Old 03-14-2010, 02:05 PM   #251
protrash64
Resistance is Futile
protrash64's Avatar
Re: 1964 Suburban Pics
Originally Posted by Joemomma1 View Post
Care to elaborate on the tv bracket on the quadrajet? I didnt think it would be easy, you make it look like its just a matter of drilling holes. That can save me the money I was gonna spend on a new carb.
Sure; it took a little cypherin' ............ Basically, I had plan to run the Edelbrock a long time ago. Well, as luck would have it, it doesn't work. Wont idle. I had picked up the TV bracket from Summit(SUM-700203) to use on it and wanted to use it now. I searched and couldn't find much info until I got to Bowtie Overdrives. They have a bracket and a carb guide for Quadrajets. Well, my Quad doesnt have the lower linkage; it was cut down 'for use on low riser stock manifolds'. Nice!!
What I did was set the 2 carbs on a level surface.I marked the center point of each throttle shaft. I put the bracket on the Edelbrock and used my speedsquare to find the angle (75*) and marked the bracket in relation to the center shaft. (It sits just forward of the shaft, made a horizontal line).
I took the bracket off and moved it to the Quad and positioned it in the same location. Horizontal line pointing at the center of the throttle shaft and sitting at a 75* angle. This should keep the radius the same as an Edelbrock as the throttle swings its arc. I clamped it down and scribed the location on the Quad bracket. Drilled out a hole and used the throttle ball and a small 10-32 bolt to hold it to the Quad linkage. One could use 2 bolts and use the standard Quad throttle ball location with minor trimming of the TV adapter.
I also had to pick up a TV cable bracket from TCI (TCI-376700) and a 1'' spacer for the carb(4-hole Quad from Mr. Gasket). I needed the spacer because of the stock manifold. I think with an aftermarket manifold one would be ok with the height. The TV bracket hit the #3 intake runner in my case. Basically a 100$ to hook up the trans. I also dont know if it will work yet, but I dont know why it wouldn't.
I'll try to get some pics on here later.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-14-2010, 02:32 PM   #252
protrash64
protrash64's Avatar
Here's a pic of the linkage. You can see the line pointing at the center of the throttle shaft and the bolt below the throttle ball. My Quad now has an Edelbrock throw on it.
Old 03-14-2010, 07:21 PM   #253
jason65
Registerd User
jason65's Avatar
Good job dude.
jason65 is offline   Reply With Quote
Old 03-15-2010, 12:12 AM   #254
daverod
SSN 706
daverod's Avatar
Your a fricken Macgyver. Fire in the hole this week?
daverod is offline   Reply With Quote
Old 03-15-2010, 12:31 AM   #255
Joemomma1
Joemomma1's Avatar
Thanks a ton. I really do appericiate you taking time out of your day to get the pic. Thanks.
Joemomma1 is offline   Reply With Quote
Old 03-15-2010, 01:14 AM   #256
protrash64
protrash64's Avatar
Hope so; still working out some small details.
No problem. Same as you I was trying to put my already spent dollars to work and not buy anything I didn't have to get. I dont know if this will work properly but I dont see why it wouldn't.
By the way, the Summit TV corrector is the cheapest route I found. I've seen it sell for up to 45 dollars elsewhere for the same 3'' piece of metal.
Old 03-18-2010, 10:26 PM   #257
CarJunkie
CarJunkie's Avatar
i like the fact that your sub whiskey has smoothies
now accepting donations towards the cj needs hot rod parts fund. all applicable donators will be thanked hospitably with a 6 pack of any alcoholic beverage of their choosing.
CarJunkie is offline   Reply With Quote
Old 04-11-2010, 01:36 PM   #258
protrash64
protrash64's Avatar
Ok..no fire in the hole yet and a small update. I have been working on this but there are many small issues and I'm finally thru them and close to having this thing running. I took some time off and then just had to start throwing some dollars at it and got there .....
Installed the business part of the Hurst shifter....works well. I'm on my 3rd set of tranny lines as I had to change exhaust plans. I'm now running BBC shorty's. My carb is finally hooked up and I'm ready to start putting in the fluids.
Once running I'm going to build some exhaust extensions and it will be ready for a test drive. I changed a lot of stuff so I'm going to have to look over many things...here are a couple pics.....oh yeah, and vaccuum the interior, damn it looks bad.
Old 04-12-2010, 12:30 AM   #259
srsummers
Nice work Jeff
I should have my truck back on the road soon. Maybe I can cruise it over to your house and hang again. Keep up the speedy progress...The Heat is coming
srsummers is offline   Reply With Quote
Old 04-12-2010, 12:41 AM   #260
protrash64
protrash64's Avatar
Originally Posted by srsummers View Post
Nice work Jeff
Ya, definitely.........need some pre-bent tranny lines??? I'm trying to get this thing fired by the end of the week. I have to take my time so I dont miss anything as I've changed and added so much stuff.
Old 04-12-2010, 01:53 AM   #261
srsummers
I'm trying to get mine on the road for a car show on the 24th. If your interested in going, let me know (it's small, but there will be at least 3 60-66). It's a hike for you 35th ave and Happy Valley. If your interested, let me know and I'll email an entry form. It supports the local High School car club. I was thinking about hittin Dino up as well.
Old 04-17-2010, 10:59 PM   #262
protrash64
protrash64's Avatar
Thumbs up Re: 1964 Suburban Pics
Fire in the hole
Started it up tonite!!! Fired off and scared the crap out of me with open headers. Have a couple small leaks to deal with but that comes with the territory. Also my neutral safety switch doesnt want to let the truck fire in PARK. The hard part is done; it runs.
Old 04-17-2010, 11:35 PM   #263
daverod
SSN 706
daverod's Avatar
Very cool to hear. You don't really need headers anyway. Now you need to go burn around the hood.
Old 04-18-2010, 12:12 AM   #264
protrash64
protrash64's Avatar
Thanx man!!!!! I'm excited as it's been 3 months of work. I had the pedal floored when it lit off cuz I thought it mite be flooded. Blew all my kitty litter out the back of the truck
Now I need to weld up my header extensions to meet up to the old exhaust system and then bleed the rear brakes. I already solved one leak and figured out my neutral safety switch.
Old 04-18-2010, 12:25 AM   #265
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Congrats!!!
Alan's Classic is offline   Reply With Quote
Old 04-18-2010, 12:42 AM   #266
Captainfab
60-66 Nut
That's good to hear. I'll bet you're anxious to go for that first test drive.
Old 04-20-2010, 01:16 AM   #267
protrash64
protrash64's Avatar
I'm just getting ready to drive, so I think I'm going to pass up the road trip right now, Scott. I wish I could go, but I'm going to try a cruise that started up about 2 miles away on Friday night. Gilbert and Baseline.
For the progress report, I welded up some pipe and installed my exhaust. I had to change out my fuel pump as the one I was using had too much pressure; my carb looked like a sprinkler!! Here are the only pics I took today. I did fire it up and it purrs nice and quietly. Welding exhaust under the truck sucks!!!
Old 04-20-2010, 10:20 PM   #268
scotts62
One day...
scotts62's Avatar
Cool man looking good!! Yeah i agree with the welding exhaust i finished up a couple pieces on my daily and the top part always sucks
Scott
93 crew cab build
Project 62
Old 04-21-2010, 12:38 AM   #269
protrash64
protrash64's Avatar
I dont have an auto adjust helmet and I kept knocking my helmet off under the truck so I ended up just wearing my sunglasses I also have flash burn on my left arm
Well, here it is......a fully operational Death Star. Still need to bleed the brakes a little more as they still feel mushy, but stop the truck. Also need to get the a/c lines tucked in somewhere.
Old 04-21-2010, 12:52 AM   #270
Joemomma1
Joemomma1's Avatar
Looks at home in that giant boat.
Old 04-21-2010, 01:03 AM   #271
Captainfab
60-66 Nut
Real nice job Jeff
Old 04-21-2010, 01:16 AM   #272
protrash64
protrash64's Avatar
Thanks for the comments everybody. It was a tough job and a lot of little details to plow thru.....still need to get it on the road and see how it drives. It sounds awesome with a low, rumbly exhaust note. I'm wondering if the radiator will keep up with the cooling of the engine. It was idling fine today at steady temps.
Oh, the headers I finally went with were Hedman #68610. They are for Chevelle/Camaro fitments. They exit at nearly a perfect 45* angle and the only issue is the #1 tube hit the clamshell. It requires a little grinding on the top/rear to allow the tube to pass. Again, these work with the 73+ 1/2 ton mounts I used to get the engine in the frame.
Old 04-21-2010, 01:32 AM   #273
StuckinAz
GM ONLY
StuckinAz's Avatar
Love that huge filter.
"59 Apache Short Step
"64 GMC Short Wide
"07 Crewcab
"08 Tricked Tahoe
StuckinAz is offline   Reply With Quote
Old 04-21-2010, 01:36 AM   #274
protrash64
protrash64's Avatar
........free!!!!
Old 04-21-2010, 06:33 AM   #275
mosesburb
I had a V-8
mosesburb's Avatar
Looks great!! It should be a real hoot with that big block in there.
1972 K20 Suburban, 5.9L Cummins, Banks Power Pack, NV4500HD, NP205, H.A.D., D60/14FF ARB Link To Build: HERE.
mosesburb is offline   Reply With Quote
