Old 05-14-2012, 12:13 PM   #251
7dee2
7dee2's Avatar
Re: 69 GMC "Ol' Blue"
As usual your work is great. Looks real good.
I think the splitter is a very cool idea for your application..
Brett
67 Camaro SS Build:http://67-72chevytrucks.com/vboard/s...d.php?t=751594
72 Cheyenne/10 Super 115" Fleetside (Waiting it's turn.)
72 Cheyenne/K30 Super 133" DRW SOLD Build:http://67-72chevytrucks.com/vboard/s...d.php?t=645614
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 05-14-2012, 01:07 PM   #252
mjensen
mjensen's Avatar
Thanks! I hope to get the cross members figured out this week so that I can finish the painting this weekend.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 05-14-2012, 11:23 PM   #253
mjensen
mjensen's Avatar
The only progress to report today was to get the remaining grease and grime off the TCase. It's now ready for one final bath, then wax and grease remover, then some paint...oh, then find all the parts and put it back together...
If it seems like I keep jumping around, that's because that's how I manage my ADD....
Mike
Old 05-15-2012, 05:01 PM   #254
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Looking good!
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 05-15-2012, 10:25 PM   #255
mjensen
mjensen's Avatar
Originally Posted by Dieselwrencher View Post
Looking good!
Thanks!
Mike
Old 05-19-2012, 09:24 PM   #256
mjensen
mjensen's Avatar
Well, not a ton of progress today, but I did get some painting done...
Mike
Old 05-19-2012, 10:45 PM   #257
thelonerife
thelonerife's Avatar
Attachment 926909
Attachment 926910
HAHA Me too!
thelonerife is offline   Reply With Quote
Old 09-09-2012, 08:16 PM   #258
mjensen
mjensen's Avatar
Well, it's been a while since I have worked on the truck but I finally got out and finished spraying the Rust Encapsulator on the frame. I've got to say, I am pretty impressed with the Preval spray system for something like this. When it comes to the top coat, I will bust out a real gun but for the encapsulator it was awesome.
Also bought a few new toys since the last time I posted
2012 GMC Sierra 6.2L
New TIG
Mike
Old 09-11-2012, 11:54 AM   #259
7dee2
7dee2's Avatar
Nice truck! Have fun with that new welder...
Brett
Old 09-11-2012, 11:09 PM   #260
mjensen
mjensen's Avatar
Thanks! All I have to do now is learn how to turn it on LOL
Mike
Old 09-11-2012, 11:44 PM   #261
thelonerife
Nice work. I just caught up on this thread. I'll keep watching.
Old 09-13-2012, 05:08 PM   #262
mjensen
mjensen's Avatar
Thank you! Thanks for joining. Hopefully I can make enough progress to watch here in the next few weeks.
Mike
Old 09-13-2012, 08:39 PM   #263
Dieselwrencher
Sweet welder and new truck! Your frame is looking nice too!
Ryan
Old 09-13-2012, 10:30 PM   #264
mjensen
mjensen's Avatar
Thanks Ryan!
Mike
Old 09-15-2012, 10:21 PM   #265
mjensen
mjensen's Avatar
Well, I actually worked on Ol' Blue today. I'm test fitting the rear suspension now. I'm still trying to decide if I'm going to replace the HO 52's pinion seal, or find me a later model 4.10. Either way, this thing is going to be a beast one day!!!
Do these look right? If anyone is checking this post out.
Mike
Old 09-15-2012, 11:02 PM   #266
mud.man.rj
mud.man.rj's Avatar
Top leaf spring bolt goes thru from the inside out so it won't hit or rub frame, that's factory. If you actually have a lot of clearance could leave it, may twist a bit when cornering or in a rut with one tire down and one up.
mud.man.rj is offline   Reply With Quote
Old 09-16-2012, 01:07 AM   #267
mjensen
mjensen's Avatar
Thanks! I'll switch it around. I really can't remember how it all goes.
Mike
Old 09-16-2012, 06:11 PM   #268
mjensen
mjensen's Avatar
Okay, so the front suspension was derailed because of a lack of having all of the bolts. A question I have is on the rear spring mounts for the front suspension, it seems like a very specific carriage bolt. Does anyone know if I really need to use one of those, or can I just use a regular grade 8? I'm asking because to buy the bolt from LMC specifically for that mount, they're 9+ a pop!
Mike
Old 09-30-2012, 12:26 AM   #269
mjensen
mjensen's Avatar
Got out and did some work today! I made my own spring hangers today. I must say that they didn't turn out too bad considering the only tools were my plasma and grinder!
On another note, I noticed that I have one of my rear springs backwards so my rear is out of alignment. Good thing this is just a mock up phase
Mike
Old 09-30-2012, 10:28 PM   #270
mjensen
mjensen's Avatar
Today's progress was finishing the cross member move. Next up..test fitting the power train to see if I measured correctly
Mike
Old 10-01-2012, 01:49 PM   #271
7dee2
7dee2's Avatar
Ok, so I'm probably the only one in the world that thinks this is exciting...
Attachment 924919
Attachment 924920
Hey MJ have you looked into this? A gear lever actuator with a control arm connecting the actuator & the OD unit?
http://www.google.com/search?q=Gear+...w=1920&bih=965
http://www.sharpshifter.co.nz/components_cars.html
These solutions are expensive!!
Brett
Old 10-01-2012, 02:04 PM   #272
7dee2
7dee2's Avatar
One more idea if all else fails. Put a manual shift lever through the floor pan. Back in the day the old big trucks used this method and was referred to as a set of sticks. This would be the easiest & cheapest method I can think of to actuate the OD unit.
Brett
Old 10-01-2012, 02:28 PM   #273
mjensen
mjensen's Avatar
Yeah, that is pretty pricey! I've found a couple of electric actuators, but I like the gear lever actuators. Maybe I could find one off a Mack or something
This is the way Advanced Adapters has it designed, but I think it would get to be a real pain when I want to split all gears (not that I would all the time, but what if ).
Thanks for the input! I'm thinking I'm going to try and go with the gear actuator method if I can find one. Luckily I work for a company that has a ton of semi's so maybe I can get one off an old rig.
Mike
Old 10-03-2012, 12:03 AM   #274
mjensen
mjensen's Avatar
I was able to procure a 14 bolt FF for $100 this week. I'm heading out to pick it up this weekend. Not too bad of a deal in my opinion.
Mike
Old 10-03-2012, 12:33 AM   #275
mud.man.rj
mud.man.rj's Avatar
I found a weird one a 14 bolt semi floater with a 6 bolt (1/2 ton 4x4) pattern, never saw one before, only have seen a 14 bolt 8lug, semi or FF. But would not sell it at this time.
