07-14-2010, 02:56 AM | #2576 |
Re: Project Vitamin C-10
Alan thanks for showing the steps on how to make a patch panel, you made it look easy and effortless, you do have a gift there with metal working...Vernski
07-15-2010, 04:49 PM | #2577 |
Thanks, Allen, for the patch panel detailed pics; awesome as usual. What is the name of the material you are using for filler?
-Mike from Alabama Why do we park on a driveway, and drive on a parkway? Jake - '67 Short Step Dirty Dan - '80 Short Fleet |
07-15-2010, 04:57 PM | #2578 |
07-15-2010, 05:57 PM | #2579 | ||||
1 thing at a time is progress.
Nope! Until you break something Quote:
There's a lot more where those came from.
Alan
Philippians 2:14-16 |
07-15-2010, 10:27 PM | #2580 |
Member of the longbed union.
do you paint them Orange so you know if someone in the shop jacked you?
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
07-15-2010, 10:56 PM | #2581 |
In our shop it's not a matter of getting jacked, but easy to identify when someone needs to borrow some. It also makes them easy to see in dark places.
Alan
07-17-2010, 12:00 PM | #2582 |
Ronnie (198plus) is getting ready to bring his cab to me in a couple of days so I tried to find something I could knock out pretty quick on my truck, so I drug my hood out to work on it and it is worse than I remember from a year ago. The reinforcements on the front and rear are ate up with cancer.
The shell is in pretty good shape. Just a slight depressed area towards the back of the "V" rib. There are some dents but nothing major. I want to replace the front and rear reinforcements with some good ones that I have taken out of some other hoods. But first I need to build a crib of some sort to support the hood. Once I remove the reinforcements it will fold up like a pretzel. I'm trying to figure out the best and easiest way to support it. I'd like to build it out of wood. I'm thinking of using plywood and cut out ribs to match the profile of the hood and wrap with foam. The thing is I don't have any wood and by the time I go to the store it will be a wasted day. I also need to get the reinforcements blasted. If I had a bigger compressor I could do it at home. But I don't. So here I sit trying to think of something else to work on. I've got a thinking problem. LOL BTW still looking for my other (passenger) vent window frame that I painted last year.
Alan
07-17-2010, 12:59 PM | #2583 |
I am trying to find parts for my tilt today. Dang I know I hand them just the other day....well 6 months or so ago. I know if I buy new pieces, I'll find it the minute the order ships.
Good Luck on your find Alan. Can't wait to see you tackle the hood.
07-17-2010, 04:28 PM | #2584 | |
After a little thinking time I thought why not use the old hood shell to support the hood that I'm working on. I figured both of them together would support each other. It seemed to work out pretty good. The old shell for support I drilled the spot welds and busted them loose with a air hammer very carefully. Then use a block of wood and 3 pound hammer to knock it out of the folded over area. I then took a wide screw driver and opened the flange up that I knocked it out of so I could slide the new one back in. I put the new one in temporarily so I could see how it was going to act. It worked out pretty well. Then it was one to patching the sides of the hood. I used some old cowl extensions I had left over. They have the perfect contour for the hood. One side I laid the piece I cut out of the hood for a pattern. Then tacked it in. I had to be carefull not to weld the reinforcement in place with my tacks, since it will be coming back out later for blasting, prime and paint. The other side of the hood I had to reverse the way I made the pattern. I cut the new piece larger then used it as a pattern then clamped in place and made my cut on the hood. This is where it is at now. I will be removing the reinforcement and cleaning up my welds on the inside. Then I will paint the inside of the hood and the reinforcements then put the reinforcement back in. Yes when I weld it back in I will have some burnt areas from welding, but at least there will be some paint in the areas that can't be seen and impossible to get paint on. I will repair the burnt areas when I repaint the inside of the hood.
Alan
07-18-2010, 01:07 PM | #2585 |
Under Construction
Nice work Alan!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
07-18-2010, 02:23 PM | #2586 |
I really like what you've done with the truck. I wish I could that kind of body work, I guess I need to get me some more tools.
Jeremy 1965 Chevy c10 Short Stepside Check out my Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=410658 |
07-21-2010, 10:22 PM | #2587 | |
thanks Heath
I'm still working on the hood some. I took vacation this week and didn't even go out in the shop Monday and Tuesday. I did go out today and helped Shannon on his cab. Made some progress on the hood, but nothing worth taking pics of. Check out Shannon's build for some good progress pics.
Alan
07-21-2010, 10:51 PM | #2588 |
Well hopefully I can learn more from you and the rest of the guys from the forum. I'm looking forward to see your truck done.
07-22-2010, 11:42 PM | #2589 | |
I put the hood on hold. I'll finish the rest of the truck and hopefully they will repop them by the the time I'm done.
Alan
07-23-2010, 02:33 PM | #2590 |
I took today and took my oldest daughter out in the shop for some father/daughter time. She said she wanted to build a car, toy car that is. She wanted to build a "mater". She hasn't had much hands on yet due to air tools etc. But she said she wants to paint it.
As I was making it, it dawned on me this would be a great exercise for those that want to learn how to work with metal, but are scared to cut on their truck. There are a lot of the same steps involved and will get you some experience working with metal. Anyway here's what we have done thus far. Took a toy apart for the wheels and axles. I cut out the rear wheel opening. I had to notch out so the tires could fit. It want be sitting this low, she wants it to sit up normal. I like it low. This is the way it is now. I've got to cut out the engine bay, make the frame, bed floor and wrecker frame and cable. We will see how it turns out.
Alan
07-23-2010, 02:46 PM | #2591 |
The Few, The Proud
The bed gap doesn't look even and the door doesn't match the rocker...... What kind of work are you turning out over there?
Seriously though, that looks great. What the the plans for it? 22's, bags, stroker? Details man we need details.
Shannon |
07-23-2010, 03:55 PM | #2592 |
Daring to be Different
I don't know Allan? You have way too much time on your hands.
Good practice though
Dennis Check out my 65/73 Cheap Build Thread. http://www.67-72chevytrucks.com/vboa...d.php?t=327644 KUSTOM RIDES FACE BOOK PAGE: https://www.facebook.com/groups/291198124258863/ 1965 C-10 Short Bed 350/700r4 2012 Silverado 1500 Crew Cab 2016 Honda Accord w/ 18" rims 2007 Honda Goldwing Trike w/ NAVI 2001 Yamaha Roadstar Indian look alike "Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...WOW!...what an amazing ride!" Live Life Passionately!!! [/COLOR] I AM WE TODD IT, I AM SOFA KING WE TODD IT |
07-23-2010, 05:49 PM | #2593 |
Nice Alan. That is one scream'n mater.
07-23-2010, 08:08 PM | #2594 | ||
You darn tootin'. You never know what I will be working on next when you click on this build.
Alan
07-23-2010, 09:15 PM | #2595 |
Don't worry when they hit the 20's they will think your Kewl, and like you again.
07-23-2010, 10:31 PM | #2596 |
I see the money just pouring in on this one Alan. That looks so sweet.
07-23-2010, 11:36 PM | #2597 |
SSN 706
Very kewl. Somthing about the back of the cab just doesn't look right though. It's not a f#rd is it? Good to you spending time with the girls.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 07-23-2010 at 11:37 PM. |
07-24-2010, 01:26 AM | #2598 |
60-66 Nut
Kudos to you Alan for spending some time with your daughter. This is something you both will remember for a long time to come. Make the time whenever you can 'cause before you know it they'll be all grown up and out of the house.
07-24-2010, 01:35 PM | #2599 |
Under Construction
Nice.
07-27-2010, 12:04 AM | #2600 |
HOW long until spring??
Way to go Alan . I like to have my daughters help me on projects.
Now they are bringing their friends over since our house is a fun place to hang out. Be careful or she will be wanting to be drive your truck to school someday!!
69 chevelle convertible 71-C-10 short-wide and low 64 C-10 custom shortbox "Bubba"s Recycling project" |
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
