Old 01-04-2015, 05:34 PM   #226
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Originally Posted by slotard View Post
Nice. I could use a pair in that color, haven't seen one in a yard though.
hey bro, you're in Cali do you want this one, I will sell it to you for what I paid for it plus I will go pull the other one for you if it helps, I can always get another fender and if it saves you painting yours its a win win, I can even drive it out half way to your house
Gregski is offline   Reply With Quote
Old 01-04-2015, 05:48 PM   #227
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Header Reinstall
OK got her buttoned up whilst listening to the Colts handle the Bengals on the radio
not perfect, but much cleaner, even wire brushed the manifold bolts, wish I knew how to keep them from rusting again cause painting bolts hasn't worked for me, the paint just twists right off as I install them, also wish some of these pictures came out better
Old 01-04-2015, 05:50 PM   #228
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Passenger Manifold Comparison
and this is just to compare how the passenger side exhaust manifold area looked like when I got the truck and how it looks today, a bit of improvement wouldn't you say
Old 01-04-2015, 07:09 PM   #229
68Timber
I know the pieces fit
68Timber's Avatar
Re: Restoring Rusty
You need to clear those bolts or paint them or something, they rust 10x quicker after being cleaned up w/a wire wheel.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 01-04-2015, 08:07 PM   #230
Jake Wade
Jake Wade's Avatar
Re: Restoring Rusty
Looks better. Did you install new valve cover gaskets?
Jake Wade is offline   Reply With Quote
Old 01-04-2015, 10:15 PM   #231
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
Yes back in October when I painted the valve covers. I special ordered these black rubber Mr. Gasket ones. This time I did not take them off although I fully planned on it cause I thought my oil leak was seeping out from the back of the passenger side valve cover, but I don't think that's the case. Now I am leaning towards the rear main seal as being the culprit as my bell housing is full of black oil and grime, not nice.
Old 01-04-2015, 10:18 PM   #232
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
I need to treat them for sure, still looking for a proper solution since I'm not a big fan of paint on the threads and I strip the paint off the heads as soon as I install them, so need something more better, like Eastwoods blackening dip kit.
Old 01-04-2015, 10:23 PM   #233
slotard
Re: Restoring Rusty
New bolts are zinc coated in most cases. While they may be a little ugly after the decades, when you strip all the zinc off they get rusty fast like any unpainted steel.
1973 C20, 350/350
slotard is offline   Reply With Quote
Old 01-04-2015, 10:57 PM   #234
68Timber
68Timber's Avatar
Re: Restoring Rusty
Yeah, I should have explained a little. I helped a friend freshen up the engine bay in a 78 Corvette he's had a loooong time and we did the same thing with all the bolts for the accessory brackets. Three months later they looked like crap and he had to redo them. Another member here found someone local to him that does the zinc plating, apparently it's fairly cheap to do. You might not care to go that far on this truck but I'd at least hit them with satin black or maybe header paint if you have some. Those will rust like they are.
John
74 Honda Z50 build
Old 01-05-2015, 12:12 AM   #235
Chaplain
Chaplain's Avatar
Re: Restoring Rusty
Good reading. Nice chronicle.
Chaplain is offline   Reply With Quote
Old 01-06-2015, 09:45 PM   #236
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty
thank you
Old 01-06-2015, 09:51 PM   #237
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - TRANSMISSION CONTROL SPARK SYSTEM
I decided I would clean up and decluter the engine bay a bit before bolting on my new intake, carb, and air cleaner, that way I won't get any of that old electrical tape glue and grime on the new shiny bits
so if I may borrow a term from the Import Crowd, I will be "deleting" the Transmission Controlled Spark System, TCS
say what?
The Transmission Controlled Spark System is used on all 10 Series vehicles, C-K20 suburban, G20 Series and G30 Sportvans when equipped with a manual transmission.
lucky me
so what does the TCS do?
Control of exhaust emitted by vehicles using the eight cylinder engines, is accomplished by eliminating ignition vaccum advance when the vehicle is operating in reverse, neutral or low forward gears
sounds great - lets get rid of it
Old 01-06-2015, 10:12 PM   #238
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - TCS Time Relay
first we introduce the five usual suspects
TCS Time Relay, this bad boy hides behind the brake booster on the fire wall, I am just going to unscrew it, (one bolt) and leave it plugged in to the wiring harness which will be yanked out anyways
Old 01-06-2015, 10:19 PM   #239
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - TCS Temperature Switch
next is the TCS Temperature Switch, this redundant temperature switch lives in the right cylinder head between the #6 and #8 exhaust ports (unlike it's much more useful cousin in the left cylinder head between #1 and #2 exhaust ports)
for now I will just unplug the single green wire from it and leave the temp switch in the head, sometime later on when I feel like draining the coolant (again) I will replace it with a nicer plug
Old 01-06-2015, 10:23 PM   #240
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - TCS Vacuum Advance Solenoid
the TCS Vacuum Advance Solenoid sits in the front right of the intake manifold, next to the oil filler cap in the photos, both pictures show the same solenoid just from different angles as it is buried behind the heater core hoses
Old 01-06-2015, 10:27 PM   #241
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - TCS Idle Stop Solenoid
the fourth component the TCS Idle Stop Solenoid attaches to the front of the carburetor, shiny bit in the photos, and is there to prevent dieseling
Old 01-06-2015, 10:37 PM   #242
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - TCS Transmission Switch
the fifth and the final component is the TCS Transmission Switch located on the lower driver side of the transmission, I plan just to unplug it and leave it there
mine is grimmy but it should look something like this
Old 01-07-2015, 07:04 PM   #243
rusty76
rusty76's Avatar
Re: Restoring Rusty
Thanks for the info!
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 01-08-2015, 03:13 AM   #244
Super_Dave
Super_Dave's Avatar
Originally Posted by Gregski View Post
so if I may borrow a term from the Import Crowd, I will be "deleting" the Transctiption Controlled Spark System, TCS
In our neck of the woods, when we perform certain functions of a similar nature, sometimes involving the use of brass fittings in hot places... we call it "optimizing."
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair
"Life is tough - wear a cup!"
"Old Enough to Know Better - Too Young to Resist"
"Junk is something you will need three weeks after you throw it away."
Super_Dave is offline   Reply With Quote
Old 01-08-2015, 03:17 AM   #245
Super_Dave
Super_Dave's Avatar
... wish I knew how to keep them from rusting again cause painting bolts hasn't worked for me, the paint just twists right off as I install them, also wish some of these pictures came out better
Fluid Film. Good for a lot of things...
http://www.fluid-film.com/
Old 01-08-2015, 11:31 PM   #246
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Removing the TCS Wiring Harness
Four of the five Transcmission Controlled Spark System components (the Idle Stop Solenoid being the exception) hang off of the same wiring harness, which plugs in to a single brown wire on the firewall leading to the fuse block.
I was able to unplug the harness from all of them except for the Transmission Switch. It is simply impossible to see how it plugs in, and you have to feel up in there, so I am still unable to disconnect the one last final wire to be able to completely remove this wiring harness.
Old 01-08-2015, 11:34 PM   #247
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Idle Stop Solenoid
The Idle Stop Solenoid connects to the fuse block using its own single brown wire
Old 01-08-2015, 11:44 PM   #248
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Engine Wiring Harness
I am one of those people who needs to know where things go, wants to know where they go and how they work, so i had to gently unwrap the crusty 40 year old wiring harness.
Old 01-08-2015, 11:48 PM   #249
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Fuse Block Wiring Harness
I just like to see where these wires go, so here is the fuse block side getting unwrapped
Old 01-08-2015, 11:53 PM   #250
Gregski
Post Whore
Gregski's Avatar
Re: Restoring Rusty - Fusible Link
check out that Fusible Link, looks good right, wait till I unwrap the harness, all of a sudden it doesn't look so good
