Old 05-05-2015, 04:45 PM   #226
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: My 1961 crew cab- XRMYCRU
some pics of the parts:
the fender and step both need rust repair at the bottom where they join together.
the fender also needs some rust repair where the sheet metal folds over the inner brace where it joins to the box.
the core support was decent , but had a little rust in the corners; I cut the bottom out of another rusty one I had for the patch panel.
I got some rust converting paint on the inside of the cab, and roof, I also sanded down the joining edges with 36 grit, so that they will stick when I glue it together.
I also sectioned the front cross member 2 inches- I referred to this thread for the how to:
http://67-72chevytrucks.com/vboard/s...d.php?t=543729
I did all the cutting and prep work, and I have it over at a buddys shop (he has a big mig, and is certified) to get welded up.
Old 05-08-2015, 06:08 PM   #227
jonzcustomshop
1961 crewcab
got the cross member and 3 inch dropped spindles back today, waiting on springs; as of now the drop up front is 5 inches!
Old 05-08-2015, 06:20 PM   #228
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
That'll look good on the truck!
Old 05-08-2015, 09:08 PM   #229
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Cross member looks good.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 05-13-2015, 12:22 AM   #230
jonzcustomshop
1961 crewcab
starting on the frame. I am using a 66 30 series 133 inch wheelbase frame.
got these pics early today of what I did a couple days ago- got one spring moved back 10 inches-
I didn't take any more pics, but today I got the other spring moved, and then drilled the 6 holes in the front to move the cross member forward 1 inch.
todays spring was a little easier, because all I had to do was copy what I did on the other side... the first was more difficult because it needed to go back 10 inches, but it was no as easy as just measuring 10 inches from the old holes.. since the frame goes up as it goes back I had to get a straight line with a square, and then measure off of that. when it was all done the front perch ended moving up about 1 3/4 to 2 inches as well as bac 10.
in the front I ran onto the same problem with moving the 6 holes forward an inch, the frame and holes taper towards each other and are not in a straight line, so I had to use a couple squares t off the radiator support cross brace to get the holes forward in the right spot. today was one of the days that I could have used an extra arm to hold the squares and scribe the marks!
Old 05-13-2015, 01:30 AM   #231
Bomp
Bomp's Avatar
With moving the springs back and up will it drop the rear or will that matter? Great Build
Bomp is offline   Reply With Quote
Old 05-13-2015, 06:26 AM   #232
aerotruk63
aerotruk63's Avatar
Are you going to get rid of a few leafs for a better ride?
Old 05-13-2015, 04:08 PM   #233
jonzcustomshop
1961 crewcab
I think it dropped the rear a few inches .I am going to do a "flip kit" and I have a C notch to put on, so that should get the back way down... my only worry now is that it might be lower in the back than the front..
for now I am going to leave it, but I bet I will in the future. we'll see how bad it is first.
as of now the bottom of the spring hangs 1/2 inch below the frame rail, and with measuring the bottom of the spring pack is about 1 1/2 inches above the bottom of the backing plate... that puts the bottom of the backing plate 2 inches below the frame rail as of now. so I will be real curious to see where it actually sits when I put it all back together...
Old 05-14-2015, 12:16 AM   #234
jonzcustomshop
1961 crewcab
more frame shots of yesterdays work:
today I got those brackets cut off the back, fitted the front cross member, and cleaned up the bottom of the frame.
Old 05-14-2015, 09:58 AM   #235
CHIZZLER
CHIZZLER's Avatar
Looking good.
61-crew cab D-max
Old 05-14-2015, 11:24 AM   #236
piratexpress1369a
piratexpress1369a's Avatar
wow what a massive job ..i like what i see going on here ..stay at it
My 63 GMC Panel Slow Build
http://67-72chevytrucks.com/vboard/s...=1#post5457281
63
piratexpress1369a is offline   Reply With Quote
Old 05-14-2015, 10:40 PM   #237
jonzcustomshop
1961 crewcab
got the frame painted today,- the bottom 1/2 I'll have to flip it and get the top still.
I also pulled the rear cab mounts off, they were the vulcanized rubber style, I will be switching to the c/10 style, and moving them 30 inches to the rear to accommodate the crew stretch.
I cut the trailing arm mounts off the rear (quite a job! I need a plasma cutter!, I used a combo of cutoff wheels a sawzall and a grinder...)
the rear is a 65, and the code shows it is a 3:73 posi!
https://onedrive.live.com/?cid=9169a...5CFC6D79%21354
also since I moved the springs back 10 inches I will have to extend the rear of the frame 10 inches, I am tempted to cut the rails just in front of the rear bumper mounts and put the new pieces in between so that I still have have all the factory mounting points.
Old 05-19-2015, 10:25 PM   #238
jonzcustomshop
1961 crewcab
alright! up on wheels. I got the front suspension all assembled. I have a 2 inch pancaked cross member, 3 inch dropped springs, and 3 inch dropped spindles. I am a little worried about the spindles, I am running 15's, and the wheel is awfully close to the lower control arm. it does not touch though.
I was wondering if the back was going to be too low, and end up lower than the front, but fortunately as assembled right now the center of the frame rails are level. so I should be able to get just the right amount of rake with the tire size. I assume that the front will come down a bit more with the engine as well.
I have a "monster C notch " left over from an air ride kit that I bought for another project. The bottom of the frame rail is just touching the axle right now. so hopefully I can mount the notch a little farther down, and not lose too much bed space.
how much room do I need between the top of the rear axle and the bottom of the notch?
Old 05-19-2015, 10:52 PM   #239
66-PMD-GMC
The 60-66 GMC/Pontiac guy....
66-PMD-GMC's Avatar
I leave 3 inches... fully assembled and aired to ride height.
Building Genuine Pontiac Firepowered cars and trucks for several decades.
Why Pontiac?? That's just me daring to be different.
Projects..
63 C10 Short Wheel Base fleetside (The Pro-Street) currently under reconstruction.
440CID 2X4 Pontiac
66-PMD-GMC is offline   Reply With Quote
Old 05-20-2015, 02:33 AM   #240
Dinos63
chevy only
Dinos63's Avatar
man aton of super nice work kat
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 07-07-2015, 09:41 PM   #241
jonzcustomshop
1961 crewcab
some progress:
the spindles I got were used , and had been drilled out to use with a dropmember and a rack. I was able to get a kit from these guys: http://www.ruffstuffspecialties.com/catalog/34SET.html
and then bought some tube and had my friend josh from runninlowcustoms run them in his lathe and weld them up to the stock inner tie rods.
next was to mount captainfabs power steering bracket 1 inch forward and 2 inches up. he supplies this great template with his kit, and not thinking I measured 1 inch forward and 2 inches up off the template and then drilled some holes-whoops the frame is curved and that was not right!
so after a minute of head scratching I leveled the frame , clamped the pattern on and drew a level line on it,,Then marked and drilled the correct holes... turned out only two go through the frame , the other two are above it.
you can see the correct holes marked they are the hand drawn X with the circle around it.
after I got the box on I was able the see where I needed to chop a 2X11 chunk out of the frame to make room for the steering linkage.
I also needed to trim a tiny bit off the front radiator core support mount to clear the box as well.
*** can any one coach me on this steering box??
it sat out for a while and I think got water in it , I pulled the top off, and drained it, the fluid was thin, but there was no rust on the gears, but now I might have messed up the adjustment nut in the center of the cover (by messed up, I mean just that it is probably not replaced in the same spot that it was...)
any tips would be great, or if needed I have about 4 4X4 73-87 boxes that are still hooked up and complete, if they interchange with the 2wd box..?
Old 07-07-2015, 09:56 PM   #242
jonzcustomshop
1961 crewcab
you can see that 1/2 of the power steering bracket sits above the frame rail.
I stitch welded the bracket to the frame and then added gussets to the portion above the frame.
next I cut and bended some 3/16 steel plate and welded in the notch for the steering linkage.
after that I got started on the "massive C notch" in the rear:
I was originally just going to do a deep pipe notch since there was room to do it, but then I remembered that lakeroadster had done a post on the strength of various notches: http://talk.classicparts.com/showthr...964#post96964/ after reading through his post I decided that the tube type C notch was the way to go.
if I was running a coil spring setup and all the rear of the frame had to do was hold up the box and bumper, then I would have just done the pipe notch, but since the rear of the frame supports the leaf springs I decided to go with the stronger notch.
as of now I have 6 inches of clearance between the rear and the notch, and the notch just goes 3 inches above the frame rail, so I might only lose about 2 inches of box space.
Old 07-07-2015, 11:12 PM   #243
joe231
joe231's Avatar
Nice progress Jon!!
The 2wd and 4wd boxes don't interchange
Here is the procedure for the sector shaft adjustment
"GM procedure
Disconnect the pitman arm from the sector shaft, completely back off the sector shaft adjusting screw on the sector shaft cover.
Center steering on the "high point" then attach an inch lb torque wrench to the steering wheel shaft, the torque required to keep the shaft moving for one complete turn should be 1/2 - 2 in lbs.
If the torque is not within these limits, loosen the thrust bearing locknut or tighten valve sleeve adjuster plug to bring the preload within limits.
Tighten the thrust bearing locknut and recheck preload.
Slowly rotate the steering shaft several times, then center the steering on high point.
Now, turn the sector shaft adjusting screw until a steering shaft torque of 3 - 6 in lbs more is required to move the worm through the center point.
Tighten the sector shaft locknut to 35 ft lbs and recheck the sector mesh adjustment.
Total steering gear preload should be 14 in lbs or less.
Install the pitman arm and replace back in vehicle.
NOTE: To try and adjust the sector shaft screw without doing the preceding will DAMAGE the steering gear.
Most of the play is not in the sector shaft adjustment, it is the spool valve area.
Other way:
now comes the tricky part, time to adjust the shaft. I looked at my 4wd shaft to see how far out the stud was from the locking nut, this will get you pretty close. GM states that you should use a torque wrench to find all these measurements but I found it easier to do it by feel. grab the rag joint and turn it lock to lock like you would with the steering wheel. If you do not feel any resistance when your steering is in the middle. Loosen the locking nut and using a allen in the top of the stud turn it a few turns clockwise, tighten back down the lock nut. Turn the rag joint again from lock to lock until you feel it get tight in the middle. Once you feel it get tight back off the stud just a little at a time locking down the lock nut after each adjustment test until you cant feel it get tight anymore. This is when you know you have it adjusted correctly. Make sure all of the bolts are tight and you are ready to go."
CHEVY ONLY
Old 07-07-2015, 11:22 PM   #244
CHIZZLER
CHIZZLER's Avatar
Looking good jon. Should be able to get back at mine once the porterbuilt stuff shows up.
61-crew cab D-max
Old 07-09-2015, 12:09 AM   #245
jonzcustomshop
1961 crewcab
thanks, joe, does that non torque wrench method still have the pitman arm removed?
here are a couple pics of the front notch clearance.
and I had an hour today, so I was able to get the insides of the c notch mounted.
Old 07-09-2015, 05:22 PM   #246
jonzcustomshop
1961 crewcab
just about done with the notches, all I have to do now is weld around the perimeter..
Old 07-10-2015, 10:02 AM   #247
piratexpress1369a
looking good stay at it
63
Old 07-10-2015, 10:14 AM   #248
Lokin4AReason
Lokin4AReason's Avatar
nice progress =0)
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
Old 07-10-2015, 11:03 AM   #249
66-PMD-GMC
66-PMD-GMC's Avatar
I guess I'm not paying attention. ..
I thought you were building 2 trucks on this thread... a crew cab and a lowered frame dragger...
After re-reading the last couple pages... I see you're building a crew cab frame dragger... :-)
Projects..
440CID 2X4 Pontiac
Old 07-11-2015, 12:34 AM   #250
jonzcustomshop
1961 crewcab
yep, actually just doing one build right now. not the usual 3 at once!
I am hoping the stance turns out like this:
http://67-72chevytrucks.com/vboard/s...328048&page=11 -post # 253
