Old 08-15-2017, 05:34 PM   #226
meenaggie
Re: No Limit Trailing Arm Rear Suspension
Originally Posted by moregrip View Post
excellent solution! do you expect those bushings will be a wear item?
Thanks for the compliment. I had them made from oil-impregnated bronze in an effort to make them "self-lubricating". I also put some synthetic grease on them during assembly for good measure and to help hold them in place. I am not expecting them to be a wear item based on the truck's limited use (i.e. not a daily driver), but I will keep on eye on them when I go to grease the trailing arm end joint.
meenaggie is offline   Reply With Quote
Old 08-15-2017, 05:44 PM   #227
meenaggie
Originally Posted by Cbo View Post
Yes,exactly.
So I measured the brackets from No Limit I have and they are 2-5/8" (plus or minus 25 thousandths) wide from inside edge to inside edge.
Old 08-16-2017, 12:31 PM   #228
robnolimit
robnolimit's Avatar
Yes,exactly.
Please give me a call with dimensions. If we sent you incorrect brackets we will send new ones. 865-940-1503
GoodGuys 2012 Pro-Truck Champion
2012 Truckin' Throwdown Champion
GoodGuys 2011 National Champion
2011 Truckin' Throwdown Champion
GoodGuys 2010 National Champion
Proud to put our products up against all others!
robnolimit is offline   Reply With Quote
Old 08-17-2017, 09:55 AM   #229
Cbo
Hey @robnolimit it was no big deal. I had a friend with a porto-power help me spread them the 1/16 or 1/8 inch I needed to get them in. I appreciate it though!
Cbo is offline   Reply With Quote
Old 09-15-2017, 11:50 AM   #230
tigerchevelle
Originally Posted by robnolimit View Post
Update. Cory brought his truck out to Cruisin the Smokies for two days of Auto-X fun, and we did a little tuning. The truck showed us very quickly that without the ability to tune the front shocks, the trucks performance wall came up pretty quick. We could have 1) increased neg. camber, 2) added more positive caster, 3) added some toe-out, but we were trying to keep it in very street friendly trim. Also, we were having too much fun to get real serious. The truck handled great, and drives smoother and more predictable than ever. Cory did finish 2nd in the truck class - first was a supercharged Trail Blazer SS - hard to beat the ABS and traction control. With some driving under his belt now, Cory is eyeing a WideRide IFS to replace the current set up. If you are interested in the Hotchkis TVS components and brakes, it is now for sale.
What wheel and tire size and backspace on this truck? I love the look and want that setup for my 70
tigerchevelle is offline   Reply With Quote
Old 10-28-2017, 06:15 AM   #231
Cbo
@robnolimit
So, the rest of the kit went on fine,and looks great. I went ahead and ordered your C-notch kit so that will be the next step for me,as I installed 2inch blocks with the kit,just like you guys did on your shop Truck. One more question though.
Did you guys have to add a shim or use angled lowering blocks? I'm really not digging the driveshaft angle coming from the rear...
Old 11-13-2017, 11:00 AM   #232
Cbo
@robnolimit nothing on using angled shims?
Old 07-27-2018, 01:29 PM   #233
NoLimitCody
Hello guys,
We've updated some of our instructions for some of our kits to make all of our products more understandable and user friendly.
In addition to the Trailing Arm Kit we also offer the 63-72 Panhard Bar kit and 63-72 Shock Relocation Kit separately to fit the original trailing arms and frame. For those interested here they are, they will also be available on the website shortly.
NoLimitCody is offline   Reply With Quote
Old 07-27-2018, 01:32 PM   #234
NoLimitCody
continued...
Old 07-27-2018, 01:33 PM   #235
NoLimitCody
Continued again....
Old 07-31-2018, 12:32 AM   #236
SierraMtns
SierraMtns's Avatar
NoLimitCody,
I feel special you guys used my pictures in your instructions. lol
SierraMtns is offline   Reply With Quote
Old 08-24-2018, 10:25 PM   #237
71GreenJunk
17 5/16" measurement from rear of frame on the No Limit shock relocation kit looks like it's for a short bed. Anyone know the measurement for a longbed? Unfortunately my '71 seems to be one of the few without the 5/8" hole punched from the factory. And the given measurement puts it way too far back.
71GreenJunk is offline   Reply With Quote
Old 08-25-2018, 09:44 PM   #238
gringoloco
A guy with a truck
gringoloco's Avatar
Long beds are 20” longer, 12” in front of wheels, 8” behind. Based on that, 25 5/16” should put you where you need to be
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 08-26-2018, 04:58 AM   #239
71GreenJunk
Thanks!!!
Old 10-20-2018, 12:51 PM   #240
Rickjz
The thread that never dies!!! I installed the trailing arm kit on my 71 Blazer. What do you do about the coil over spring being loose when you jack up the vehicle?
Rickjz is offline   Reply With Quote
Old 10-20-2018, 02:29 PM   #241
gringoloco
A guy with a truck
gringoloco's Avatar
Assuming you’ve got the ride height set where you want it, you could:
- add a lowering block between the trailing arm and axle
- move the upper coilover mount up
- use a shorter coilover shock body
- haul a couple hundred pounds of gravel
-Chris
Old 10-21-2018, 10:45 AM   #242
Rickjz
Gringoloco, you have had some nice rides! This is what I have so far. I think that a shorter shock is the best option. I plan on lowering it as far as I can without floor/frame interference.
Old 10-23-2018, 03:53 PM   #243
robnolimit
robnolimit's Avatar
I recommend that you wait until the body is on. Looks good. BTW, kinda odd to see a SBC in a build now a days. Like it!
Old 10-23-2018, 04:38 PM   #244
SCOTI
SCOTI's Avatar
Sad statement right there. I'm all about the technological advancements of the LS platform, but the SBC is always a solid choice.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-24-2018, 02:42 PM   #245
turbotruck
on the rear coilover setup is the shock vertical?
turbotruck is offline   Reply With Quote
Old 10-24-2018, 02:48 PM   #246
turbotruck
and on gringo locko picture the shocks are in front of the axle, yet in your digram they are behind
Old 10-24-2018, 05:09 PM   #247
SCOTI
SCOTI's Avatar
Gringoloco is using a Porterbuilt rear set-up which is why the C/O's are behind the axle.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-24-2018, 08:03 PM   #248
Rickjz
The body is on the frame now. Sadly, I've been doing this project for 28 years. When I started, dropped spindles from a 73 and cut coils was the best you could do! I'm glad I waited. Today I would have done a LS motor. The SBC should get the job done though, especially with a 4 speed tranny.
Old 10-26-2018, 10:15 AM   #249
turbotruck
sorry i meant rickjz's photo
Old 10-26-2018, 04:36 PM   #250
SCOTI
SCOTI's Avatar
The images above from NoLimit are the shock relocation kit which places the shocks behind the axle when using the stock Truck Arms & coil springs. The No Limit coil-over set-up puts the C/O's in front of the axle about where the factory coils would be but outboard of the frame & T/A.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
