Closed Thread
Old 08-16-2015, 03:41 PM   #2626
mud.man.rj
mud.man.rj's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by 88fordf150 View Post
Pushed it outside for a bath.
Whooo. like to here that run, she isn't an 88F150, may have to change your handle to chevy power.
1987 Green n Green machine.
5.0 4spd std.
7" lift w 35's.
mud.man.rj is offline
Old 08-16-2015, 09:14 PM   #2627
kingstrider
kingstrider's Avatar
I changed the door locks and ignition key to a set that only uses one key instead of two. The hardest part was removing the window crank and door handle, I didn't have a tool so used the rag trick. At least now I can finally lock my doors. Oh I also ordered some more parts from Classic Industries and saved nearly $50 thanks to the 'dog days of summer' sale. That included a new front lamp harness to replace the one that Bubba hacked up.
kingstrider is offline
Old 08-17-2015, 05:31 PM   #2628
TheCougarine
TheCougarine's Avatar
Put on this cool old front plate from the 70's I found online.
TheCougarine is offline
Old 08-17-2015, 10:36 PM   #2629
9teen69
9teen69's Avatar
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline
Old 08-17-2015, 11:50 PM   #2630
toolboxchev
Tried to R & R the Pitman Arm, ugh! Even the tool I rented will not pull it off. Years ago when I replaced the steering box the dang thing almost dropped off, now it wont budge.
Even ground down the out side of the arm at the shaft to get the tool to fit better.
Progress yet no results.
toolboxchev is offline
Old 08-18-2015, 10:55 AM   #2631
hamjet
hamjet's Avatar
I put on some decals and made a new Colt shifter while listening to Hank on the 8 track.. life is good...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline
Old 08-18-2015, 11:07 AM   #2632
9teen69
9teen69's Avatar
[QUOTE=hamjet;7277402]I put on some decals and made a new Colt shifter while listening to Hank on the 8 track.. life is good...[/QUOTE
That shifter is too cool and love the sticker!
9teen69 is offline
Old 08-18-2015, 03:35 PM   #2633
TheCougarine
Originally Posted by 9teen69 View Post
Thanks!
Old 08-21-2015, 04:33 PM   #2634
jethro5333
new fuel tank in. get it hooked up then I can get the interior back in. have to wait til I heal up some more from surgery. not supposed to pick up anything heavy and that seat ain't light.
jethro5333 is offline
Old 08-21-2015, 05:54 PM   #2635
cooperhw
cooperhw's Avatar
Got my truck (Homer) to start, stop, go forwards and backwards. Not far mind you (about 10') but under his own power none the less. Milestone after 8 long months of blood, sweat, and tears. Few grinding discs, and some welding wire.:met al:
"Life is too short to drive a boring vehicle".
Later,
Wayne
cooperhw is offline
Old 08-21-2015, 06:11 PM   #2636
64chevtruck
I made another adjustment to my caster and camber that worked excelent, Ground down my brake calipers and added a 1/4 inch wheel spacer so I could run stock rims with rings and moons. Then went on a trip to the beach,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline
Old 08-21-2015, 06:25 PM   #2637
CST10
CST10's Avatar
Post Re: What did you do to your truck today? Chapter II
Nice truck.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 08-22-2015, 11:23 AM   #2638
fartblossom
fartblossom's Avatar
I finally stopped my oil plug leak. PO had over-tightened the plug and messed up threads. I tried a simple single oversized plug and no luck. Then I tried this double plug from Dorman and added some high temp sealant to the treads.
http://www.autozone.com/external-eng...hv/133360_0_0/
Since over-tightening again would be no bueno, I slowly tightened it, checking for seeping every 20 minutes, first two times it leaked I tightened an eighth of a turn and waited. Finally stopped. WOOT!
fartblossom is offline
Old 08-22-2015, 04:27 PM   #2639
firedemon
went to start the truck this morning to go to work real hard start and when it did it ran like I was missing a cylinder or two. once I was able to get the rpms up it smothed out but you could still tell something wasn't right . I managed to get it to work poped the hood took off the air cleaner sprayed the carb out good blew some compressed air through the passages still crap . pulled the plugs all look good so I checked the timing because I keep it just loose enough to adjust it when needed couldn't get it to settle out . pulled the cap found the problem points almost closed on high lobe distributor was bone dry it must have rubbed the plastic down enough to close the gap it was 3 thousandths . being a little broke at the moment I had to cheat it a little put some antisieze on the cam and rubbing block on the points to help slow the wear till next week . adjusted it to 18 thousandths set the timing running perfect again . love how easy these are to work on.
firedemon is offline
Old 08-22-2015, 05:10 PM   #2640
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Cleaned out the beginning of mouse nests and a few of their "leavings".
Replaced the pic of the "girls" that had suffered from heat exhaustion.
A/C is so cold that I haven't changed the aluminum blank we made for the classier aluminum
one that Tom made and gave me for a wonderful present.... and that I had anodized black.
This fall, for sure!!!
In the meantime, the girls are back in shape.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 08-22-2015, 05:47 PM   #2641
88Stanger
88Stanger's Avatar
painted the frame. start frame assy. tomorrow.
88Stanger is offline
Old 08-23-2015, 12:44 AM   #2642
FIREBALL
(007) aka Houdini
FIREBALL's Avatar
Well despite I've had a bad sinus infection hitting me lately, I had something irritating me on my truck. So we all know the story if something's driving u crazy in the back of your mind what do u do, figure it out right! Well I was having a issue with my dome was staying on all the time! I traced wiring, headlight switch and so on. Well it turns out apparently/somehow the wrong bulb got put up in the cargo lamp housing and was grounding the dome light to stay on so, problem solved. Lol so while on this journey I decided I was making my cargo light that I never use into a 3rd led brake light so my next project is on......
Live life one day at a time!
FIREBALL is offline
Old 08-23-2015, 04:07 PM   #2643
CST10
CST10's Avatar
Well ol Samson got a new battery and a coolant system flush today.
MyToys:
CST10 is offline
Old 08-23-2015, 04:30 PM   #2644
boraxman
Keepin an eye out
boraxman's Avatar
Got the top of my dash painted a nice black, couple coats...Also fitted my recent board purchase Dakota Digitals to my old bezel...
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline
Old 08-23-2015, 04:45 PM   #2645
doc2491
Bought it for my 15 yr old....first vehicle. 67 with 69 front end. 70k original miles. He loves it!!
doc2491 is offline
Old 08-23-2015, 05:22 PM   #2646
jdalexa84
I changed the gauges out in my cluster to the ones from a 76+ square body. I like having numbers in stead of letters
jdalexa84 is offline
Old 08-23-2015, 05:23 PM   #2647
jdalexa84
How do I rotate an image
Old 08-23-2015, 06:42 PM   #2648
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
[quote=ole dollor;7273793]
Originally Posted by Andy4639 View Post
Had a local guy come to the house and detailed it. Cleaned it up very nicely! Truck looks killer in the sunlight. We touched up the front of the hood and the bumper both.
Fixing to put some clear bra on it I hope in a week are so.
as nice as that truck is I did not think it needed any thing . its really got a shine now......I like it a lot...Don
Thanks Don, sorry I left for the beach and haven't had any computers there. Just my phone and it's not setup for this forum.
Going tomorrow and get pricing on the clear bra stuff I hope.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline
Old 08-23-2015, 11:55 PM   #2649
magwakeenercew2jh
Here ya go.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-25-2015, 08:38 PM   #2650
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Yesterday was for my truck. I built a work bench with a shelf. Then ran the cable for the "clothesline" I built for my wife (aka parts hanger).
Today I started tearing into the inside of the cab. Finding the darnedest things, like a chuck key inside a duct hose. Couldn't tell ya.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Closed Thread
