Old 12-08-2011, 01:30 AM   #251
rick boyd
rick boyd's Avatar
Re: Post Your Straight Six Pics!
46 chevy 216 1 1/2 ton truck
rick boyd is offline   Reply With Quote
Old 12-08-2011, 06:40 AM   #252
slick copper
slick copper's Avatar
That's cool! All original? And is that the stock horn location? How does it work? Sorry never seen this before, curious, and impressed! Clean six!
Raymond
1967 Chevy C/10 LWB Custom Optioned "big window truck" AKA Copper
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=452594
The story of how I got the truck:http://67-72chevytrucks.com/vboard/s...d.php?t=450939
Ole Smokey Build Thread 2002 Silverado 8.1L Crew Cab **SOLD**http://67-72chevytrucks.com/vboard/s...d.php?t=618402
slick copper is offline   Reply With Quote
Old 12-08-2011, 08:45 AM   #253
70STOVEBOLT
70STOVEBOLT's Avatar
Looks like a wolf whistle.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Power windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 12-08-2011, 10:38 AM   #254
rick boyd
rick boyd's Avatar
horn is original,
electric 6-v , sounds like the road runner "beep beep"
Old 12-08-2011, 10:43 AM   #255
rick boyd
rick boyd's Avatar
carb after wire brush
Old 12-09-2011, 03:08 AM   #256
rick boyd
rick boyd's Avatar
is a 292 really better than a 250?
Old 12-09-2011, 07:09 AM   #257
slick copper
Interesting. Thanks for sharing. As far as a 292 better than a 250, I guess the 292 is bigger and has more torque and power. 250's are more common though, maybe easier to find parts for. Guess I'm partial to the 250 as that's what I got in my truck. I think the 292 looks too tall and bulky compared to the 250.
Any other opinions?
Raymond
Old 12-09-2011, 04:16 PM   #258
Shaky
Six in a row makes it go...
Shaky's Avatar
I have one of each currently. I've owned a few 250s over the years and one 292.
The big difference to me is the ultra-long stroke of the 292. It makes its torque peak at 1800 (!) rpm. The long stoke also means that spinning that engine up to higher rpm results in a really high piston speed. This can put large loads on the main/rod bearings.
So, to me, the 250 is a little "sportier" than a 292. I try to keep the rpm down on my 292 and use it like it was designed: a low-end grunter.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 12-09-2011, 07:15 PM   #259
'68OrangeSunshine
'68OrangeSunshine's Avatar
I have no 250 experience, so my view is admittedly biased. I really like the 292 over the V8s. I have a crate Mr Goodwrench 350 in a '71 [K/5] Jimmy and once ran a 454 in a '67 K/10 Suburban. My '68 C/10 Stepside w/ L6 292 has better torque that the stock BBC, and better acceleration than the stock 350. It's also lighter: ~125# less than the SBC and ~200# under the BBC.
The 454 had an iron intake and iron exhaust manifolds and a 625 CFM Carter AFB. The 350 has Heddman headers, a Weiand intake and a Carter 600 CFM AFB. The 292 is bored .030-over, has oversize intake valves [307 V8=1.86], a Crane cam 260H, Badger cast pistons, and Offy 4V intake, Clifford headers, and a 500 CFM Edelbrock 4 Bbl "Performer" [AFB clone]. It's the original engine, rebuilt once. So it may be unfair to compare a hand built engine with 2 stock factory engines. My last L6 engine, a '67 292 block, I built in 1977-- it ran 25 years and 250,000 miles. It was bored .030 over, but other wise stock [or OEM "heavy duty" parts from the dealer.] I ran the same intake and Clifford [Research] headers and a Holley 390 CFM. After a 500 mile break-in on the new engine, the Holley gave up the ghost, and I went with the Edelbrock.
From my perspective-- running and gunning 292s since 1973, in contrast to Mr Slick, the 250 looks too small.
Rick: Sweet engine and welcome to the Board.
Old 12-10-2011, 06:02 AM   #260
slick copper
Of course! "the 250 looks too small" To each their own. But like Mr Sunshine and Shaky said the 292's are meant to have more torque, and are great for pulling/hauling. 250's are good all around especially DD (not that a 292's not). And either is gonna be a heck of a lot lighter than a V8. Inline 6's ROCK!!
Raymond
Old 12-14-2011, 04:11 AM   #261
NobleSix
if you click the link in my sig, i have a few pics of my 69's 292 in there. im no photographer by any means =D
'69 c10 longbed granny 4spd 292 "Behemoth"
'67 c10 longbed granny 4spd 292 "Burzum"
some pictures of my work in progresshttp://photobucket.com/zaeea
R.I.P. Corey "Flattus Maximus" Smoot 11/3/11
You will be missed. Your sound lives on.
NobleSix is offline   Reply With Quote
Old 12-17-2011, 11:17 PM   #262
pritch
pritch's Avatar
I got a little bit of a start on my build today. I put my new timing gear on the crank and got the cam in, then ran into a little snag.
I was going to check the mains with Plastigage, but all I had was too small, and besides it was way too brittle. It's pretty old, so I figured I'd just get some new that's the right size. Then I got to thinking that maybe it was brittle because of how cold it is in my shop, so I decided to get some propane, too, and be all ready for next weekend.
Oh yeah, I got my damper back from Damper Doctor, so I'm all set.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 12-18-2011, 08:43 PM   #263
R.L.
R.L.'s Avatar
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Detailed the enginge compartment since these were taken, I'll post them later; these are the bracket I made for the kickdown cable with the 700r4.
R.L. is offline   Reply With Quote
Old 12-18-2011, 09:39 PM   #264
john_p
thought i was the last one proud of my 6... 250 stock, but it plans to grow.. after the body and interior..almost forgot to mention, great looking engine bays.. all of them
john_p is offline   Reply With Quote
Old 12-19-2011, 01:39 AM   #265
stsalvage
Scrapper 1
stsalvage's Avatar
I bought a 250 inline 6 5 years ago i'm planing on putting it in a 1968 longhorn the truck with the 8 1/2 foot bed.I'm converting it to a 1/2 ton just got the stock spindles from a 1973--87 chevy 1/2 ton changing the upper and lower ball joints the truck came with a 396 and 400 auto it came with factory AC and power steering will be adding power brakes and 3.73 posi rear end and putting a 700R4 or a 200R4 in it.Leaving it stock but putting in a cd player in the dash.A guy on eBay is selling a aftermarket brackets for the AC unit so you can run the HEI for 139 plus 15.00 shipped you have to use the different Compressor but i like to have the AC in the truck.
At one time thought i always run the 350 or 327 but with gas going up as much as it has i like to have a nice one to just enjoy
stsalvage is offline   Reply With Quote
Old 12-22-2011, 12:54 PM   #266
tkeduk8r
tkeduk8r's Avatar
that 68 is SOOOO cool.... love the paint and the slots.... and being a MN guy doesnt look like any rust... SOOOO jealous.... enjoy!!!!
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 12-26-2011, 12:00 AM   #267
70c-10
There are some pics of my 292 on this page. I pulled it from my 70 C-10 and put it in my 63 Chevy II:
292 - Six in a row, makes it go!
6 in a row, makes it go!!!
My Car
'88 SWB Daily Driver
70c-10 is offline   Reply With Quote
Old 12-26-2011, 10:45 AM   #268
Gokart Mozart
Gokart Mozart is offline   Reply With Quote
Old 01-02-2012, 10:42 PM   #269
pritch
pritch's Avatar
It was a pretty nice day for January, so I decided to get some primer on my 292 tin:
Figured I'd better get this done before I get my motor all put together
'68 Panel
'68 C-10
Ol' Green
Old 01-03-2012, 05:06 PM   #270
Shaky
Shaky's Avatar
Oh man - I love the engine, the car, and the photography. That valve cover/air cleaner combo is sweet!
Old 01-04-2012, 10:22 PM   #271
richards72chevy
richards72chevy's Avatar
richards72chevy is offline   Reply With Quote
Old 01-05-2012, 02:48 PM   #272
slick copper
Very cool! Love the intake on the red truck, and gotta love the patina dually!
Raymond
Old 01-05-2012, 06:19 PM   #273
Shaky
Shaky's Avatar
That dually is mental. The gnarly snow tires on the back are the crowning touch.
Old 01-05-2012, 07:22 PM   #274
68steppsidee
is there a build on this dually
68steppsidee is offline   Reply With Quote
Old 01-05-2012, 08:10 PM   #275
richards72chevy
No i wish there was a build thread on it.I got the pics from some other forums and he hasnt updated any thing in awhile!
