Old 10-06-2021, 01:18 AM   #2476
89AKurt
89AKurt's Avatar
Re: What did you do to your truck today.The 3rd chapter
Rust bucket....
https://youtu.be/IUM_Qn01_vs
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 10-07-2021, 07:27 PM   #2477
zellway
zellway's Avatar
My long put off 67 work truck is finally getting a little love. Noting too crazy but should look good from 20 feet away 😄
Erik
My 69 suburban http://67-72chevytrucks.com/vboard/s...d.php?t=530626
1970 C10 step Project Jiminy http://67-72chevytrucks.com/vboard/s...d.php?t=682647
RUST!? Thats just mother natures way of telling all of us.....MINE!!!!
zellway is offline   Reply With Quote
Old 10-08-2021, 06:52 AM   #2478
Jiggers72-GMC
Jiggers72-GMC's Avatar
Right on Erik, the grille looks real nice .....
Gerry, North Bay Ontario
1971 Chevy K10 short stepper, 518 med green & white
1972 GMC C1500 long box, dark Brown, owned since 1977
1969 GMC C2500 manual
Jiggers72-GMC is offline   Reply With Quote
Old 10-08-2021, 12:44 PM   #2479
67C10Step
67C10Step's Avatar
Installed new dash pad and started to clean up and fix up the instrument cluster. Anyone have tips to repair a printed circuit with a bit of delamination? All my instruments and lights worked when I took this apart so I know the circuit is good. No need to replace it, just tidy up a few small places.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
67C10Step is offline   Reply With Quote
Old 10-09-2021, 07:08 AM   #2480
Jiggers72-GMC
67C10Step, I remember that game as a child, 'one of these things doesn't belong here', that's the first thing I thought of when I saw the Yota grille, not sure how to fix the printed circuit, no offence intended
Old 10-09-2021, 10:54 AM   #2481
67C10Step
67C10Step's Avatar
Jiggers,
Ha! Only about 50 years difference in those parts. That grill is off my son’s truck. He wanted the TRD PRO grill and now I have that one left over. Got it listed for sale as those new are about $300.
I saw where some folks were repairing with flexible CA glue so I’ll try that. All my traces are solid, just a few lifted from the plastic and a few edges delaminating at it.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 10-09-2021, 03:32 PM   #2482
Rich72C10
Mr. Cheyenne
Rich72C10's Avatar
Got my 72 Rochester Quadrajet carb back from Cliff's High Performance. Straight on the the truck she started up and darn near sounded perfect! She needs a lot less idle screw than my '78 Carter Qjet, which I found interesting. I can't believe I wasted $450 dollars with Quadrajet Power and then all that time between Jan 2012 till June 2021. I highly recommend Cliff Ruggles, he is a dream to correspond with and he'll even call you up to chat if he has any questions (yes, call you on the phone).
After dropping my vacuum gauge into my radiator fan (doh!) and getting a new one, I got the idle mixture screws all dialed in. O'Riley's had one but darn thing is about -2 off zero out of the box. I used it and my timing light (its digital with RPM) to get it what I believe is correct. I should have just used the timing light / RPMs and not gotten that "new" vacuum gauge from O'Rileys.
Man, this carb rocks, not one blip anywhere on my test drives. When I nail the gas to WOT at the stop signs I get a better burn out too! Man, I wished I had a Posi 3.73 rearend, instead of my open 3.08 LOL
Richard
'72 Chevy C10 Cheyenne *Super WHT/MED BRONZE/WHT
SBC 350 | TH350 | LWB | AC | Buddy Seats
Upgrades: Tilt | Front Sway Bar | Radio | Sliding Window | Bed Spare w/Lock
Bed Rails | Full LEDs | Courtesy Lights | Tachometer | Glovebox Lock & Light | Head Light Relays | *Upgraded Fully Super Trim
Rich72C10 is offline   Reply With Quote
Old 10-09-2021, 06:11 PM   #2483
Sparky dave
I blocked off my oil cooler ports on my gen 6 454 without removing bypass valve which caused low oil pressure spin a rod bearing bent a valve wiped a can lobe and shattered piston and rings and destroyed my engine on first start up after6 weeks of work on engine conversion. I feel sick
69 longbed 350 700r4 3.73 POSI cruiser
Sparky dave is offline   Reply With Quote
Old 10-09-2021, 11:18 PM   #2484
Carl Spangler
Carl Spangler's Avatar
This is probably worth a separate thread.............. with more info on what/why the motor got toasted.
1971 SWB step side: Original NM Forestry and then NM Fire truck
Carl Spangler is offline   Reply With Quote
Old 10-11-2021, 02:25 AM   #2485
zellway
zellway's Avatar
Thanks. I have been putting this truck off for so long. Just about everything needs some work but little by little it’s getting better looking.
Erik
Old 10-11-2021, 11:02 AM   #2486
67C10Step
67C10Step's Avatar
Did get the instrument cluster re-done and back together over the weekend. Not back in the truck yet but ready to go.
By the way, if you have a delaminating printed circuit the rubber reinforced CA Gorilla Glue works really well.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 10-11-2021, 12:08 PM   #2487
1968 K20
Over the weekend was able to get the hood, cowl, front inner fenders and the bed undercoated/bed lined.
1968 K20 is offline   Reply With Quote
Old 10-11-2021, 07:30 PM   #2488
72c20customcamper
72c20customcamper's Avatar
Can’t wait to see it all together .
Made the truck work today moved around 2 pear an apple and plum tree to be planted. Had to go buy wire fencing to keep the deer away . They will kill them quickly. Damn things will eat the whole sapling down to the trunk .
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-12-2021, 02:23 PM   #2489
pilotXC
Not today, but on Saturday got tires swapped onto my re-painted stock wheels... Getting close to being where I want it. Few more interior details to go.
1972 K20 Cheyanne
1956 VW Bug
LQ4/4L80E Swap: https://67-72chevytrucks.com/vboard/...d.php?t=796095
pilotXC is offline   Reply With Quote
Old 10-13-2021, 11:41 AM   #2490
Chevys4life
Looking good!!!
Chevys4life is offline   Reply With Quote
Old 10-13-2021, 11:44 AM   #2491
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Originally Posted by Chevys4life View Post
Looking good!!!
X2! Nice truck.
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 10-13-2021, 01:28 PM   #2492
30772
Installed this custom (my 81 year old artist Dad made it), hand-made Dash Plaque for a nice, unique, interior finishing touch....
30772 is offline   Reply With Quote
Old 10-13-2021, 01:48 PM   #2493
Ol Blue K20
Looks nice.
Dale
Old 10-14-2021, 12:32 PM   #2494
zellway
zellway's Avatar
But more progress on my work truck. Was just going to do some basics to make it nicer but it’s starting to look like a nice truck.
Erik
Old 10-14-2021, 03:20 PM   #2495
67C10Step
67C10Step's Avatar
zellway,
Looking really good.
I put the refurbed instrument cluster back in and up against the new dash pad I like the way things are starting to look. My truck needs some rust repair but I know what will happen if I start to tackle much of it right now. I'll look and the whole thing will be in pieces again and it will be another two years before I drive it. I think I'll have everything I want to do complete by spring and can drive it a while and settle on a color. THEN, I won't feel bad about pulling it all apart again. But I will have the majority of frame/suspension/steering work already done. Be just bodywork and paint, which will be a big enough job.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
Old 10-14-2021, 07:45 PM   #2496
zellway
zellway's Avatar
That looks great. I kinda wish I had kept my dash more original looking like yours.
Originally Posted by 67C10Step View Post
zellway,
Erik
Old 10-14-2021, 08:10 PM   #2497
Boog
laying low
Boog's Avatar
Hey neighbor. You have been pretty busy on your truck and it's looking good. That bed wood is awesome!
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 10-14-2021, 08:58 PM   #2498
Ol Blue K20
Hey Boog is back! I can quit worrying about ya!
Dale
Old 10-15-2021, 07:06 AM   #2499
Sparky dave
I will do iv been in time out for a few days to get to terms with it. Thanks for the interest
Old 10-15-2021, 08:32 AM   #2500
67C10Step
67C10Step's Avatar
Jim,
Glad to see you back! I've been meaning to text you but just haven't taken the time. Been using all my spare time on the old truck to make some progress.
Thanks for the comments. I may have went too far on the wood. Probably should have just painted it but I can always do that at some point.
I'll holler at you sometime to see if you got time for lunch or something.
1967 C10
1980 Jeep CJ5
2020 Toyota 4Runner
2024 Toyota Tundra
