05-01-2013, 09:06 PM | #251 |
Cool Truck
Re: 8 lug wheels - what's on YOUR truck?
I have always thought those H2s looked nice
1968 Chevrolet C20 Longhorn "Cool Truck" 1937 Chevrolet Pickup - Project Looking for a patina'd 68 50th Anniversary longbed |
05-01-2013, 09:26 PM | #252 |
What mine came with from po. Stuck with them for now Posted via Mobile Device
72 GMC super custom. |
05-11-2013, 06:24 PM | #253 | |
In my application, I actually WANT a lot of backspacing. (5-1/2" to 6" would be fine). Ideally, I really want a wider wheel....something in the 11"-12" range, so even if I find a Dodge wheel it will probably end up hacked apart to graft the center into a wider barrel. Thanks for the leads... -G Posted via Mobile Device
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well" Build |
05-11-2013, 09:58 PM | #254 |
Roto Reuter thats the name...
Looking good. What did you finally end up using on your caps?
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
05-11-2013, 11:30 PM | #255 | |
Here's a better pic of just the modified cap: Last edited by FirstOwner69; 05-11-2013 at 11:47 PM. |
05-14-2013, 07:43 PM | #256 |
all of you guys out there with newer GM 8 lug rims on their trucks how did you get the center cap to stay on the new style lug nuts did you change rotors? I have 2005 2500 hd wheels and caps and the new style lugs with the threads on them but the black covers in the caps will not reach the lug nut for some reason can any one help and any one have pictures with the wheel off and with it on and no cap by chance. thanks
05-15-2013, 06:55 AM | #257 |
Do you have a Dana60 rearend? If so, sounds like you're having the same problem I had? Your center cover won't go on because of the axle hub. I used 1 1/4" spacers on mine to get the rim out to where they would fit. Have since found out that I can get the centers for a dually set up that will work without the spacers. The spacers have been on for 3-4 years with no problems. pic of spacers below. Just bolt them on, and then use the studs on them to bolt your rims on.
LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! 1970 GMC LWB, Fleetside, 350/4spd, Flowmaster "40's", 2002 GMC 16" Rallies, cowl hood,and added a bunch of options that weren't there when I started. |
05-15-2013, 07:40 AM | #258 |
Here's a pic of them bolted on.
05-15-2013, 09:53 AM | #259 |
If you are looking for factory steel wheels try Stockton Wheels in Stockton CA. I had a set made to my specs. Turned out great.
Roger Koop |
05-15-2013, 05:45 PM | #260 |
Yep its a dana 60 and you are correct. I have the rear figured out I can go three ways to make them fit spacers, dually caps or the route i started and probably the most expensive is longer studs to accommodate a special lug that a local machinist can make me to fit the wheel but the cap will still hit the axle cover plate. so the dually caps or spacers is the better way on the rear for sure. Now I need to figure out the fronts I have the stock disk brake set up and once the wheel is on the lugs are tight the black cap covers that hold the cap to the rim wont reach, I can get one or two started but wont tighten up they pop off so I am about 3/4 of an inch or so shy from making them work on the front and need ideas for that if any one has any. Thanks OhioDan for the info so far much appreciated you to Roger if I cant get the look I want I will go the the steel wheels for sure and will look uo Stockton Wheel for sure.
05-16-2013, 11:25 AM | #261 |
Centerline Blackfoots in 16.5"...were on the Burb when I bought it, have been on it since the 90s. Not a bad wheel, but I want something different, that will be easier to get tires for.
-Nathan- 1972 GMC K2500 Suburban "The Project" 2013 GMC Sierra 1500 SLT Z71 "The Daily Driver" 2005 Ford F150 Lariat SCrew 2WD "The Daily Driver" SOLD 1995 GMC Sierra C1500 SLE "The Daily Driver"SOLD 2003 Ford Ranger Edge 2DSC 2WD Flareside "The Daily Driver/Project"SOLD |
05-17-2013, 08:52 PM | #262 |
The pic in my avatar is what I'm running for now. It's sideways, I know, but I just pretend it's climbing a really steep incline...or as special-k once said it looks fine if you're eating a taco. It's going to get 16x7 and power kings eventually.
'69 K20 350/4 speed/Rockwell/D44/HO52. "orange rhymes with door hinge" |
06-02-2013, 08:55 PM | #263 |
bought dually caps today at local swap meet brought them home and they will no not work either they are deep enough to let the axle cover fit inside the cap but the lug caps that screw on to the lug nuts to hold the cap on will not reach the lug nuts that is the same problem I have on the front with the stock 2005 3/4 ton cap I love the 2005 -06 3/4 ton wheels but this is getting crazy trying to get them to fit. If anyone can help out some more let me know
09-13-2013, 06:55 PM | #264 |
Stalker Nate
Bump for 8 lug guys. I'm trying to find the dually caps from a mid'90s Chevy to put on the steelies I have. One found set and it sold fast. Hoping to find another set or I'll just run spacers out back, but caps would be cheapest.
Nate
1957 GMC SWB stepper modified summer time driver 1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project 1965 Chevy P10 Ice Cream Truck project Instagram - TheDonutDiner FaceBook - @UscreamIscream |
09-13-2013, 07:58 PM | #265 |
i left the hubcaps off mine.
AE Series 018 20x9 |
09-14-2013, 11:25 AM | #266 |
Stalker Nate
10-31-2013, 11:59 AM | #267 | |
I have a 85 K20 and do not want to go over 17 or bigger wheel. |
10-31-2013, 12:32 PM | #268 |
I know you can get them in 16s, and would highly recommend it as you normally pay through the nose for 16.5 tires and selection is minimal.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
10-31-2013, 01:00 PM | #269 |
I was thinking about running these, as they kind of look like the old mags.
http://www.hotrodhanks.com/imagesProducts2/16358.jpg The old dually steel wheels also had oval holes, but 4 insted of 5. Maybe powdercoated white with OEM hub caps would make them look kind of vintage too! What do you guys think? UNLESS of course anybody knows of a company building 18" or 20" steel wheels, or aluminum that look like the OEM 16" steel wheels and take the OEM hub cap! If anybody hears about anything like that, LET ME KNOW!!!! Thanks
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104 68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441 |
10-31-2013, 04:31 PM | #270 |
Not wanting to hijack the thread but I am looking for advice of what vehicle I can do a swap out of rear axle that has disc breaks positraction and something that doesn't have to be cut on to make it work. I have a 72 c20 and want to stay with the same wheel package that I already have. Any advice or suggestions are appreciated.
Please pm me if anyone has any info. Thanks Robert
72 C20 custom extended cab short bed. http://i1320.photobucket.com/albums/...ps0be39e4c.jpg THE ONLY THING HOLDING ME BACK IS FEAR AND COMMON SENSE AND OF COURSE MONEY. |
10-31-2013, 04:47 PM | #271 | |
10-31-2013, 06:59 PM | #272 |
Extended72 there are kits out there for the C-20 I retrofit my 71 C-20 Longhorn with disc brakes out back for less than 500.00 with quality parts. the biggest trick on the C-20/30's are the rear hubs they rotor has to go on the back if the hub so when you do the job or need to turn the rotors you have to remove the hubs and that is time consuming but worth it for sure.
03-02-2014, 08:33 AM | #273 | |
My truck has the ho52 Eaton Axle. Thanks.
1971 Chevy C/20 Longhorn, 350/TH400, Edelbrock Performer, IMPCO 425 LPG Carb 1974 Chevy Camaro Z28 (Original) ------------------------- Capelle a/d IJssel, The Netherlands |
03-02-2014, 02:40 PM | #274 |
I have 8.25 & 9.75 -16.5 steelies but not looking like a truck for them for a while. Can't go wrong on a C/20. Guys never worried with hubcaps,either. I remember black wheels. They look great with chrome lugs
03-02-2014, 03:25 PM | #275 |
Heres mine.
