#2676 |
Re: What Did You Do With Your Truck Today ?
Squeezed a 4" fan in place of the 2" low profile.
Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
#2677 |
My dad often says "nobody will see that"
![]() I notice that if there are a line of nice cars/trucks at a show. The one that always stands out even if it doesn't have as nice paint. is the one that has all the nobody will see that's treated like they will be the first thing that will be seen. |
#2678 |
Done some more body work on the cab of my 51. Can't wait to get all the body work done, I like working on frames, welding, fab work etc, body work sucks.
#2679 |
Hooked up heater hoses to engine and installed electric washer bottle, its from a mid 90's Dodge Caravan back window unit.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#2680 |
![]() Join Date: Jul 2012
Set up an electrolysis tank using a leaky trash can then de-rusted the radiator frame. Also got out the body hammers and pounded on one of the front fenders.
No pics, the gallery seems to be closed for maintenance. |
#2681 |
My 55.5 got an electric wiper motor transplant today along with mounting the cab to frame bars in the engine bay. Also got a better e-brake lever installed and put my replacement chrome wiper mounts on the outside of the truck. Last thin I did tonight was getting one of the cab vent cables worked loose.
#2682 |
I drove mine to the exhaust shop on Friday afternoon for a full exhaust set up and an inspection. So I've been sitting all weekend anxiously awaiting its return. I won't be getting it home until Wednesday at least so I should learn a little more patience. But it sure is amazing what you can get done around the house and yard when you haven't got a truck to work on
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
#2683 |
put the last coat of poly on my bed boards.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
#2684 |
I finally ordered a new master cylinder for my 57. After two years of dripping, it was time....
#2685 |
I finally got a couple of things done that I have been putting off. My Vintage Air dealer thought I needed to mount my condenser closer to my radiator so I got that done by re-positioning the condenser and removing the spacer I had between the radiator and the radiator support so that it moved the radiator closer to the condenser. I also installed a new fan clutch and a shroud which I hope will cure my over heating problem when I'm in traffic with the a/c going.
I also added a windshield visor. I tried to spray it dry to cut the gloss, and even lightly scuffed it with a 3M pad to reduce the gloss and help match it but there's still a difference, although the pic seems to exaggerate the difference. I need to drop the front end some but that's this winter's project. |
#2686 |
It's looking great russell!
I bought some hub caps a couple days back, Decided to clean one of them up and do a side by side comparison. |
#2687 |
Tell me those are two separate caps, and not the same one!!!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
#2688 |
![]() ![]() Join Date: Nov 2008
Nick,
Outstanding clean up! 000 or 0000 steel wool? Did you paint the letters using the "tape over & cut out letters out with razor blade" method?
'55 Big Window Shortbed, Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's Dan's '55 Big Window "Build" - Well, Kinda! |
#2689 | |
I have the exact same plastic shroud on my '55. When I had it installed one of the old guys that worked on my truck told me the fan blades should only go INTO the shroud 1/3 to 1/2 their width other wise the fan would not be very efficient at cooling. From your photo it's hard to see but it looks like it might be "in" too far. Posted via Mobile Device
#2690 |
Dropped the 59' off at the fabricator to get it started. Will start a build thread.
#2691 | |
#2692 |
Russell where did you get your fan i think im going to run a clutch fan opposed to a electric fan. thanks
1958 Chevy Apache Stepside 1955 BBW Fleetside |
#2693 |
Oh, ok. I had to use some aluminum spacers to get mine where I wanted it. Works great though. Yours looks nice.
#2694 | |
Do you know if they will fit on a Chevy Rallye wheel?
Nev Need a bigger garage so I can keep more cool cars alive My build, a long way to go. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=595909 |
#2695 |
Swapping pieces parts in and out of an improvised electrolysis tank.
(no pics with the gallery down) |
#2696 | |
FYI: Be sure to get the fan clutch that is correct for your water pump. Some water pumps have a 3/4 inch shaft and some like mine have a 5/8 inch shaft. |
#2697 | |
Ha ha yes they are two separate hub caps. But the right one looked almost identical to the left one when I pulled them from the yard.
Actually first I (lightly) used a steel wire brush. Then I went to a #2 steel wool. Honestly it's a miracle I didn't scratch the surface. (enough to see it at least) Others have done the "paint everything, then wipe off the paint where you don't want it." So I thought I'd give it a shot. I taped off the caps right up to the edges of the letters. Then I tried to barely wet the towel and go over everything, but the surface isn't perfectly flat, and I hit the letters, so I repainted it, and spent 20 min with a bunch of cue tips removing the paint. You know, I don't see any reason why not. |
#2698 |
#2699 |
Save your money they won't fit ralley wheels the hubcaps use clips and whole size on rear of cap is to big!
Quote: Originally Posted by Nev68 Lovin' those hubcaps. Do you know if they will fit on a Chevy Rallye wheel? You know, I don't see any reason why not.
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
#2700 |
Ha ha yeah. I kinda help the brush at an odd angle. I think that kinda help not completely scratch em.
I was already planning on getting a new set of these caps, and these were already beat to hell, so I figured I thought I'd just give it a shot. I stand corrected! |
