04-16-2022, 07:33 PM | #226 |
Re: 59 Apache/C6 Corvette build
Tailgate bumper bullet installed and front bumper dialed in. The ends turned our great. #HammerFab
Current project: 59 Apache with 2012 Corvette drivetrain Jeep Trackhawk(beast) |
04-16-2022, 07:37 PM | #227 |
now that is a tight bumper. on the roads around here the body flex would likely cause some scratching.
looking good. |
04-16-2022, 10:48 PM | #228 |
that bumper is awesome nice fab work
04-17-2022, 12:16 AM | #229 |
Good point. I agree. Rubber pucks mounted on each fender to prevent touching in extreme conditions will keep it from touching. The frame is pretty stiff, but worth putting in protection.
Current project: 59 Apache with 2012 Corvette drivetrain Jeep Trackhawk(beast) Last edited by tdishon; 04-19-2022 at 12:42 AM. |
04-19-2022, 09:50 PM | #230 |
incredible fab work..... nice touch on the dimples you put in the bed where it bolts up to the rear fenders.... very very nice. I'll be following
05-01-2022, 05:23 PM | #231 |
Grill done. Baby steps.
05-07-2022, 12:03 AM | #232 |
Hood latch is beefy. Release lever is inside the cab.
Current project: 59 Apache with 2012 Corvette drivetrain Jeep Trackhawk(beast) Last edited by tdishon; 05-07-2022 at 12:11 AM. |
05-07-2022, 12:07 AM | #233 |
Time for the firewall...
05-07-2022, 04:49 PM | #234 |
Hammerfabs work is awesome!!
"Fear makes the wolf look bigger" http://67-72chevytrucks.com/vboard/s...d.php?t=305629 |
05-09-2022, 10:40 AM | #235 |
Yeah, so much talent being shown off in this build.
All good stuff!! Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
05-09-2022, 05:46 PM | #236 |
This is so good I dont even know what im looking at.
My Current Trucks: 1958 Apache BBW 4.8LS/4l60 "Lucky" Built By Me 1958 GMC BBW LS1/4l60 "The Kraken" Built By Delmo |
05-09-2022, 05:51 PM | #237 |
LOL. I never liked the clunky factory hood latch, so I went with a Volvo semi truck hood latch with a 360 degree wrap around pin for safety. Smaller aftermarket or common VW latches need a safety backup because it doesn't wrap around the whole pin.
05-10-2022, 07:44 AM | #238 |
just the security alone of having the hood release inside would be nice. i've been trying to figure out some kind of hood lock.
05-10-2022, 09:54 PM | #239 |
6dof i used a bear claw with electric seloniod works great
05-10-2022, 10:16 PM | #240 |
Maybe something like this? I had one of these on my last car and it worked perfect.
05-11-2022, 01:30 PM | #241 |
i cant' find those cables with lock anywhere but straighofftheboat.commie
05-11-2022, 01:44 PM | #242 |
I'm not sure where to get them. I bought mine on Ebay a few years ago.
05-16-2022, 02:26 PM | #243 |
Door gap time. I think this is everyone's favorite thing(to avoid).
05-16-2022, 02:58 PM | #244 |
the rounded corner really makes it
05-18-2022, 09:25 PM | #245 |
Looks good. Hammer fab does amazing work! Your truck is going to be top notch.
http://67-72chevytrucks.com/vboard/s...d.php?t=780018 Jason’s 56 build |
05-19-2022, 04:18 PM | #246 |
I really like all the brazing that happens here. I wonder why that and not just regular welds?
05-19-2022, 04:43 PM | #247 |
The brazing is only to eliminate body filler. Easy to sand compared to welds. Everything is welded, but low spots can be filled and sanded somewhat like lead. It is a lifetime hold compared to body filler. Now, it will still need a skim coat of body filler before paint, but this will just eliminate any weakness or spots.
05-19-2022, 06:57 PM | #248 |
thats what I was gonna say too, long lasting filler. some body guys are not crazy about it but it works. I have seen a few original seams done with brazing on the task force trucks. dash braces, some A pillar areas and around the windshield opening seams
05-19-2022, 08:19 PM | #249 |
It does add a little strength compared to filler, but I don't think they had any in the 50's. Well lead... It does fill the void with low heat so it doesn't cause warpage like welding.
05-20-2022, 10:16 AM | #250 |
I have done a complete teardown on a few task force trucks, like drill out spot welds and take apart to individual panels, and have found that the dash mount tabs on each side at the A pillar were brazed, the A pillar window doglegs were brazed, some of the windshield opening parts were brazed. not sure but it sure looked factory to me. I have also seen some old bodywork on these trucks that was done in brazing. I remember back in the 70's when I was learning to gas weld with the torch on body steel I would braze sometimes because it warped less and was easier to grind, it does plug up a grinding disc easily though, no flap discs available back then.
