Old 06-28-2009, 08:50 PM   #251
protrash64
Resistance is Futile
protrash64's Avatar
Re: Daverods project 66
Hey daverod, wouldn't it be possible to just cut the ends where the frame rail meets the x-member instead of cutting the whole thing? Ive never done it nor do I have the parts sitting in front of me. Just a thought.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 06-28-2009, 11:58 PM   #252
Captainfab
60-66 Nut
Originally Posted by daverod View Post
I never really got that far in my thought process. Wouldnt you just drill new holes 1 1/2" higher then the old holes. It lookes you would have to fill in the big holes? What are the big holes for?
I believe those large holes are for access to the upper control arm mounting bolts/studs......incase they need to be changed I guess.
Old 06-29-2009, 12:06 AM   #253
daverod
SSN 706
daverod's Avatar
Thanks Capt.
daverod is offline   Reply With Quote
Old 06-29-2009, 12:12 AM   #254
daverod
SSN 706
daverod's Avatar
Now you come up with that idea? After I just spent all that time. It seems like it would work? I think it would be easier then cutting the whole thing. It might be harder to mount to trhe frame? All things to think about. I'll sleep on it. Ya I sleep Allan.
Old 06-29-2009, 12:20 AM   #255
joe231
joe231's Avatar
I believe you need the whole cross member sectioned like you did to clear your oil pan.....
I agree with you on the welding the access holes for the upper arm studs and drilling new holes...seems like the thing to do....but you might wanna cut some new access holes....just in case....
CHEVY ONLY
Old 06-29-2009, 12:26 AM   #256
Captainfab
60-66 Nut
Doing it this way, you can still use factory motor mount brackets. Otherwise you would most likely have to fab some new motor mont brackets as well.
Old 06-29-2009, 08:03 AM   #257
daverod
SSN 706
daverod's Avatar
I'm going to weld up both holes and drill some new ones. I knew there was reason nobody just cut a notch out. If it was that easy everyone would do it. Now I'm wondering if my transmission was going to hit the hump? Just somthing else to think about?
Old 06-29-2009, 08:07 AM   #258
joe231
joe231's Avatar
your engine and transmission should stay in the same relation to the cab and frame, all you are doing is moving the suspension up, you might have some steering linkage issues though.....
CHEVY ONLY
Old 06-29-2009, 09:34 AM   #259
daverod
SSN 706
daverod's Avatar
It seems like the engine and trans would also be 1 1/2 higher or closer to the floor of the cab? I got it. Your right like always. Thanks joe
Old 06-29-2009, 10:28 AM   #260
protrash64
protrash64's Avatar
I thought about the motor mount issue, but I swear Ive seen it done. I need to find the Street Trucks article about this...circa 2000. Turner Fab used to sell a kit with all the pieces; you cut the x-member, and then used their patch pieces to put it back together.
Well, looks like daverod will be guru on this
Old 06-29-2009, 04:22 PM   #261
daverod
SSN 706
daverod's Avatar
Ya, now FrizzleFry has no excuses. "Yes, please inspire me to chop my spare". Chop,Chop I don't know about the guru part. I just finished my first 10lb of wire. My welding is getting better though. I looking forward to welding somthing besides rusty body panels.
Old 06-29-2009, 06:13 PM   #262
protrash64
protrash64's Avatar
Ok guys.....I was right. I dug through my extensive library of Streettrucks mags and found the original articles on lowering trucks the ole school way. The first article appeared in Jan 2000 (issue 4). The follow-up appeared in March 2000(issue 6).
They only chopped out the location where the frame rails went thru the x-member. Lowers the truck 1.3-1.5''. They then section the lower half of the motor perches to keep the engine in its correct location. They also make a large notch across the front of the crossmember to provide clearance for the centerlink. They use the service hole for the upper a-arm bolts to mount the crossmember and drill 2 new holes thru to bolt it on.
I tried to search the site, but could not get a link to these 2 articles. I think the only way to get them is to get the mags.
Old 06-29-2009, 08:27 PM   #263
daverod
SSN 706
daverod's Avatar
Cool now we know a different way to do it. The way I did it was'nt very hard. I bet I had it laided out and cut in 2 hours. Pussed out on welding it though. Took it to the blacksmith. He's a hell of a welder. $80 cash, got to love the cash, be ready thursday. Hell, it would have cost my $20 in materials( wire, metal for the ends, grinding wheels, more grinding wheels, more wire). Parts fairy brought me my notch for the rear. Funny, all I hear is the door bell and then new parts. Got to love it.
Old 06-29-2009, 08:30 PM   #264
joe231
joe231's Avatar
well I guess you better get busy scanning them in so you can post them here
CHEVY ONLY
Old 06-29-2009, 08:33 PM   #265
daverod
SSN 706
daverod's Avatar
Ya we need pic's. I still have another cross member.
Old 06-29-2009, 08:51 PM   #266
Strodder
Daring to be Different
Strodder's Avatar
I remember that tech article. Since you read StreetTrucks back then do remember this truck.
It was my sons truck. He did a lot of tech pages for the magazine. But not the one we're talking about. He owned Sportruck Specialties in Carson, Ca, and I owned Sportruck Specialties in Simi Valley, Ca.
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 06-29-2009, 09:08 PM   #267
daverod
SSN 706
daverod's Avatar
Well , get scanning. We need pic's. That's cool your kinda like famous and stuff. I wish I would have gotton into trucks/cars sooner. In 2000 I was busting my a$$ framing houses for the man.
Old 06-29-2009, 09:09 PM   #268
Strodder
Strodder's Avatar
Wel,l get scanning. We need pic's.
I save all my old magazines. I'll look for it.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 06-29-2009, 09:39 PM   #269
protrash64
protrash64's Avatar
I remember that truck...it was very nice. A bunch the tech articles were about the 4cyl performance IIRC. Kinda like 'jumbo shrimp' in my book
Old 06-29-2009, 09:51 PM   #270
Strodder
Strodder's Avatar
He did pretty good selling the 4 cylinder stuff. He is still selling them. But not as much. He's into Cafe Racers now building bikes.
http://www.lossaengineering.com/
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 06-29-2009, 10:33 PM   #271
daverod
SSN 706
daverod's Avatar
Some of those bikes your son has remind me of an old yz 80 I have sitting out in my barn. I was going to restore it at one time, still runs had it since I was 14. Cut all the crap off my frame now all I have to do is make a pattern so I'll know where to cut.
Old 06-29-2009, 11:37 PM   #272
daverod
SSN 706
daverod's Avatar
Got one side cut out. Made a nice pattern. Put it on backwards,and cut it out, nice. It only made a difference of about 1/2" of metal. What did Stodder say about drinking and working. I'll make sure and do the other side the same so they match.
Old 06-30-2009, 01:18 AM   #273
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Dave I know you were looking at airbagit.com. I'm going to tell you to stay away from there. The bags they sell are cheap because they suck, I would say go with Airlift D2600 bags or RE7's, Firestone and connitech aren't that bad, but you pay for what you get. If you want ones that wont give you problems get either of the first 2 I told you about. The RE7's have a internal bump stop in them. But they are costly at over 100 a bag. Check out ***************** they sometimes give discounts on their bags.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 06-30-2009, 08:52 AM   #274
daverod
SSN 706
daverod's Avatar
Thanks Ruffrida. I'm thinking about just putting bags on the back.
Old 06-30-2009, 10:46 AM   #275
Strodder
Strodder's Avatar
I've used Firestone, and Contitech bags all the time. The biggest problem is the person installing them incorrectly. Other wise I never had a failure. I sell Contitech bags for $69.00 each.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
