03-30-2005, 06:57 PM | #251 |
moving right along....more 60's
#1 1966 chevy #2 1967 chevy #3 1968 chevy wrecker #4 1968 chevy wrecker #5 1968 chevy wrecker
1972 GMC Sierra Grande |
03-30-2005, 07:06 PM | #252 |
finishing up the 60's and movin on to the 70's
#1 1968 chevy #2 1968 chevy #3 1969 chevy #4 1971 chevy #5 1972 chevy
03-30-2005, 07:14 PM | #253 |
here is the 70's...w/ a few oddballs mixed in
#1 1972 chevy c-40 #2 1972 chevy c-40 #3 1972 chevy c-40 #4 1972 gmc camper conversion #5 1972 gmc k-30
03-30-2005, 07:21 PM | #254 |
more 70's here...
#1 1973 chevy #2 1974 gmc #3 1975 gmc 4door carhauler #4 1976 chevy carhauler #5 1977 chevy
03-30-2005, 07:26 PM | #255 |
ok here is the last of them that i had. i see that they don't look as good as i had hoped. this is my first attempt at posting pics, so i will learn from this. i do hope that you guys like them at least alittle.....
#1 1977 chevy #2 1977 chevy dump truck
1972 GMC Sierra Grande Last edited by 7gmc2; 03-30-2005 at 09:39 PM. |
03-30-2005, 09:26 PM | #256 |
I have a radical idea!
Wow!! Great pics!!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
03-30-2005, 09:37 PM | #257 |
found another 1.....
#1 1970 chevy k-30
03-31-2005, 09:03 PM | #258 |
User #12137
i see sum of you have, member of the 1 ton club, in your siggys is there a 1 ton club here on the board ? i know that sumbody here is making a 1-ton club on the net but i was just wondering about here ?
03-31-2005, 09:05 PM | #259 | |
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
03-31-2005, 10:36 PM | #260 | |
User #12137
i have seen that one but i was askin if there was a 1 ton club here on the board not the one in 67 c 30 siggy i have aready told him i would join that one |
04-01-2005, 12:51 AM | #261 |
tnblazerk5, Its not an official club, but if you want to join, just add it to your sig. Tx Firefighter put it in his sig, and several of us other 1 ton owners did the same. You got one, so you qualify!!
04-01-2005, 09:35 AM | #262 |
User #12137
ok thanks !!!!!! now how do i get the red letters and the bigger print at the same time ?
04-01-2005, 12:15 PM | #263 |
{SIZE=3}{COLOR=Red}{B}Member of the 1-Ton Club!{/B}{/COLOR}{/SIZE}
This is is code, you just need to change the brackets from {} to [ ]
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! Last edited by 67_C-30; 04-01-2005 at 12:21 PM. |
04-01-2005, 05:26 PM | #264 |
I thought to be an official member you had to do what I did and change your signature 5 times trying to figure out the correct size. I should have been smart and asked for the correct size too.
04-01-2005, 06:55 PM | #265 |
User #12137
test to see if it worked
04-01-2005, 06:55 PM | #266 |
User #12137
yup it worked
04-01-2005, 07:07 PM | #267 |
Hey tnblazerk5;
Have you ever priced a dually kit for your '91 S-15. I have always wanted to do this mod. to mine and now I have a good one ton rear end, I think that it would look great, and that way it would match up with my '68 dually. Also have you ever seen a S series truck done, I have seen lots of rangers done, but never a S series. |
04-01-2005, 07:31 PM | #268 |
Currently Blazerless
Has anyone changed from the 1/2" studs to 9/16" or 14mm, I have a 70 and need to switch in order to better center the later model budds.
My local auto supply didnt want to take the time to pull out the Dorman book so part numbers and drill sizes would really help if someone has done this.
1972 C/30 133" W.B. C&C 1970 GMC 3500 157" W.B. single wheel C&C |
04-01-2005, 08:14 PM | #269 | |
User #12137
no i have never seen that done to a s seires truck , but it would be cool to do to one theres sum toyotas around here like that but there delivery trucks wounder if that rear would fit a s15 or s10 ? |
04-01-2005, 08:30 PM | #270 |
I have a rear end out of this truck that I thought would look killer under it, as it fairly narrow, only problem is that it has 4 5 6 gears in it. I probably won't drive it much anyways, seeing as though I have the '68, just more for show, possibly on a trailer behind the old gurl.
BTW, this was the donor chassis for my '68. Last edited by 68gmcdually; 04-01-2005 at 08:33 PM. |
04-01-2005, 09:18 PM | #271 | |
98596 Front Stud; Dual Rear Wheels; w/Rear Drum Brakes 98565 Rear Stud; Dual Rear Wheels; w/Rear Drum Brakes 99929 Front Or Rear; External Thread; w/Rear Drum Brakes; Dual Rear Wheels
04-01-2005, 10:16 PM | #272 | |
User #12137
04-01-2005, 10:33 PM | #273 |
67_c30, Thanks that helps alot, I'll check out those numbers tomorrow.
04-02-2005, 12:35 AM | #274 |
Not a dually, but they say its a 72 C-30!!
04-02-2005, 03:51 AM | #275 |
Rob, I have the part numbers for the 9/16" studs I used in my 68 ,
Wagner, BD60909 Front DOR, 610-189. I think these are the rear ones These are from O'Reillys. Joe
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
