12-08-2011, 08:21 PM | #2701 |
A guy with a truck
Re: 67 cheby's Dropmember build thread
You will experience shrinkage...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
12-08-2011, 11:21 PM | #2702 |
I know there is lots of good stories about the epoxy stuff but all it takes is one bad tube that didnt quite mix just right or the temp/ moisture wasnt quite right and all your hard work is down the tubes, I learned that one the hard way.... and besides what chemical company knows how time really effects their product for as fast as they are cranking them out... and all their guarantee covers is the cost of the product. just something to think about.
Adam My 1967 C10 - Turbo 250 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=485843 (608) 214-8706 |
12-09-2011, 03:14 AM | #2703 |
you could ude s combinnation of welding /bolting and the gleu , there a lot of kitcars and fast sportscars here that have nothing but gleu to hold them together the stuff is incredibly strong as in metal tears before bond breaks
i got a job again and having fun at it too idea's for the trucks and the order of things to do are taking shape and get closer to being realized , a few more months and i be able to start building for real i complete 2 of the trucks intoo running fashion one custom and one basicly stock the thirth will be sacrificed for parts |
12-09-2011, 08:17 AM | #2704 |
I bonded a fiberglass cowl hood scoop to an S10 I had and later totaled the truck in a head on collision. The bonded fiberglass to metal portion never gave. That stuff is strong!
66 Chevy 305 /350 auto, bagged, custom frame |
12-09-2011, 10:30 AM | #2705 |
67cheby
this makes me laugh !! LOL
12-09-2011, 10:33 AM | #2706 |
67cheby
worked last night on braces to "end cap" where the wood will stop under the notch cover , and worked on making some Slosh Tubz filler panels, got the flat sheet metal cut out will bead roll them and bend them and see how they turn out , i think it will look good and hide all of my wiring ..anyway pictures turned out crappy
12-09-2011, 10:34 AM | #2707 |
check out my build thread 71 c/10 step side 5.3 twin turbo http://67-72chevytrucks.com/vboard/s...d.php?t=485320 raul |
12-09-2011, 11:40 AM | #2708 |
anyone remember that tread on some off road forum about a guy getting rinoliner on his little tool and was stupid enough to ask for a solution to his problem online?
12-09-2011, 02:33 PM | #2709 |
GEARHEAD
Another word on panel adhesive, all new trucks are built at the factory using this stuff. The body shops all use it for replacement panels. It has been used for several years. I used it to do my floor pans, gas filler patch, and for covering holes in the cab floor from fuel lines, etc. Did a cab corner also. One of the big advantages, especially for us in the rust belt is that the seam is completely coated and can't get moisture in to start rusting. Welded panels will be have a higher chance to start rusting in the seam or on the back side of it. Shrinkage is minimal. Even your primer coats have shrinkage, it doesn't stop anyone from spraying paint over it the next day. You can't use it for everything, but if you just wanted to band some sheetmetal to a panel for looks, it's a very good option.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
12-09-2011, 09:12 PM | #2710 |
^^^^^It's kind of like when I told someone I would never own a computer--haa--now I don't know what to do without it!!!!!!!!!!!!.............jim
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
12-12-2011, 05:05 PM | #2711 |
Can anyone recommend a certain brand over another, and why it is better? Thanks!
12-12-2011, 09:54 PM | #2712 |
I'm using 3m-$50 +- .......If your careful with cleanup U can reuse-gun is expensive-not sure if it's better but this stuff STICKS!!!...jim
12-12-2011, 10:51 PM | #2713 | |
Still Learning
Mike, your notch cover project is coming along nicely. |
12-13-2011, 09:30 AM | #2714 |
GEARHEAD
I used SEM products. It was available through my local small town parts store and I found a gun for cheap on ebay.
12-13-2011, 10:30 AM | #2715 |
67cheby
LOL...i am only 38 but i am "STOCKY" lol
12-13-2011, 08:28 PM | #2716 |
Stocky, ya, let's go with that.
Good description there Mike....... Of course, not that I'm one to talk....
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
12-14-2011, 02:05 AM | #2717 |
VA72C10
Looking good! Any more progress on the filler panels? I had that on my list of to-do's when I was building my "shaved" ride a while back...
Looking for a 67-72 swb or blazer project in or around VA. |
12-14-2011, 10:35 AM | #2718 |
67cheby
i have them cut out ready to bead roll and bend, but i have been spending my time trying to get this notch cover hinged , first i tried some 80's model truck hood hinges...that didnt work , now i am trying some generic Autoloc trunk hinges working on that tonight, it is driving me crazy i guess my main problem is that i dont fully understand pivot points?? so trying to figure out where to place the hinges is all trial and mostly ERROR !!
12-14-2011, 11:38 AM | #2719 |
you are making me feel like "I need to step up my game" when it comes to great ideas..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
12-14-2011, 11:50 AM | #2720 |
67cheby
Stumble along blindly like me and you will eventually stumble across something that works !!! Lol
12-19-2011, 11:17 AM | #2721 |
Just read about 30 pages of your build...beautiful work, can't wait to see finished project. I'm excited for you. I spent 5 years on my 67' Camaro, only to have it turned into a submarine by Huricane Katrina, lol. Now I'm in the middle of doing my 68' shortbed. Putting the TPI motor together this week. You're motivating me! Keep the pics coming.--Dave
68 Chevy SWB Stepside--under construction--now Fleetside w/18's & 20's--getting ready for 350 TPI motor w/700r4 67 Camaro--17x8's and 19x12's--C5 & Airride Technologies susp. (not finished) 09 Tahoe--lowered w/20's Superformance Cobra--347 stroker w/Weber injection--polished 17's--SOLD 08 Scion Xb w/ground effects and 19's (son's car) |
12-19-2011, 11:57 AM | #2722 |
67cheby
Thanks man i appreciate it, that stinks on your car !
12-19-2011, 08:31 PM | #2723 |
PROJECT 7DEUCE
Just wanted to drop in and let ya know I got that hood piece in the mail and it will work perfect.. Thank you very much and happy holidays and best wishes to you and yours..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
12-19-2011, 08:50 PM | #2724 | |
12-19-2011, 09:28 PM | #2725 |
PROJECT 7DEUCE
Look at a 81-83 toyota pickup for its hood hinges very adjustable
Tags |
fiberglass inner fenders, pb hood hinges ", w/pb 4 link |
