#2476 |
Re: What did you do to your truck today!
Installed a Holley electric fuel pump, and installed a new vacuum modulator on my turbo 400 as the last one was allowing tranny fluid to pass through to the vacuum line right to the carb.
#2477 |
Tightened my steering gear a little. Big difference. Should have done it 6 months ago.
#2478 |
Removed heater core/box, removed cowl panel from below windhield, cut out the old 6cylinder exhaust pipe and muffler. Removed tail lights, reverse lights, clutch pedal, door panels, instrument cluster
Also had to grind off some welds. The previous owner installed a sheet of steel that covers the wood bed and he welded it to the front, sides and back of the bed. It was a PITA, but luckily i had enough patience.....and a grinder with 3" cutting wheel.
1967 Chevy swb stepside-work in progress 2005 GTO-daily driver 2001 F250-weekend car crusher 1956 Chevy Pickup-sold |
#2479 |
I did cut a low hump cover the same border as big hump to install it in my truck.
I've a camaro floor shifter but the cable is short with the big hump and with the low hump i'll have about 2 1/2 inches and I expect now will move more smooth and soft. |
#2480 |
went to the brothers show and won lowest truck
#2481 |
Took the truck to cruise night and decided to adjust the timing once again to try and get rid of this damn stumble on low speed driving. Now sitting at 12BTDC and will get my vacuum gauge to adjust the idle mixture this week hopefully.
Mike Email: Click here to email me -- 2019 Silvedrado 4x4 1970 Chevy 3/4 ton, 396BB, on air bags |
#2482 |
Finally removed the dash pad for dyeing. Reinstalled the ignition switch. Removed some more PO wiring tangles. Mounted my door panel trim in preparation to mounting the door panels (powdercoated). Will be reinstalling the seat, seatbelts, ashtray, radio blockout. Removing the metal radio mount from under the dash. Probably going to a single, oil pressure only, gauge set-up. Slowly completing the interior. Soon will get back under the hood to correct some more wiring issues, then hit the road.
#2483 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
mORE BOARDSANDER ACTION TODAY....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#2484 |
Installed pushrods and roller rockers yesterday
Installed intake, carb, and temp installed valve covers
Always remember those that had your back Never forget those that turned it Demon 68- C20 (conv. 5 lug) 406sb, TH400, 12 Bolt, Red Slut 09- 1500 Crew Cab Z71, 2.5" Lift, Comp Cam, Deleted AFM/DoD, Diablo tuner |
#2485 |
Washed and waxed everything. Powerwashed the undercarriage and engine and bed. Now I drive it and save up for some nefty goodies.
Susie-Honda Accord Coupe|Elisa-1968 Chevy C20 Holdin' it down in the 520
#2486 |
Bought some new Stainless Steel door sills with the chevy emblem on them to replace the chrome ones in there now that the passenger one is a bit rusty in one corner. Normally I would leave it but this year will be my first car show that I have a vehicle to enter and I want the truck as close to perfect as possible.
Here is a picture I found online of what it looks like.
#2487 |
I cut the right rear corner off the bed for a buddy to use on his truck, then took the torch to the bed bolts and took it off the frame, found out there is a serious rust problem, but hey, that's what makes it a project right
Rob 72 C/10 (under reconstruction)(destruction ? LOL) 48 Willys CJ2A 1952 Super "A" Farmall (Grandfather's) |
#2488 |
Old Skool Club
![]() Join Date: Jun 2001
Took my rear end and driveshaft to be sandblasted and painted.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#2489 |
PROJECT 7DEUCE
More mud....board sander and more mud..... this is getting old..
#2490 |
Grandpa in the rustmobile...
Went outside this AM to my DD 68 started it backed up a few feet and it died.
Bad ?modulator? (half moon thing in dizzy) luckily I had a spare ![]()
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#2491 |
i had bought some [URL="http://www.12vcity.com"]car parts, wanted to travelling
#2492 |
I was actually thinking of selling it! And I am looking for a new one too! Anyone here would like to give me any suggestions on what to buy next?
#2493 |
well for the last few days I have been doing body work inside the bed. and on it to get it finished where i am happy enough. I went and laid some paint this week and here is what so far I have come up with. dont mind as some of the paint is still wet but it gives a good look IMO I also will be spraying the center section gloss black in a few days. and dont mind I still have some minor body work to do.
![]() http://67-72chevytrucks.com/vboard/s...d.php?t=442487 My Picture Gallery http://67-72chevytrucks.com/gallery/...0&ppuser=36004 |
#2494 |
Starting to dismantle the front clip to replace the drivers side fender and hood. Got the grille, trim, and cowl pulled tonight before it got too dark...
1979 Silverado C10 Shortbox - Photo Album 1977 Silverado K20 Camper Special - Photo Album 1972 C10 Custom Deluxe Highlander - sold 1971 Cheyenne Super Longhorn -sold 1972 Cheyenne Super SWB 4x4 -sold, bought back, sold again... I'm dumb. 1970 Chevy C10 SWB "Sprout" -sold 1972 Cheyenne K20 -sold 1969 GMC Shortbox Stepside 4x4 -sold 1972 GMC Jimmy 4x4 -sold |
#2495 |
adapters/spacers and new draglite wheels and new dunlope tires... finished undercoating
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
#2496 |
Final prep for paint tailgate and hood. Got drivers' door half way there. Tomorrow paint. The next day 5 years and an unknown amount of hours and money will turn an obsession into reality
GENERALM |
#2497 |
Painted the firewall and inner fenders. Pressure washed it, scrubbed it and sprayed it all black. My buddy has a paint gun, and he had some extra black paint. I just bought a little paint thinner and taped her up... Not exactly a 100% attention to every little detail here, but I didn't want to pay a shop to do it.
Before, during and after pics ...
Thank you god for all your blessings! My mini build (I had a great starting point) http://67-72chevytrucks.com/vboard/s...d.php?t=440743 |
#2498 |
I pulled the cowl panel off getting ready to unbolt the front end. Cut the back bumper off and that later model bumper and push bar off. I removed the front panel from the rusty bed I pulled the other day, it is perfect. I'm gonna have to replace the back half of the frame it's swiss cheese. I did find a donor, just haven't got it yet, price is right trading scrap for scrap! You know what they say one man's junk is another man's treasure!
#2499 |
Cleaned up/painted the tranny. Test fit/adjusted the new Lokar shifter so i don't have to do it when its in. Bolted tranny to motor....its going in tomorrow!!!!!
My 72 Suburban Build - http://67-72chevytrucks.com/vboard/s...d.php?t=454019 79 Volvo Turbo LS Build - http://67-72chevytrucks.com/vboard/s...d.php?t=594252 Buggy Bed for son - http://67-72chevytrucks.com/vboard/s...d.php?t=657350 |
#2500 |
Bought a Gas Tank Carpet Kit and a Fiber Board Cover.
Hello members... I'd like you to know that I sold, my 72 GMC (Ratikle), back in November of 2011. I don't visit the site much anymore, but please feel free, to drop me a private message. RIP...."RATIKLE" |
