Old 04-30-2024, 06:22 AM   #26026
Wikid61
Wikid61's Avatar
Re: Facebook Marketplace finds
1971 Chevrolet 1500 regular cab Long Bed
$5,200
Listed 6 weeks ago in Alpine, AL
About this vehicle
Driven 1,000,000 miles
Automatic transmission
Exterior color: Blue · Interior color:
Fuel type: Gasoline
Seller's description
1971 Chevy Cheyenne, new exhaust, gas tank, locks and ignition are keyed the same. New door parts not installed. Has exterior rust, floor are fine. Motor runs great
Alpine, AL
Location is approximate
Seller information
Mike George https://www.facebook.com/marketplace...type=top_picks
Wikid61 is offline   Reply With Quote
Old 04-30-2024, 06:24 AM   #26027
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...type=top_picks 72 Lwb c10
$6,000
Listed 5 days ago in Arlington, TX
Old 04-30-2024, 06:29 AM   #26028
Wikid61
Wikid61's Avatar
71-72 C10 Grille Shell
$225
Listed 3 days ago in Concord, NC
Details
Condition
Used - like new
1971-72 C10 Brand new was used for mock up it does have some dents. I did my best to show them in the pictures. https://www.facebook.com/marketplace...30525996%22%7D
Old 04-30-2024, 06:31 AM   #26029
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...30525996%22%7D 1970 Chevrolet C-10
$10,000
Listed 3 days ago in Guilford, CT
Details
Condition
Used - Good
1970 C-10
350
4-speed new process A-833
Brand new posi 3.73
Cpp Tubular motor mounts
Cpp 2” drop spindles
Cpp 4” lowering springs
Cpp Brake booster
New brakes
New radiator
New clutch
New drive shaft
I have new fenders, wheel wells, radiator support
Truck runs drives stops
10k great project just needs to be finished
I have ton of other parts as well
Original title
Currently registeredd
Old 04-30-2024, 06:38 AM   #26030
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...0-2771213bfb57 1970 c10
$3,000$3,200
Listed a day ago in Oneida, TN
Details
Condition
Used - Good
350 3 speed truck was running And driving when parked 3 years ago pretty solid truck not rusted out I have the title and keys 3,000 obo may trade for a Harley
Old 04-30-2024, 06:41 AM   #26031
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...7-0ed722ed52a3 1968 Chevrolet c-10
$6,000
Listed a day ago in Greencastle, IN
About this vehicle
Driven 22,000 miles
Manual transmission
Clean title
This vehicle has no significant damage or problems.
1968 C-10. Starts, drives, and stops. 250 inline 6 motor. Starts right up and idles great.
The good:
Whole new brake system consisting of all 4 wheels having new drums and springs kits, all new brake lines and new master cylinder. New radiator. New water pump and thermostat. New valve cover gasket, oil pan gasket, and rear main seal.
The bad:
Does leak oil. Do not know where it’s coming from especially after replacing all those gaskets and main seal. Can explain more if interested. Trailing arms have holes rusted in them. Passenger side floorboard has rusted hole as well. Turn signal lever is broken somewhere in the column but still works sometimes.
The truck is still solid for 56 years old. $6000 obo. Thanks!
Old 04-30-2024, 06:46 AM   #26032
Wikid61
Wikid61's Avatar
1970 Chevrolet c10
$9,000
Listed 12 hours ago in Front Royal, VA
About this vehicle
Driven 86,000 miles
Exterior color: Blue · Interior color: Blue
1970 C10 383 stroker tricked trans nice Lil hot rod could use some tires runs and drives come check it out
Front Royal, VA https://www.facebook.com/marketplace...0-2771213bfb57
Old 04-30-2024, 06:47 AM   #26033
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...2-7806b91c0b1f 1969 Chevrolet 1500 regular cab Custom
$7,950
Listed 9 hours ago in Collinsville, TX
Old 04-30-2024, 06:51 AM   #26034
Wikid61
Wikid61's Avatar
1970 Chevrolet chevy van g10
$2,500
Listed 15 hours ago in Burnsville, NC
About this vehicle
Driven 100,000 miles
Exterior color: Brown · Interior color: Brown
Fuel type: Gasoline
This vehicle is paid off
C10 v8 automatic. No title
Burnsville, NC
Location is approximate https://www.facebook.com/marketplace...d-b660be171525
Old 04-30-2024, 06:54 AM   #26035
Wikid61
Wikid61's Avatar
1969 Chevrolet c/20
$3,000
Listed 4 days ago in San Angelo, TX
About this vehicle
Driven 1,000 miles
Exterior color: White · Interior color: Blue
Fuel type: Gasoline
Clean title
1969 3/4 ton long bed fresh barn find,runs and drives needs a battery,350 motor,400 transmission come's with wood bed as show in picture's plus the original bed. $3,000.00
Old 04-30-2024, 06:55 AM   #26036
Wikid61
Wikid61's Avatar
1968 Chevrolet 1500 regular cab Long Bed
$6,000
Listed 21 hours ago in Jacksonville, NC
About this vehicle
Driven 123,456 miles
Exterior color: Blue · Interior color: Black
Fuel type: Gasoline
2 owners
Clean title
This 1968 Chevy C10 Long Bed is an Antique. It has the original engine 250 straight 6. 3 speeds in the tree. Has New Gas Tank, Radiator, New Tires with rims power steering and a title. In the back of the truck has 350 small block engine included with the truck. Truck has only surface rust body is solid, add will we taken down when sold no need to ask.
Old 04-30-2024, 06:56 AM   #26037
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...2-7806b91c0b1f 1969 Chevrolet 2500 regular cab
$14,000
Listed 23 hours ago in Glasgow, MO
Old 04-30-2024, 07:23 AM   #26038
Wikid61
Wikid61's Avatar
1969 Chevrolet c10
$44,000
Listed a day ago in Beaumont, TX
1969 Chevy C10
69 c10 original short bed not cut down. Clean Texas title in my name,Truck came from Kentucky. New 71-72 bumper and grille shell with billet insert. Rebuilt 6.0 with rattler cam, rebuild 4l80 with shift kit and new fti 3600 lock up converter. New steering column, new gear box and all tie rods replaced along with control arm bushings and ball joints. New old air products ac/heat with new vents installed, low mount compressor. New seat foam and cover. New bed wood and strips, wood stained and marine spar finish on them. Intellitronix dash installed. Stainless exhaust with v band clamps, through crossmember and over axle with spin tech mufflers. Ptfe fuel lines and walbro pump. https://www.facebook.com/marketplace...2-7806b91c0b1f
Old 04-30-2024, 07:29 AM   #26039
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...d-b660be171525 1972 Chevrolet 1500 regular cab Long Bed
$3,400
Listed 2 hours ago in Easley, SC
About this vehicle
Driven 12,346 miles
Exterior color: Orange · Interior color: Tan
Fuel type: Gasoline
1972 Chevrolet C10 350 automatic longbed. It has some rust in the rockers but the bed is solid. The frame is really good. It has power steering but no power brakes. The hood latch is missing. The glass is good. The truck cranks and is yard drivable. It does not have any rust on the bottom of the doors. The rust is in the rocker panels and cab corners. It is titled as a1972 but I believe the frame is a 69 and the cab is a 72. $3400 in Easley SC. I will not take any less so please no offers. I will delete them.
Old 04-30-2024, 07:34 AM   #26040
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...d-b660be171525 1968 CHEVY C10 - 50TH ANNIVERSARY GOLD
$5,500$6,000
Listed 20 hours ago in Rising Sun, MD
Details
Condition
Used - Good
No trades. I will not answer offers sent over messenger. Please only contact if you are genuinely serious with cash and a time in mind.
Price is only negotiable in person, I’m located in Rising Sun MD.
I’m listing this 50th Anniversary 1968 Chevrolet C10 for sale. It’s a single cab, long bed, 2WD truck powered by a recently rebuilt 355 and 3-speed automatic. Clean title in hand.
The truck starts, runs, drives, shifts, and stops fine as it sits. The engine was built under 1000 miles ago (by previous owner-no paperwork) and has been bored .030 over with a mild camshaft. It has a new battery, new tool box, and Rally wheels. Everything else is stock.
This is a factory 50th Anniversary Gold special edition trim, and it seems to be wearing all of the factory paint. The body is surprisingly straight with some cool patina. The frame has plenty of surface rust but is overall solid. The cab supports, cab floor, doors, and bed floor are rough as far as rust goes, but the truck looks decent nevertheless.
The interior is all original and in decent shape. The white upholstery has held up surprisingly well and the lights/radio/horn work.
You can drive this home as-is, but it definitely needs some love. The factory manual drum brakes are sketchy and the Quadrajet carburetor isn’t the best. I have cruised it around town a few times but it’s still a project.
Message me and come today. Thanks!
Rising Sun, MD https://www.facebook.com/marketplace...d-b660be171525
Old 04-30-2024, 08:46 AM   #26041
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...2-7806b91c0b1f 1969 GMC sierra (classic) 1500 regular cab SL Pickup 2D 6 1/2 ft
$26,500
Listed a day ago in Rodessa, LA
Old 04-30-2024, 03:04 PM   #26042
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...type=top_picks 1971 Chevrolet other
$18,999
Listed 2 days ago in London, OH
About this vehicle
Driven 125,000 miles
Exterior color: Red · Interior color:
4 wheel disc breaks
New ball joints
New tyrods
New idle arm
New shocks
New coil springs
New master cylinder
New break lines
4 row radiator
Vintage air system
New TH400
New elder block carburetor
New tires
New power steering pump
New fuel pump
Electric windows
London, OH
Seller information
Old 04-30-2024, 03:06 PM   #26043
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...type=top_picks 1971 Chevrolet k20
$5,250
Listed 17 hours ago in Tignall, GA
Old 04-30-2024, 03:08 PM   #26044
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...type=top_picks 1972 Chevrolet 1 ton truck
$4,500
Listed a day ago in Clinton, NC
Old 04-30-2024, 03:11 PM   #26045
Wikid61
Wikid61's Avatar
1968 Chevrolet classic
$15,000
Listed 4 weeks ago in Ridgeway, VA
About this vehicle
Driven 333 miles
1968 Chevrolet Classic · Truck · Driven 333 miles
68 C-10 Truck 4- wheel disc brakes, new seat- still in plastic, 327 motor w/ 350 transmission, 20” staggered wheels, Good cruiser.
Ridgeway, VA
Location is approximate https://www.facebook.com/marketplace...type=top_picks
Old 04-30-2024, 03:13 PM   #26046
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...type=top_picks 1968 Chevrolet 1500 regular cab
$28,000
Listed 21 hours ago in Fairfield, CT
About this vehicle
Driven 12,345 miles
Manual transmission
2 owners
Good running truck
Fairfield, CT
Seller information
Ed Firgeleski Jr
Joined Facebook in 2009
Sponsored
Old 04-30-2024, 03:15 PM   #26047
Wikid61
Wikid61's Avatar
1967 Chevrolet c10
$5,000
Listed 4 hours ago in Alliance, OH
About this vehicle
Driven 85,765 miles
I have two trucks for sale. One is a 1969 GMC. C 10 2 Wheeldrive for sale for 2500 or best offer comes with two cabs then I have the jacked up 4 x 4 orange ones in 1967 BAD TRANNY 5000 or trade has bad gas in it but still runs
Alliance, OH
Seller information
https://www.facebook.com/marketplace...1-a93fb56e92dc
Old 04-30-2024, 03:17 PM   #26048
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...1-a93fb56e92dc 1967 Chevrolet 1500 regular cab Long Bed
$4,000
Listed 6 days ago in Midlothian, VA
About this vehicle
Exterior color: Gold · Interior color:
Fuel type: Gasoline
1967 Chevy K10. Does not run. Good project or parts truck. Cab in bed not included.
Midlothian, VA
Seller information
Nathan Hughes
Joined Facebook in 2024
Sponsored
Send seller a message
Old 04-30-2024, 03:19 PM   #26049
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...1-a93fb56e92dc 1967-1972 Chevy truck parts
$1,111 · In stock
Listed in Mocksville, NC
Details
Condition
Used - Fair
Parting out a couple 1967-1972 Chevy trucks
Message for prices and info
Mocksville, NC
Seller information
Jeremy Allen
(27)
Sponsored
Old 04-30-2024, 03:21 PM   #26050
Wikid61
Wikid61's Avatar
https://www.facebook.com/marketplace...type=top_picks 1968 GMC 1500 regular cab
$1,800
Listed 15 hours ago in Essex, MD
About this vehicle
Driven 80,000 miles
Exterior color: Grey · Interior color:
The truck drives well. 350 with a rochester quadra jet carb.
-Automatic
-Gauges do not work
-The cab and bed is in rough shape
-Comes with both rocker rocker panels, cab corners, dash pad, new diff cover, and an extra passenger door.
