Old 12-19-2014, 10:12 PM   #251
Monte's62
Re: Post Pics of your Static Drops!!
wow!!! Got cubbage???
Monte's62 is offline   Reply With Quote
Old 12-20-2014, 10:12 AM   #252
contagious102
contagious102's Avatar
Bigger is better.!!! Never enough. Drove it in the local Christmas Parade last weekend with my Daughter.!!
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
Old 12-20-2014, 11:14 AM   #253
chevyrestoguy
chevyrestoguy's Avatar
Here's mine, still currently under construction.
The front suspension and rear axle is all '79 Chevy 1/2 ton.
Front: Belltech spindles, 1 coil cut, 2" chassis "Z", wheelbase stretched 1" to center the front wheels in the fender openings, lower control arms moved fwd .75 (my mod). Total drop is 7".
Rear: 5" drop coils, 2" block, ECE Super Track Bar, ECE shock relocators, frame is notched, forward trailing arm brackets flipped. Total drop is 7"
Wheels/tires: '60s vintage ET Supers, 15x6 front/15x8.5 rear (3.0" backspace). 215/60-15 front, 265/70-15 rear.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 04-03-2015, 06:23 PM   #254
Evoracer
Bump...
Evoracer is offline   Reply With Quote
Old 04-04-2015, 02:38 AM   #255
64nlo
64nlo's Avatar
I really like this thread. old school drop.
64nlo is offline   Reply With Quote
Old 04-04-2015, 12:31 PM   #256
rustbucket66
My 66. 2 1/2" drop spindles and 2" drop springs in the front, and 4" drop springs in the rear.
rustbucket66 is offline   Reply With Quote
Old 04-04-2015, 06:17 PM   #257
Slambone
Slambone's Avatar
My truck has CPP 3" lowered springs which I cut a coil and a half off. The rear has CPP 5" lowered springs with 2" blocks as well. From what I can tell I have the 5/7 drop.
Slambone is offline   Reply With Quote
Old 04-05-2015, 01:33 PM   #258
Fastest32
Fastest32's Avatar
Tires and wheels look perfect. What size?
BaBaBooey BaBaBooey
GO SPURS GO!!!
Fastest32 is offline   Reply With Quote
Old 04-05-2015, 03:01 PM   #259
Slambone
Slambone's Avatar
Thanks! They're 225/70/15's. I'm also using 2"wheel spacers to push the tires out closer to the fenders
Old 04-05-2015, 03:26 PM   #260
Shasta123
Do you have c notch in the rear frame
Shasta123 is offline   Reply With Quote
Old 04-05-2015, 03:28 PM   #261
Slambone
Slambone's Avatar
Yeah. It has a CPP C notch kit.
Old 04-05-2015, 06:22 PM   #262
Fastest32
Fastest32's Avatar
Good to know.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Old 04-05-2015, 07:40 PM   #263
schpeen
schpeen's Avatar
8 ball
schpeen is offline   Reply With Quote
Old 04-05-2015, 10:34 PM   #264
64nlo
64nlo's Avatar
the Dyanamat under the hood is a good idea. like.
Old 04-07-2015, 09:53 PM   #265
willyp
willyp's Avatar
Saturday night.
The price of cool aint cheap.
willyp is offline   Reply With Quote
Old 04-07-2015, 09:56 PM   #266
Layne
Very nice.
Layne is offline   Reply With Quote
Old 04-10-2015, 07:35 PM   #267
rcg66
rcg66's Avatar
Just got it out after a long, cold winter. 2/4 drop using lowered coil springs.
rcg66 is offline   Reply With Quote
Old 04-10-2015, 10:02 PM   #268
CPO1
Looks good.
CPO1 is offline   Reply With Quote
Old 05-12-2015, 09:13 AM   #269
4mulaSvaliant
4mulaSvaliant's Avatar
5" drop springs out back, 2 1/2" drop spindles and 2" drop springs in the front.
Other than a stiff ride in the rear, its great. I plan to keep th rear springs since I use it as a truck and haul stuff still. If anything I may throw a bit of weight back there to soften the ride a bit. Ill likely be putting in at least a 1" block in the rear as well. I like the rake, but its just a bit much.
64 LWB to SWB Step build. Daily driven!
http://67-72chevytrucks.com/vboard/s...d.php?t=647168
4mulaSvaliant is offline   Reply With Quote
Old 05-12-2015, 11:08 PM   #270
lobuck64
Did 3.5 front springs used rear springs for an a-body adjustable track bar rides good
lobuck64 is offline   Reply With Quote
Old 06-07-2015, 10:31 AM   #271
1stGrumpy
1stGrumpy's Avatar
Front has '85 crossmember swap with 2 1/2" drop spindles and 2" drop springs. Rear has '70 rear axle swap with Jeep Wrangler coils and 1" block.
Paddle faster, I hear banjo's...
1stGrumpy is offline   Reply With Quote
Old 06-08-2015, 06:34 AM   #272
kenwkirk
kenwkirk's Avatar
hey ---- would the truck (black stepside) ? possibly be 4 sale ? Thanks in advance
kenwkirk is offline   Reply With Quote
Old 06-09-2015, 01:41 PM   #273
sags
Previous owner had cut some coils (not sure how much) on front and rear. Just added 2.5 inch drop spindles. Front is way low - like an inch off the bumpstops. Bottoms out and tires rub when turning (but just barely). For those that said they cut them off, what shocks did you use? Also, I am taking suggestions for what size drop coils for the rear. I am thinking 3".
sags is offline   Reply With Quote
Old 06-10-2015, 08:56 AM   #274
Dubnova
Perfect ....You nailed it!
Dubnova is offline   Reply With Quote
Old 06-10-2015, 09:35 AM   #275
Texas1963
Texas1963's Avatar
I put the 5 inch from CPP on the rear and It looks an drives good no c notch, with adjustable track bar and spings with re-locator kit.
Texas1963 is offline   Reply With Quote
