01-17-2008, 06:54 AM | #251 |
Re: How to: Ruin a perfectly good Blazer...
01-17-2008, 07:12 AM | #252 |
No harm, no foul.
01-17-2008, 03:02 PM | #253 |
A guy with a truck
I CRS most of the time too. Info is correct except the tires are 255s...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
01-17-2008, 03:16 PM | #254 |
01-18-2008, 07:14 AM | #255 |
A guy with a truck
Besides an alignment and rear shocks, this pretty much completes the suspension portion of this build...
Mods- if you wanna move this to the Projects & Builds section, I'll continue posting there. For everyone else who is following along, I'll be posting here for the GenIII engine install...
01-18-2008, 10:59 PM | #256 | |
On the fast track to nowhere..
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
01-19-2008, 01:17 AM | #257 |
Texas Big Wig
It'd cool if you were to combine the 2 threads...
Anywho, I can't wait till you get this thing outside for some more pics !!!! |
01-23-2008, 05:47 AM | #258 | |
A guy with a truck
Ride height and dumped. Also a pic of the inner fender carnage and the solution to the problems it produced...
01-23-2008, 05:53 AM | #259 |
Looks just right now. Much improved! Tiltin it forward huh? Nice.
01-23-2008, 05:58 AM | #260 |
Beautiful!!!
01-23-2008, 07:03 AM | #262 |
Looks good! Let us know how that tilt front hood thingy works out for ya, I have thought about doing the same thing
Kevin LFD Inc. |
01-23-2008, 07:19 AM | #263 |
Lukin Great, makes me wanna go work on mine but to dang cold
01-23-2008, 08:25 AM | #264 |
Modesty
01-23-2008, 11:13 AM | #265 | |
What is your ride height gonna be? I'm planning on 6". Is your's close to that? Also, your dumped height - how far off the ground is it? With my tire hieght I should be a 2". Again, how close is yours? Thanks
Jim '71 Blazer-Porterbuilt Dropmember C4/LS1/6L80E '57 VW beetle - Oct. 2006 Hot VW's pg. 87 - 350hp intercooled, turbocharged, EFI 2.3liter and 5spd in the works '87 BMW 325i - daily driver |
01-23-2008, 12:27 PM | #266 | |||
A guy with a truck
Thanks! Moving along slowly Quote:
Toughen up! I worked last night 'til the air tools froze up on me. Quote:
When I put the drop spindles on, I should be able to lay the front bumper on the ground easily, but I will probably set up some bumpstops to stop it close to where it is now. That will make it so i can roll(but not steer) in case of air system failure and save me from having to tub the hood...
01-23-2008, 12:50 PM | #267 |
Looking forward to the mods to the hood. I really like the function of mine but I will be redoing it abit for more of a finished visual look. What are you planned changes?
Kevin LFD Inc. |
01-23-2008, 12:54 PM | #268 |
A guy with a truck
Played a little today with the hood hinges. It's actually coming together very easily. I won't go into a whole lot of detail on it because it has been covered by Rokcrln in his FAQ. I will be following his example pretty closely with the exception of a few small things.
I also included a daytime shot of it outside with the hood on. The tape is to keep me from damaging the paint while I remove/install the hood during hinge fab. It's cool that I can roll it in and out of the shop without airing it up...
01-23-2008, 12:56 PM | #269 |
Lookin good.. Keep up the good work.
01-23-2008, 12:59 PM | #271 |
Make sure you check the radiator cap clearance as it gets real tight. I had my cap on with the PSI release lever facing up tward the radiator center, closed the hood and bought a new cap Now I keep the lever facing down!
Kevin LFD Inc. |
01-23-2008, 01:06 PM | #272 | |
A guy with a truck
The only real deviations I see from your design so far is that I will not weld the actual hinge assemblies to the core support. They will be entirely bolt-on so that I can replace them if necessary and so they can be removed for things like- oh, I dunno- stabbing the 6.0! Lo-buk looks good btw; I may be stealing your other hood mod before too long...
01-23-2008, 01:24 PM | #273 |
Freakin' sweet!
01-23-2008, 01:35 PM | #274 | |
Kevin LFD Inc. |
01-23-2008, 01:41 PM | #275 |
Gringo, did you have your DM powder-coated as is or did you debur the edges a little?
I did on mine 'cause I was worried about the powder 'lifting' off the sharp edges like it did on my ECE hidden-hitch.
