucks.com/vboard/s...d.php?t=671706
FamilyBowTie is offline
Old 02-07-2015, 09:25 PM   #237
dinosaurdoctor
Looks like you're getting there, My 48 isn't that far along yet. I need to find a place that sells WD40 in 55 gallon drums. Got the engine and trans today, Now to pull the 216 and begin the swap.
Old 02-07-2015, 09:41 PM   #238
FamilyBowTie
A full can of Liquid Wrench and 1/2 a can of break free helped but still snapped prob. 1/3 of the bolts. Not to bad as far as rust, hoping to get the steering column/glass out than the cab off.
Anyone have any links to how to remove the steering column?
49 5 window on s10
Old 02-08-2015, 10:14 AM   #239
la hi
57 swb, 454ci, 700r4,
We, my neighbor who knows how to weld, and I boxed the frame and welded in the cross-member. Today will see more grinding and then this week assembling.
la hi is offline
Old 02-08-2015, 02:27 PM   #240
rrenner
rrenner's Avatar
After first time rebuilding one, finally cranked engine (sbc) about 2 1/2 years into project... got through cam break in, found a couple of small oil pan leaks but all in all pretty satisfied.
1958 Apache short bed
rrenner is offline
Old 02-08-2015, 06:17 PM   #241
bufordtjustice
Cool truck Denny, what paint code is that? Torch red??
Mike
Originally Posted by Denny55 View Post
Really crappy picture, but I put the front fenders on!! Looking like a truck!!
bufordtjustice is offline
Old 02-08-2015, 07:44 PM   #242
OrrieG
OrrieG's Avatar
Off the top of my head, remove steering wheel and shift lever mech if column shift. Remove turn signal if equiped. Remove pitman arm from steering box, remove steering box bolts to frame bracket. Remove bracket that holds column to dash or dash support. unbolt anything else I forgot holding column. Pull box and steering column out thru firewall. Mark wheel and pitman arm locations for reassembly before removing.
OrrieG is offline
Old 02-08-2015, 08:46 PM   #243
itstheshu
Installed my Sid's 3" drop axle and disc brakes. Now it's time for a C notch.
itstheshu is offline
Old 02-08-2015, 11:10 PM   #244
yossarian19
In between fatherhood duties, working on the DD & some minor errands, I got some more soldering done on the engine harness and wrapped up another section. Now have "driver's injecttion", "rear" & "fuse box" left to do.
Also adjusted a wheel bearing... if I'm lucky I'll get the other side done before bed.
"Over my head"
Old 02-09-2015, 05:47 PM   #245
57chevyman
57chevyman's Avatar
before and after pic of 2 inch drop in the front.
Frank
1957 Chevy 3100
Old 02-09-2015, 06:10 PM   #246
Nordic
Nordic's Avatar
Installed new gauge cluster
Nordic is offline
Old 02-09-2015, 06:39 PM   #247
yoshi
yoshi's Avatar
Changed distributer to an HEI, I haven't tried starting it yet as it got too late
yoshi's 49 project
yoshi is offline
Old 02-09-2015, 08:42 PM   #248
57chevyman
57chevyman's Avatar
I like those vintage looking gauges! nice job
Frank
1957 Chevy 3100
Old 02-10-2015, 07:58 PM   #249
capnduane
capnduane's Avatar
Just a couple little things, replaced the rusty, worn valve cover bolts (they were 3 different head sizes) with a nice new shiny set. And then painted most of the waterpump with a brush, what I could reach, with out removing anything. Just cleans up under the hood a bit!
'55 Chevy 1/2ton pickup w/ Pontiac 350 and Muncie M21 close ratio 4speed "Red Ryder"
capnduane is offline
Old 02-10-2015, 08:06 PM   #250
57chevyman
57chevyman's Avatar
sprayed my front panel and tailgate
Frank
1957 Chevy 3100
Closed Thread
