08-21-2010, 07:24 PM | #2626 |
1 thing at a time is progress.
Re: Project Vitamin C-10
Started to work the Lt bed panel. First I worked on shaving the chain area and the rear stake pocket.
I left this piece a little long and once I welded it I trimmed to fit. Alll done with chain area and rear stake pocket Moved on up the bedside to another problem. I tried heat to straighten this out with no luck. I put it on the vise and beat it back into submission and welded what was left of the hole. This is where it is now. Got pulled away.
Alan
Philippians 2:14-16 |
08-22-2010, 12:56 AM | #2628 |
60-66 Nut
I'm really happy to see you fill in that little notch.
I think every rear of a truck I've seen that has been 'shaved' this little detail has not been done, and it bugs the crap outta me. This is just another example of the fine detail that sets you above most of the guys Alan
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 08-22-2010 at 12:57 AM. |
08-22-2010, 07:56 AM | #2629 |
1961 crewcab
I like the "chevrolet" logo on the 2002-2006 avalanche tailgates.. I always wanted to put it on a project... however I found out that those tailgates are plastic...
is there a way to bond that logo to a smooth metal gate? that would be my suggestion!
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 08-22-2010 at 08:01 AM. |
08-22-2010, 11:45 AM | #2630 |
I'm with captianfab
I agree that notch should be filled by all with out chains, it is just another detail that many over look, but Alan's Keen eye for detail is at it again and definitely will be apparent when in shows. Tailgate script or no script I prefer the original script tailgates, this is my opinion. I don't like the script on the Mar-K tailgates, it is different from original and reversed from original and does not suite me, I like the latch system and wish they would make us a kit to adapt to the original tailgates and as for the links to hold the tail gate those are Ok too in keeping with the original equipment later models or the newer cables are cool too, So Alan in your case I'm voting for the non script and then you can letter it or do what ever design on the tailgate you wish, but what ever you do it will be detailed and cool we are all waiting to see what you do and then drool. |
08-22-2010, 06:30 PM | #2631 | |||
I use these pull pins to handle the panel until it is ready to weld then use tape to hold it where I want it til it is tacked. Since I removed the stake pocket I needed a reinforcement to brace it up. Getting ready to wipe. This is all I can wipe at one time due to the heat (97 in the shop). Due to the heat I have to reduce the hardener that is used, in turn the crust stays sticky longer. It kicks really fast but due to the sticky crust it gums up the sand paper. Sometimes I can wipe the sticky stuff off with a laquer rag if I can't wait. It's still drying now. I should be able to sand pretty soon when it is fully cured without using thinner. First wipe Nine wipes later. It took almost an hour just to wipe it. I couldn't take my time like I usually would. I just had to get it on as quick as possible.
Alan
08-22-2010, 07:02 PM | #2632 |
What product are you using on your wipes?
Thanks! |
08-22-2010, 08:44 PM | #2633 |
I love this stuff, but it's about $40/gallon. I knocked the crust off with 36 grit on an assortment of air tools. I don't like blocking so I do as much with air tools as possible. Then I went over it with a long block with 80 grit. Still have a few low spots that need attention.
Alan
08-22-2010, 11:13 PM | #2634 |
1961 crewcab
I like that you are showing this part...
most of the time you see a bare metal shot, and then a shot of finished with paint.. I think that alot of people don't realize that to get any vehicle super straight like the 6 figure show cars, there will be a skim coat of some sort of filler over the whole vehicle...might only be a millimeter thick, but it will be there.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
08-22-2010, 11:22 PM | #2635 | |
Member of the longbed union.
I like the stand Alan.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
08-23-2010, 01:00 AM | #2636 |
One day...
Yeah the heat makes you move a lot faster especially when it your money going into the materials that dry fast
Is that a Hutchins line sander? You like it? I have heard good and bad about them but i guess its all in how you take care of them.. |
08-23-2010, 09:06 AM | #2637 |
Under Construction
nice progress!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
08-23-2010, 01:00 PM | #2638 |
283 Drama Queen
As usual, beautiful work - Alan.
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
08-23-2010, 01:17 PM | #2639 | |
08-24-2010, 12:02 AM | #2640 | ||||
Went out tonight did more sanding and filled some low spots. I'll knock it down tomorrow. KMACD71 did this in Photo shop for me. He took the letters off the T/G. He said doing a color change can't be done. I'm trying to find out what is needed to see my vision. Maybe I can do a search for a Hugger orange truck and just have the PS guys do some changes. That should be OK don't you think?
Alan
08-24-2010, 01:52 PM | #2641 |
Rollin' Old Skool
hey Alan, i have this pic if it helps any...not hugger orange, but maybe a photoshopper can work with it
08-25-2010, 02:09 PM | #2642 |
Shloooooong bed member #2
Alan,
I ran across this today. |
08-25-2010, 11:16 PM | #2643 | |
I also did some searching. I haven't found an orange one yet with the view I am looking for. I did find TR65's truck with the perfect angles. Thanks TR for letting me use pics of your awesome truck. I just hope the PS guys can work with the color. They mentioned dark colors and white are hard to work with. I don't believe it is white but a light gray.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 08-25-2010 at 11:44 PM. |
08-28-2010, 09:43 PM | #2644 |
Had a little shop time today. Blocked on the bedside with 80 with air tools then blocked it by hand with a long board. Around the wheel arch needs more attention as well as a couple more areas. I sprayed guide coat to see where I have been, plus to check his/lows.
Here's a neat trick for those hard to reach areas when spreading filler. I use an acid brush. I tried another video of how to block into a curve, but I'm not happy with it(my performance). It could have been better arranged and thought out. Maybe I wouldn't stumble as much. I'm having problems getting the video link working like I want it too. I'm doing what I normally do but the video box doesn't show in the message.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 08-28-2010 at 10:04 PM. |
08-29-2010, 06:43 PM | #2645 |
Man alan I wish you and me were closer I would bring my bed to you after I get the metal work done to smear it. I hate that part. Progress looks good.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
08-30-2010, 10:00 AM | #2646 |
Under Construction
nice progress Alan!
08-30-2010, 11:03 AM | #2647 |
alan thanks for the tip. I'm looking forward to that video!
Robert 1965 Chevy C10 http://67-72chevytrucks.com/vboard/s...d.php?t=374373 1997 Chevy K2500 6.5 diesel |
09-02-2010, 10:39 PM | #2648 | |
I hope to get it remade soon. Somedays we all have bad days in what we do best. I couldn't get the filler like I wanted so I had to rewipe the bottom section.
Alan
09-03-2010, 12:26 AM | #2649 |
Alan if you want I'll just bring you my cab and bed, and you can make a video. I'll be the cam guy and will sell it for $20 a pop.
09-04-2010, 10:58 PM | #2650 | |
I need to make this statement. I know that there are several people that follow this build. There are a couple products that I use and have recommended. Slick Sand being one of them. While I feel comfortable using it, it might not be the right thing for others. In a nut shell read the label and talk to paint reps and make an educated decision on what is best for you. Now that is over on with the build. The left bedside is getting closer. I installed the fuel door to see how it looks. This a great seat for working the bed, it's almost at the perfect height.
Alan
Philippians 2:14-16 Last edited by Alan's Classic; 12-05-2010 at 07:01 PM. |
Tags |
1959, 1960, 1964, 1965, 1966, c10, hugger, impala, orange |
