Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 09-16-2016, 11:55 AM   #2701
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
mornings progress, finished throttle body, searching connectors for air temp. sensor, installed heat shields
[url=https://flic.kr/p/Lk5SLD]
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 09-16-2016, 12:02 PM   #2702
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
anyone need a ballast and points?
[url=https://flic.kr/p/M7u2gC
SAFETY FIRST
AS usual, off topic
Jim
Old 09-17-2016, 12:26 PM   #2703
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
mornings progress
fuel injector harness
O2 sensor harness
Taylor high temp wires
shields
[url=https://flic.kr/p/Mg5XXE]
[url=https://flic.kr/p/Mg5XY1]
SAFETY FIRST
AS usual, off topic
Jim
Old 09-17-2016, 05:52 PM   #2704
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: PO has me PO'd
Getting closer Jim.
Looks like you need a few bolts in you exhaust manifold.
Take Care.
low'n slow is offline   Reply With Quote
Old 09-19-2016, 10:50 AM   #2705
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
thanks Doug, labor of luv,ahhh another lol
whatcha bin up two?
I think all the bolts are in, just need to torque
unless you mean t he cast in boss
and then their was two.....just new air temp. sensor, o2 weld to downpipe
[url=https://flic.kr/p/MdyhtN]
[url=https://flic.kr/p/Mdyhuu]
we need another what's in the safe thread
SAFETY FIRST
AS usual, off topic
Jim
Old 09-21-2016, 10:29 AM   #2706
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
tired of trying to line up bolt and shield at the same time. used a 1" hex drive ss stud with aflange serrated nut
[url=https://flic.kr/p/LuVaRG]
SAFETY FIRST
AS usual, off topic
Jim
Old 09-22-2016, 12:24 PM   #2707
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
tomorrow it rolls out of the work shop, to put the bridge port in
SAFETY FIRST
AS usual, off topic
Jim
Old 09-22-2016, 11:46 PM   #2708
Captainfab
60-66 Nut
Re: PO has me PO'd
I'm jealous........
Old 09-23-2016, 09:06 AM   #2709
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: PO has me PO'd
[QUOTE=. used a 1" hex drive ss stud with aflange serrated nut
Be sure and use some copper anti seize compound on that SS hardware.
Tom Vogel is offline   Reply With Quote
Old 09-24-2016, 07:47 PM   #2710
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Originally Posted by Captainfab View Post
I'm jealous........
[quote=Tom Vogel;7721770][QUOTE=. used a 1" hex drive ss stud with aflange serrated nut
Be sure and use some copper anti seize compound on that SS hardware.[/quote]
it fits cap'n, I guess she stays
tom, thanks for the reminder, how about nickel, instead of copper. I think it has higher temps.
[url=https://flic.kr/p/Mrhdhz]
SAFETY FIRST
AS usual, off topic
Jim
Old 09-24-2016, 07:50 PM   #2711
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
first time in the light of day in 15 years
[url=https://flic.kr/p/MrhdhV]
[url=https://flic.kr/p/Mrhdig]
SAFETY FIRST
AS usual, off topic
Jim
Old 09-25-2016, 12:40 AM   #2712
Captainfab
60-66 Nut
Re: PO has me PO'd
Yep, it looks like she fits.........just don't get too engrossed in machining something and forget about that step over to the right
[quote=jaros44sr;7723207]
Old 09-25-2016, 09:59 AM   #2713
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: PO has me PO'd
Copper is the high heat stuff.
PS... I want a mill like that. So useful.
Old 09-26-2016, 08:59 AM   #2714
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks Tom for setting me straight. Machinery is pretty cheap around here, I only paid 400 for this one, even came with a electric cross feed and vice.It's 3 phase, so I have to change the motor. there is a bearing company that wants me to key shafts for them, so I will have work this winter
[url=https://flic.kr/p/MaQVwE]
SAFETY FIRST
AS usual, off topic
Jim
Old 09-27-2016, 12:39 AM   #2715
Captainfab
60-66 Nut
Re: PO has me PO'd
You are kidding me! Around here a Bridgeport like that would go for about 10X that. A wore out Bridgeport would still be $2K+.
Old 09-27-2016, 11:11 AM   #2716
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
well, we lost a lot of manufacturing in this area, auctions for this stuff is all over the place. MAYBE I should buy it up and deliver out there
SAFETY FIRST
AS usual, off topic
Jim
Old 09-27-2016, 03:17 PM   #2717
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
new interior light for working on computers and wiring 110 V
[url=https://flic.kr/p/MBmC8s]
SAFETY FIRST
AS usual, off topic
Jim
Old 10-10-2016, 11:48 AM   #2718
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Phase convertor mounted, now 220V to power it up
[url=https://flic.kr/p/N59mrZ]
SAFETY FIRST
AS usual, off topic
Jim
Old 10-10-2016, 11:59 AM   #2719
Chevyman63
Can't wait to retire!!
Chevyman63's Avatar
Re: PO has me PO'd
That's a nice light, but it may obstruct your view slightly driving down the road?
2009 4x4 Chevy Crew Cab 6.0
1989 4x4 Siverado (270,000 miles)
1972 4x4 Blazer
2007 Chevy Cutaway 1 ton
1970 Corvette (sons project)
RIP
- CLR 10/11/09
Chevyman63 is offline   Reply With Quote
Old 10-10-2016, 12:57 PM   #2720
hemi43
hemi43's Avatar
Re: PO has me PO'd
[QUOTE=jaros44sr;7724548]Thanks Tom for setting me straight. Machinery is pretty cheap around here, I only paid 400 for this one, even came with a electric cross feed and vice.It's 3 phase, so I have to change the motor. there is a bearing company that wants me to key shafts for them, so I will have work this winter
What voltage is your motor? If it's 208, keep the 3 phase and use a variable frequency drive(VFD). I run a few of my machines this way and now prefer small 3 phase motors over single phase because I can make them variable speed. Best part is that a VFD is relatively cheap to buy.
hemi43 is offline   Reply With Quote
Old 10-10-2016, 05:48 PM   #2721
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Got tired of tripping over my drop light
[quote=hemi43;7738365]
Started to go down that road, I agree a better way, but 220V and 2 phase, might try looking a little more, but 2 phase VFD are hard to find or even available. Then I started to think about buying a 3 phase motor and a VFD, the motor plate is smashed and hard to tell what number the frame is
SAFETY FIRST
AS usual, off topic
Jim
Old 10-11-2016, 10:27 AM   #2722
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
just came to me who was posting up, talk about a blast from the past, how's the boys? What have you been up to....
SAFETY FIRST
AS usual, off topic
Jim
Old 10-11-2016, 10:31 AM   #2723
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Dan, spent a little more time searching, and came up with a VFD for the Bridgeport, much better than the noisy rotary drive. Thanks for getting me back on track
SAFETY FIRST
AS usual, off topic
Jim
Old 10-11-2016, 03:30 PM   #2724
hemi43
hemi43's Avatar
Re: PO has me PO'd
Glad to hear !! Awesome that you have a 220V motor. You won't regret the VFD. I built a CNC mill a few years ago and used a Hitachi VFD with 100% satisfaction.
All you need now is some ball screws and a computer !!
Old 10-11-2016, 06:43 PM   #2725
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Don't know if I'll ever get into CNC, I'm more of a manual kind of guy, been there my whole life....
Weird, to run into 2 phase, but its a philly and Rochester thing, from way back in the day. found out about it on practical machinist
SAFETY FIRST
AS usual, off topic
Jim
